avatar_NARSES2
General Discussion
Started by NARSES2, June 14, 2025, 06:21:02 AM
perttime
A stock F-16 clearly doesn't go into "outer space" (above 100 km from Earth's surface). Surely an F-16 can be whiffed into something that does.
Steel Penguin
make the engine akin to the HOTOL one and have it in the nose of a Titan 2, surface to space interceptor, couple of big underwing missiles ?
Quote from: perttime on June 19, 2025, 11:56:23 AMA stock F-16 clearly doesn't go into "outer space" (above 100 km from Earth's surface). Surely an F-16 can be whiffed into something that does.
It can be indeed. The X-15B would have been modified structuraly to do so. IRL the F-16 would need vast changes to do so, but its possible in whiffworld.
Quote from: zenrat on June 19, 2025, 03:46:34 AMAnd there's your blown Hemi.  In order to thoroughly test the running gear of a proposed Moon Buggy a prototype was equipped with an engine so it could be run up and down a (1/4 mile long) test track...
A 1/4 mile? That's a handy distance, not to long, not too short, just right in fact.  ;D
Quote from: PR19_Kit on June 19, 2025, 01:03:59 PM
In the luna rover scientific test laboratory  circles the 1/4 mile is called the Goldilocks distance  ;)  ;D
We've had the discussion and Chris's ammendment to the rules is good to go.  :thumbsup:
I've had an idea for a secret alien group stealing aircraft from different boneyards around the world and modifying them into space fighters or scout ships for their conflict with another race. Keep the cockpit, insert or attach an alien engine, strip the wings down to the spars and attach alien weapons. Of course this sounds pretty sci fi so maybe not in this GB. I'm just throwing it out there for discussion.
Also I saw a pic of an A-4 Skyhawk painted in a space shuttle pattern. Could be a "research vehicle"!
Pics
Kerbal space program
It's not the pic I was thinking of as that was a straight Skyhawk with the tiles and other shuttle details added. Of course I can't find it right now.
Just need some clarification on the atmosphere thingy from the Mods on that ...are moons with an atmosphere good to go ??
Cause if they are I've a build in mind from a book i I had when I was a kid ..it was a two book series on space craft ...one was about the military side of Earth's forces and the other was about the craft used ..both human and alien.
In one picture was this crashed figther of sorts..propeller driven and the pic shows the crew escaping with these fecking great worm things in the background about to attack.
That plane is the basis for the build and I want to base it from either a Mk24 Spitfire or a Spiteful....or both combined 🤔 😀
Believe it or not I found the damn books ..easy as pie 😆 🤣
It's called Spacecraft 2000 to 2100..TTA or Terrain Trade Authority and the military one is the TDA or TDF
It's seems there's like 4 of these books all written by Stewart Cowley and I was thinking I'd love to get these 2 books I had again..then I saw the prices ppl want for wm  :o  :o
$83 US to over $125US 😳
Sooo maybe not. 😆
Quote from: Wardukw on June 20, 2025, 01:03:47 PMJust need some clarification on the atmosphere thingy from the Mods on that ...are moons with an atmosphere good to go ??
The Mods have decided that no propeller powered aircraft are allowed but a heavily modified jet on the other hand is permitted in the form of a spaceplane.
Quote from: McColm on June 20, 2025, 03:53:03 PM
yeah ok then ,, im out of this one .
This is probably the image you're thinking of Phil. Looks 109ish.You cannot view this attachment.
Quote from: jcf on June 21, 2025, 12:41:59 AMThis is probably the image you're thinking of Phil. Looks 109ish.You cannot view this attachment.
Yep Jon ..that's it ...and after a wee bit of hunting I was able to get all four books as PDF downloads ..which I liked 👍
