avatar_George the Cat
George the Cat's modelling plans
Started by George the Cat, April 18, 2025, 12:43:29 AM
George the Cat
I didn't really have a blog under my old name well not for years. So here is the new one.... Just some random modelling related jottings.
First off would the FAA seriously look at an anglicised FA18 for a suitably adapted Queen Elizabeth class carrier?
I think EDSG would look good on a Super Hornet.  :wacko:
In some Alternate Universe the RN never gave up on CTOL carriers! ;)
Charlie_c67
Quote from: George the Cat on April 18, 2025, 12:43:29 AMI didn't really have a blog under my old name well not for years. So here is the new one.... Just some random modelling related jottings.
Funny you should say that....  ;)
by charlie_c67
George the Cat
Charlie_C67 that looks good. Mine will get ASRAAM and Storm Shadows.
George the Cat
Today's modelling also has a naval theme.... Xtrakit 1/72 Saunders Roe SRA-1. Going for an ocean grey finish on top with aluminium undersides and BPF markings. More work on this tomorrow.
A nice kit that SRA/1. Needed longer wings though, so I added some.  ;D
BPF sounds good Trev. Would work for the Op Downfall GB if it gets the go ahead (be a bit late for your build though)
There was quite a lot of artwork circulated around the new aircraft carriers with the Hornet on the flight deck.
Quote from: PR19_Kit on April 20, 2025, 08:33:36 AMA nice kit that SRA/1. Needed longer wings though, so I added some.  ;D
Decent kit yup, but I was surprised at just how large and ugly the thing was.
Did mine as Greek.
It sure is big, but they wanted long range and it had two fuel hungry engines of the time.
George the Cat
After the palaver of losing a float, the missing one turned up this morning. The kit parts to attach float to wings are awful so I am going to replace what's here with some old Aeroclub foil struts using the slots on the floats. I have also added some Paragon 100 gallon wing tanks for the Mosquito to the wings.
Good to see the wayward float returned home, Trevor! :thumbsup:
I read your post but I don't have much in 1/72 scale, let alone anything with floats.
George the Cat
Quote from: Old Wombat on May 04, 2025, 07:54:03 AMGood to see the wayward float returned home, Trevor! :thumbsup:
I was very relieved.
George the Cat
The completed work on the struts for the wing floats. Wasn't too fiddly to do in the end. Also one of the wing tanks visible.
That float retraction system is a work of................I'm not sure if it's genius or craziness, but it's pretty clever.  ;D
