avatar_Supertom
Su-34MKI - at long last!
Started by Supertom, June 15, 2025, 03:28:16 PM
Supertom
This has been project that is a long time coming. It's the Italeri Su-34, with what-if Indian Air Force markings. I just didn't want to do it as-is, so I've been slowly putting the pieces together:
First, the kit:
Next, the bits. Photoetch bits to start. I've got some wingtip Khibiny pods from a Trumpeter Su-30 I'll be adding. The decals were slightly wetted when my basement flooded in 2019, I did a test and while the decals didn't slide off, it did lift off. I do have an extra set coming in though. I'll be adding other bits like extra bumps and antennas.
Finally, the pièce de résistance! I finally found a guy who 3D printed a Brahmos for me, with pylon. Unfortunately the pylon attachment bits are quite fragile and a little broke off. I'll cross that bridge later.
Currently, the photoetch is soaking overnight in some vinegar to etch them a bit. The cockpit detailing is getting scraped off in preparation for the PE.
Interestingly, this is the 4th time I've built this. My first attempt was in 1996 or so when the kit first came out, and I accidentally ruined the nose by putting too much Testor's white putty to secure the weight, which melted it. 2nd attempt was the prototype build, which took me 4 years to build as I had issue with matching the paint. 3rd build was my what-if PLAAF model, which has mysteriously disappeared. Admittedly, I love this kit.
Etching PE in vinegar's not something I've heard of before, could be a handy trick. Thanks Tom.
Sounds interesting. Nice find on the Brahmos.
Quote from: PR19_Kit on June 15, 2025, 11:44:55 PMEtching PE in vinegar's not something I've heard of before, could be a handy trick. Thanks Tom.
Vinegar can be quite useful for lots of things, other than putting on your chips. Smell can linger though
Supertom
Might not want to soak it in vinegar too long, though. It started to turn green! I'd say no more than 6 hours.
Accidental Loggie
Quote from: Supertom on June 16, 2025, 04:51:31 PMMight not want to soak it in vinegar too long, though. It started to turn green! I'd say no more than 6 hours.
I just saw this as the first entry on the top of the subject, and wondered what the Hell someone was soaking in vinegar long enough for it to turn green  :wacko:
Converte et subvertere
Supertom
Slow progress, as the hobby room/office is a little hot this time of the year due to the windows facing the morning and mid-afternoon sun, and the need to stay caught up with work:
PE cockpit pieces have been painted and attached. I've cut open the correct door shape (note to self - make a replacement door) and I'll need to start positioning the BrahMos plyon next before I can close the whole thing up.
Supertom
Supertom
A critical piece of this build is the BrahMos. It needs to be mounted accurately, or it will distract from the finished look. I made a mounting plate so that I would have a way to position the pylon, then realized it looked silly and I could just use that as a template to drill holes for the mounts, so that's what I'll do after I clean up the intake seams.
Supertom
Got the door glued on. I'm sure the aircrews would be more disciplined to close and latch the door, but I left the door ajar for some visual interest.
Supertom
First bits of major surgery: sawing off the wingtip plyons.
In place are Sorbtsiya L-004 ECM pods left over from a Trumpeter Su-30 kit.
Supertom
#13
At this point, everything moves quickly. The pods are glued on, then wings and tail stinger are attached, and a little PSR to blend the wings in. Extra bits will be attached before painting.
Quote from: Supertom on July 29, 2025, 11:33:36 PMGot the door glued on. I'm sure the aircrews would be more disciplined to close and latch the door, but I left the door ajar for some visual interest.
They won't have to worry about any pax barging in wanting to know if they're nearly there yet....................  ;D
