avatar_George the Cat
George the Cat's modelling plans
Started by George the Cat, April 18, 2025, 12:43:29 AM
I got so sick and tired of knocking over my Tamiya glues iues to take a chunk of polystyrene and cut a square out of it and put the glue in that ,,worked a treat ,,,now i've use a Depiae one my mate Perrin gave me ,,its machined from a solid block of alloy with a anti slip pad on the base ,,fecking love it  ;D
For my superglues and tube putty i just use a old business card container which works great too,,keeps everything sitting up right  :thumbsup:
I use the Tamiya square bottles with the small brushes and decant the larger bottles of glue into it, a bit at a time.
They've got a solid base and a low centre of gravity, so it's working for me so far.  :thumbsup:
And if it did spill, there's not so much to lose.
And I do store the superglue upright, but it still goes off within a week.  :banghead:
George the Cat
One more project just finished. Airfix 1/72 Hawk D3 drone. Paint, Llanbedr Yellow and BR rail freight red. Freightdog's extended rear fuselage also used with plastic card strakes on the airbrake. Will be showing this one at Thornbury this Sunday.
Great idea for the glue holder ! I need to do something like that and build myself a travelling kit. Of course, now that I'm nearing the end of my career I'd devise a perfect travelling kit......
The drone looks great as well ! Canada just retired all of our Hawks and sent them to the school in Borden. Surely we could have shot a couple down !?
George the Cat
Quote from: Captain Canada on July 31, 2025, 04:58:31 AMThe drone looks great as well ! Canada just retired all of our Hawks and sent them to the school in Borden. Surely we could have shot a couple down !?
Thanks Captain. Must do something new and Canadian one day.
The drone Hawk makes sense, looks good Trev. :thumbsup:
George the Cat
Quote from: Mossie on July 31, 2025, 01:55:33 PMThe drone Hawk makes sense, looks good Trev. :thumbsup:
Thanks.There are a few other wiffed Hawks to do, an Irish and Belgian ones being but two. I imagined this Hawk being a full scale aerial target somewhere in west Wales......
George the Cat
PR19Kit will be pleased to see the progress with the MB12. I have begun the process of getting all the bits glued up. Long way to go.
This is going to be one of those double-take moments for Rivet Counters when it's on a show table!  ;D  ;D  :wacko:  :thumbsup:
That's looking very promising Trevor, that centre section is almost EXACTLY the correct chord for an MB5/6 wing too.
Will it be a four seater, with the double length canopies?
One day i've got to build a twin fuselaged plane cause this is starting to look very cool and it's a twin engined bird to ..so instant like  ;D  ;D
George the Cat
This indicates the extent of the work on the underside of the MB12 very well. Lots of filler, plastic card and scraping required.
George the Cat
This one is now done. F104C in the Black Mike markings of 111 Sqn RAF
George the Cat
The top side of the MB12. Put the tailplane in earlier this afternoon. In a bit it's off to a rather good annual BBQ. As there is no etch brass for the Martin Baker, naturally I am using an F82 set from Airwaves.
