avatar_Leading Observer
Westland Whirlwind Whirling in my brain
Started by Leading Observer, October 15, 2025, 07:49:01 AM
Arm one with several 30mm cannon and name it the Westland Walloper.  :wacko:
Pegasus or Perseus would make the most sense for a radial-engined Whirlwind, in the time/weight limits.
Quote from: Weaver on October 30, 2025, 04:48:12 AMPegasus or Perseus would make the most sense for a radial-engined Whirlwind, in the time/weight limits.
Taurus is more likely being more powerful and of the exact same period as the Peregrine and the Whirlwind. While the Taurus II weighs 160lbs more than the Peregrine, it's a wash after you remove all of the liquid cooling stuff associated with Peregrine.
The F.9/37 with Taurus engines was larger than the Whirlwind yet the empty weight was only 518lbs greater.
Two Taurus II would give the Whirlwind 2,000+hp at take off compared to 1,530hp from two Peregrine.
The Beaufort and the Albacore used the
Taurus, a Beaufort kit could be the donor for a radial Whirlwind and in turn receive the Peregrine nacelles from the Whirlwind.
Quote from: jcf on October 30, 2025, 08:05:31 AMTaurus is more likely being more powerful and of the exact same period as the Peregrine and the Whirlwind. While the Taurus II weighs 160lbs more than the Peregrine, it's a wash after you remove all of the liquid cooling stuff associated with Peregrine.
The Beaufort and the Albacore used the Taurus, a Beaufort kit could be the donor for a radial Whirlwind and in turn receive the Peregrine nacelles from the Whirlwind.
Uh-oh! Now I'm getting "ideas", & forming "plans" involving smacking one of my Beaufort kits into my Whirlwind kit!  :banghead:  :banghead:  :mellow:
63cpe
Quote from: Old Wombat on October 30, 2025, 08:22:20 AM
Hey Hey, had the same plan....another is to have beaufighter wings-n-enginges involved.
David
perttime
Quote from: Rick Lowe on October 29, 2025, 09:39:29 PM
Quote from: Scotaidh on October 29, 2025, 12:04:14 PMHas anyone done a radial-engined Whirlwind?
As I've mentioned before, Dizzy has - IIRC he used Airfix Dinah nacelles, put a whacking great anti-tank cannon in the nose and tasked it for ground attack.
He may chime in with a link, otherwise it'll be on his Flickr feed somewhere.  :thumbsup:
I see he has done some Whirlwinds
https://www.flickr.com/photos/dizzyfugu/albums/72157654009737756/with/17423785479
Do one like that build from Dizzy but move the tailplanes down to fuselage and put it in Japanese markings. It'd probably cause a lot of confusion.
;D
