avatar_Spey_Phantom
My stash just grew again 2026
Started by Spey_Phantom, December 31, 2025, 02:21:11 PM
Ordered!
Hopefully on their way soon;
1 x Peewit 1/35 Skoda-Praga L [3D Printed Model] (PW-35001) - Czech!
1 x Hobby Boss 1/35 152mm ShkH DANA vz.77 (HB 85501) - Czech!
1 x Special Hobby 1/35 Skoda 7.5cm Horsky Kanon vz.15/7.5cm Gebirgskanone M.15 (SH-SA35002) - Czech!
1 x IBG 1/35 Skoda 100mm vz 14 Howitzer (IBG35026) - Czech!
1 x 1/35 Skoda 100mm vz 14/19 Howitzer (optional metal barrel included) (IBG35025) - Czech!
1 x AFV Club 1/35 Australian Army M113A1 LRV 1980 Transitional Model (AFV-AF35313) - Aussie!
2 x Master Models 1/48 Hawker Siddeley Buccaneer - Pitot Tube and Refueling Probe (AM-48-100) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2's (AX12012)
2 x Metallic Details 1/48 Blackburn Buccaneer Landing Gears for Airfix kit #12012 (MED-MDR48194) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2's (AX12012)
1 x Eduard 1/48 Blackburn Buccaneer S.2B Detail set for Airfix kits (ED FE1440) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012)for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012), requested notification for another
1 x QuickBoost 1/48 Blackburn H.S. Buccaneer Antennas for Airfix kits (QB49008) - for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012)for my 2x Airfix 1/48 Blackburn Buccaneer S.2s (AX12012), requested notification for another
A big order, but a pay rise backpay today makes it affordable.  :thumbsup:
Received this evening from eBay
1 x 1/72 Modelsvit 72074 Mirage 2000B
Charlie_c67
Quote from: Thorvic on May 13, 2026, 08:24:22 AMFrom  Hannants
KP 1/72 Aeronacchi MB-339 with guns - includes 3d printed wing mounted gun pods as used by the Argentine Navy in the Falklands War.
KP 1/72 HS-125 Dominie prototype boxing
KP 1/72 HS-125 Dominie T1 - standard Red & White scheme
How good is the MB-339? Not seen one of these in the flesh so to speak.
Quote from: chrisonord on May 13, 2026, 03:20:35 AMJust arrived, Lost British projects P. 1214, in 1/72 scale. Looking like it will need a lot of work, but I will just do bits of it here and there.
Interesting Chris. Where did you get it?
Quote from: Gondor on May 13, 2026, 01:44:27 PM
I got it from Lost British projects on Facebook, they do a lot of interesting stuff in any scale you want. It's going to need a lot of work, and it doesn't have a clear canopy unfortunately, and it is quite textured, hence the lots of work. I was advised to get some 3D print coating epoxy resin which will smooth it all out, as sanding can cause problems.
Leading Observer
#620
Quote from: chrisonord on May 13, 2026, 03:06:47 PM
I got one too, and Chris is quite correct about the work involved if you want a perfect finish. My Supermarine 545 Superswift https://www.whatifmodellers.com/index.php?topic=54238.msg1090569#msg1090569 was a LBP model
LO
Quote from: chrisonord on May 13, 2026, 03:06:47 PMI got it from Lost British projects on Facebook, they do a lot of interesting stuff in any scale you want. It's going to need a lot of work, and it doesn't have a clear canopy unfortunately, and it is quite textured, hence the lots of work. I was advised to get some 3D print coating epoxy resin which will smooth it all out, as sanding can cause problems.
Maybe knifing putty, a type of fine car filler, would work. Very good for small detail work, quite malleable and easy to spread.
Quote from: Gondor on May 13, 2026, 11:45:16 PM
I have some knifing putty, and I think it will be too thick for the kind of work it will need to do. I am also thinking of filler primer, sprayed on, if there is a very fine version available.
Won on eBay, hopefully this one will have all the parts included. 1/72 Revell Avro Shackleton AEW.2.
Quote from: chrisonord on May 14, 2026, 04:49:08 AM
AK Interactive and Mr Hobby both do such things; others may also be available depending on how you search the internet.
Received from a nice man on Britmodeller
1 x 1/48 Canberra Corrected tail surfaces
Found an Airfix HS/BAe Nimrod R/MR on eBay for less than £60.
Hawkrod lives on !
Also bought from eBay all in /72 scale:
Heller Lockheed EC-121 Warning Star
AIM Transport Wings the Rolls-Royce Dart turboprops for the Vickers Viscount and the SLAR pod set.
Allison turboprop engine conversion set for the Convair 580 series.
Another bargain on eBay the Academy 1/72 Martin PBM-5A Mariner. Hopefully this will be better than the Mach2 model kit but it also has issues with the wings and front gun turret.
Hicote do filler primer, about £7 a can. It's decent stuff, I used it on the Contrail Ju 390. Try your nearest branch of The Range or any automotive supply shop as the latter will usually carry some Hicote paints.  Failing that, get several cans of really cheap primer from Poundland, built it up and sand back.
Quote from: The Wooksta! on May 15, 2026, 08:16:56 AMHicote do filler primer, about £7 a can. It's decent stuff, I used it on the Contrail Ju 390. Try your nearest branch of The Range or any automotive supply shop as the latter will usually carry some Hicote paints.  Failing that, get several cans of really cheap primer from Poundland, built it up and sand back.
It sure is good, I've been using it since Halfords did their 'upgrade', and the Hycote stuff is a little bit pricier than Halfords was, but now it's cheaper, per volume anyway.
Received today, direct from RS Models
1 x 1/72 Decal sheet for 92274 Nakajima Ki-201 "Karyu". Hopefully, this will give me some motivation to get on with the build now that I have the correct decals for the box.
