avatar_Spey_Phantom
My stash just grew again 2026
Started by Spey_Phantom, December 31, 2025, 02:21:11 PM
Quote from: The Wooksta! on May 15, 2026, 08:16:56 AM
Quote from: chrisonord on May 13, 2026, 03:06:47 PMI got it from Lost British projects on Facebook, they do a lot of interesting stuff in any scale you want. It's going to need a lot of work, and it doesn't have a clear canopy unfortunately, and it is quite textured, hence the lots of work. I was advised to get some 3D print coating epoxy resin which will smooth it all out, as sanding can cause problems.
Hicote do filler primer, about £7 a can. It's decent stuff, I used it on the Contrail Ju 390. Try your nearest branch of The Range or any automotive supply shop as the latter will usually carry some Hicote paints.  Failing that, get several cans of really cheap primer from Poundland, built it up and sand back.
cheers Lee /Kit. I already have some of the black AK interactive stuff, so I will try that, failing that I will get some of the hicote stuff, cheers  :thumbsup:
Arrived this evening from eModels
1 x 1/72 Modelsvit 72076 Mirage 2000N
Another unexpected ev!lbay win: an MPM 1:72 Douglas A-20G (with glass nose) for just 10,-.  :rolleyes:
Again with no real plan, but I consider a RAF Coastal Command aircraft with rockets against submarines in the Channel.
Quote from: PR19_Kit on May 15, 2026, 08:34:03 AM
Quote from: The Wooksta! on May 15, 2026, 08:16:56 AMHicote do filler primer, about £7 a can. It's decent stuff, I used it on the Contrail Ju 390. Try your nearest branch of The Range or any automotive supply shop as the latter will usually carry some Hicote paints.  Failing that, get several cans of really cheap primer from Poundland, built it up and sand back.
It sure is good, I've been using it since Halfords did their 'upgrade', and the Hycote stuff is a little bit pricier than Halfords was, but now it's cheaper, per volume anyway.
The standard Halfords cans have 330ml, whereas the same size Hicote ones are 400ml.  I can't recommend the Hicote paints highly enough.
Won on eBay the Academy 1/72 Boeing KB-29P , Revell 1/72 Douglas DC-4 and the 1/25 Dodge Viper hardtop.
Bought on eBay, Tamiya acrylic primer, black and white paint in rattle cans
Anothter sudden ev!lbay-win: the Italeri 1:72 Frecce Tricolore set with an MB.339, a G.91R and a an F-86 for less than EUR 25,-. The Gina alone goes for more these days.  :lol:
From Spruefinders.  I thought about one of these when they first came out but procrastinated and then the 1/24 ones were not around, just the 1/35.
Admiral Cabriolet by Fred Maillardet, on Flickr
Multipiece body with chrome parts and rubber tyres.  It needs to be lower over whitewalls.  Lose the bumpers, roll the pans.  Or maybe a more contemporary Street Rod with Big wheels/thin tyres and a modern V8.
Received today from eBay
2 x 1/72 Modelsvit 72073 Mirage 2000C. One each for the Indian and Greek options on the decal sheet.
This lot arrived today;
Quote from: Old Wombat on May 13, 2026, 11:10:25 AM1 x Peewit 1/35 Skoda-Praga L [3D Printed Model] (PW-35001) - Czech!
1 x Hobby Boss 1/35 152mm ShkH DANA vz.77 (HB 85501) - Czech!
1 x Special Hobby 1/35 Skoda 7.5cm Horsky Kanon vz.15/7.5cm Gebirgskanone M.15 (SH-SA35002) - Czech!
1 x IBG 1/35 Skoda 100mm vz 14 Howitzer (IBG35026) - Czech!
1 x 1/35 Skoda 100mm vz 14/19 Howitzer (optional metal barrel included) (IBG35025) - Czech!
1 x AFV Club 1/35 Australian Army M113A1 LRV 1980 Transitional Model (AFV-AF35313) - Aussie!
2 x Master Models 1/48 Hawker Siddeley Buccaneer - Pitot Tube and Refueling Probe (AM-48-100) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2's (AX12012)
2 x Metallic Details 1/48 Blackburn Buccaneer Landing Gears for Airfix kit #12012 (MED-MDR48194) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2's (AX12012)
1 x Eduard 1/48 Blackburn Buccaneer S.2B Detail set for Airfix kits (ED FE1440) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012)for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012), requested notification for another
1 x QuickBoost 1/48 Blackburn H.S. Buccaneer Antennas for Airfix kits (QB49008) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012)for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012), requested notification for another
The Praga has some heft to it but it looks really good, despite a broken mud guard. Only about a dozen pieces in total & maybe 6 decals. It may get built sooner, rather than later.
The Metallic Details Bucc landing gear is all 3D printed & looks way better than I imagined - I just hope it's strong enough to hold the builds off the ground once built.
While going through The Loft in my old house the other weekend, I filled up a large box (like a 4 ft cube....) with various kits that were lying about the place. I've only just got to check the stuff that's in the box, and one is something I'd forgotten about, and started AEONS ago, and I've mentioned it on here a few times too.
The much sought after 'Holy Grail' of 1/144 scale modellers, the Otaki C-5 Galaxy kit!  ;D
I seem to have glued the fuselage, and the wings, but not joined them yet, and then just left it, no idea why. As I'm doing my RAF C-133C Durham right now my thoughts are turning to an RAF Galaxy, with RB-211 engines of course, but I'm trying to imagine what the RAF would have called it. As it would have to have a city or town name, preferably one that exists in both countries, 'Birmingham' comes to mind, except it would always end up being called a 'Brum' in the real world.  ;D
If it helps,  there is a Lichfield Illinois  and a  city of Lichfield in Staffordshire.  The Lockheed Lichfield is therefore a possibility.
I happen to have one of those in my stash as well, mine is unstarted though
