avatar_Leading Observer
Westland Whirlwind Whirling in my brain
Started by Leading Observer, October 15, 2025, 07:49:01 AM
Doug K
perttime
Looks good!
I've been thinking that the Whirlwind needs a sleeker cockpit canopy. Something from a late model Spitfire/Seafire, or P-47/P-51/Bearcat, if it needs to be larger.
Waterspout does look good  :thumbsup:  And it's got BPF markings which adds to the attractivness  ;)  :thumbsup:
Scotaidh
Quote from: Weaver on October 23, 2025, 11:01:44 AMWestland Warlock
Westland Wallaby
Westland Waltzer
Westland Wanderer
Westland Warhorse
Westland Warlord
Westland Warrior
Westland Warthog
Westland Watchman
Westland Waxwing
Westland Wayfarer
Westland Wayland
Westland Wotsit
Quote from: zenrat on October 29, 2025, 02:22:50 AM
Quote from: Scotaidh on October 29, 2025, 01:52:50 AMWestland Wotsit
I'm not sure.  It's a bit cheesy...
 :wacko:
  ;D
Westland Waffle - what if Barnes Wallis took his geodetic construction to Westland instead of Vickers.
Charlie_c67
Scotaidh
Westland Wolverine
Has anyone done a radial-engined Whirlwind?
George the Cat
Charlie_c67
Quote from: Scotaidh on October 29, 2025, 12:04:14 PMHas anyone done a radial-engined Whirlwind?
Question is Mercury, Pegasus or Hercules? CoughorCentauruscough  :wacko:  :wacko:  :wacko:
63cpe
Quote from: Charlie_c67 on October 29, 2025, 12:39:34 PM
Mmm, not yet. But it's a great idea....Centaurus it is...
David aka 63CPE
Centaurus is way too big and heavy for a Whirlwind size airframe. A later series
Hercules type would give you more than enough oomph from a smaller package.
Plus it has the rear swept exhausts so you can do the collected side exit exhaust
thing like a Sea Fury if so desired. The Bristol Freighter has 2,000hp Hercules 734
engines, so the Airfix kit could be a start for cowlings/nacelles, but even then you'll
see how big they are in comparison to a Whirlwind airframe.
The Gloster F.9/37 is the best example of an aircraft that had both radial and inline
engines, Bristol Taurus and R-R Peregrine respectively. It was faster with the Taurus.
As I've mentioned before, Dizzy has - IIRC he used Airfix Dinah nacelles, put a whacking great anti-tank cannon in the nose and tasked it for ground attack.
He may chime in with a link, otherwise it'll be on his Flickr feed somewhere.  :thumbsup:
