avatar_Leading Observer
Westland Whirlwind Whirling in my brain
Started by Leading Observer, October 15, 2025, 07:49:01 AM
Now there's an idea. How about a Whirlwind powered with two Pythons? That should get a bit of a move on, eh?  ;D
Quote from: zenrat on October 22, 2025, 03:24:08 AMOr a Wyvern powered by a Peregrine... :-\
I'm not sure it would have enough grunt to reach the threshold, let alone take off! :(
Leading Observer
Quote from: PR19_Kit on October 22, 2025, 03:47:43 AM
It would be a bit like the fibreglass Hurricanes used in the Battle of Britain film - the prop would turn and ...
LO
63cpe
Quote from: Old Wombat on October 21, 2025, 08:07:24 PMI don't want to appear rude, David, but this is a Wyvern;
This is a Whirlwind;
Ah, you're completely right. It's a Whirlwind offcourse. The Wyvern is totally different in concept and age.. :banghead:
Unless you did a Merlin engined Whirlwind & called in a Wyvern, which I'm unaware of, then upgraded that?  :unsure:
Charlie_c67
I mean you could call any adaptation of the Whirlwind the Westland Willy-Willy to save any confusion...  :wacko:  :wacko:  :wacko:
Staying with mythology like the Wyvern:
Westland Wyrm
Westland Woden
I suppose you could also reuse names Westland had used previously like Witch, Wizard and, my favourite, Weasel.
;D
Quote from: jcf on October 22, 2025, 03:19:23 PMI suppose you could also reuse names Westland had used previously like ...[snip]..., my favourite, Weasel.
;D
And, if you set it free, it would be a Wild Weasel:angel:  :angel:  :angel:
Hat! Coat! Gone!  ;D  ;D  ;D
Charlie_c67
#40
Westland Wazzock? Often seen paired with its Antipodean cousin the Bristol Bogan...  :laugh:
Westland Warlock
Westland Wallaby
Westland Waltzer
Westland Wanderer
Westland Warhorse
Westland Warlord
Westland Warrior
Westland Warthog
Westland Watchman
Westland Waxwing
Westland Wayfarer
Westland Wayland
63cpe
Wallaby, Sopwith.
Warrior, Republic P-44.
Quote from: jcf on October 23, 2025, 03:31:38 PMWallaby, Sopwith.
Lightning: Lockheed P-38
Lightning: English Electric
Lightning: Lockheed Martin F-35
Still happened though...
