avatar_Wardukw
BoeConsol B-33 Bomber Escort
Started by Wardukw, August 22, 2025, 08:17:23 PM
63cpe
Wooooow, looks great even though It's not finished yet. It's a crazy cool plan to realize. Amazing you've taken the plunge.
Carry-on! I'd love to see this finished.
David aka 63cpe
Quote from: Rick Lowe on August 30, 2025, 07:05:39 PMCrazy, but in a Good Way!
Jamie is impressed, and says he's very happy to have aided and abetted such Madness.  :thumbsup:  ;D
Thanks ya  matey  ;D..tell Jamie he's seen nothing yet 😉 😀
Guy and Dave  ;D  ;D..thanks gents ....one thing I can guarantee for sure  ...im gonna need more putty  :lol:
Cool.  :thumbsup:
Technically speaking what you have there is a tandem wing aircraft. Those large forward surfaces would provide lift and support the fwd. fuselage, unlike in the classic canard configuration in which the surfaces supply minimal lift and are used for stability and control. A propeller driven canard design also requires that the mainplanes be swept for CG placement and basic pitch stability. The same problem that bedevils all tailless designs.
Quote from: jcf on August 30, 2025, 11:13:53 PMCool.  :thumbsup:
Thanks for that Jon mate  . ..so im a thinking that calling em winglets would be a more accurate description for em 🤔
I like it..forward winglets  :thumbsup:
Scotaidh
That's brilliant!   :thumbsup: I've seen artists' impressions of a Lanc done that way, but never a Liberator - well done!  I'm thinking that if you can get rid of the main wings' forward sweep you'll simplify the engines, mate - can you pad the front of the wing sockets?  Maybe file down the wing roots a bit?  I'm sure you've considered all that - but why take the easy way out. eh?  ;)
Mind you, I've read that the Sunderland's wings were swiped from another aircraft and installed with a few degrees backward stagger, so the engines were always pulling out to 'their' side, so to speak - making the aircraft very stable, so long as all engines functioned normally.  Engine out must have been exciting, though ...  :D
Robomog
That is looking beautifully bonkers at the moment, keep up the good work.
I'd swear you have shares in a model filler company  ;)  ;D  ;D
Mog
F**king A.   :thumbsup:
Although IMO the winglets need some sweep to their trailing edge mirroring the main wings.
Quote from: Scotaidh on August 31, 2025, 03:00:57 AMThat's brilliant!   :thumbsup: I've seen artists' impressions of a Lanc done that way, but never a Liberator - well done!  I'm thinking that if you can get rid of the main wings' forward sweep you'll simplify the engines, mate - can you pad the front of the wing sockets?  Maybe file down the wing roots a bit?  I'm sure you've considered all that - but why take the easy way out. eh?  ;)
Matey things with thing are looking better and better ,,in my warped mind that is  :wacko:
The wings are no where near done yet ,,they are going to be totally smoothed into the fuselage for one thing ...yep the cheating side of things is being used as much as possible here ,,,its was much simpler to cut out the mounts from a useless B-24 fuselage than to mock up a whole new mount and then smooth the two together ,,there's still a ton of smoothing to go just to blend the 24's mounts into the 17's fuselage but i did more yesterday to sort that and then realized im not even half way there yet  :o  ;D
As for the engines ...yep entirely new look for them as it turns out ,,,i'm not looking more towards TU-95 Bear for that as this is getting TP's and it will make it easier to lengthen the engines too . ;D  ;D
Quote from: Robomog on August 31, 2025, 03:24:13 AMThat is looking beautifully bonkers at the moment, keep up the good work.
Mog
Moggy bud i'm looking at putting an order in this week for quite alot more putty than i have i can tell ya  ;D  ;D
Quote from: zenrat on August 31, 2025, 04:08:03 AMF**king A.   :thumbsup:
watch this space buddy boy  ;)  ;D  :wacko:
perttime
Quote from: Wardukw on August 30, 2025, 11:40:13 PM
Better just call them wings. In the Real World, "winglets" means something a little different.
"Bonkers" sounds appropriate  ;D
Quote from: perttime on August 31, 2025, 09:14:50 PM
Winglets are yummy if there the ones your thinking off 😋 😉
Bonkers are an actual thing in aviation. They are small explosive charges, that are used to induce a change in direction, without damage to the surface they are mounted on. Only used in the development stage and predominantly in the 60's.
perttime
Quote from: Wardukw on September 01, 2025, 12:32:00 AM
Actually, I was thinking of:
https://en.wikipedia.org/wiki/Wingtip_device#Winglets
But also: "The term "winglet" was previously used to describe an additional lifting surface on an aircraft, like a short section between wheels on fixed undercarriage. Richard Whitcomb's research in the 1970s at NASA first used winglet with its modern meaning referring to near-vertical extension of the wing tips."
If not winglets, then how about 'foreplanes"?
Quote from: zenrat on September 01, 2025, 04:09:36 AMIf not winglets, then how about 'foreplanes"?
Ahhhh ha ..yeah it shows that me brain sometimes went straight to food instead of to winglets  :banghead:  ;D
Mate I'm liking foreplanes even tho it sounds like a part from a boat  :wacko:
Or call em TLFW's "The little front wings"
What ever the hell they end being called I'm still chuffed they were so easy to sort out  ;D
