Main Menu
avatar_kitbasher
Thunderscreech - ish!
Started by kitbasher, June 06, 2025, 11:58:34 PM
The 'Essence of Thunderscreech' that surely has Dave, but with a prop it'll look the BUSINESS, specially if it's a square tipped contra-prop.  ;D
Quote from: PR19_Kit on June 10, 2025, 01:48:42 PMThe 'Essence of Thunderscreech' that surely has Dave, but with a prop it'll look the BUSINESS, specially if it's a square tipped contra-prop.  ;D
Cheers, Kit.
I haven't got any decent spare Firestreaks anyway (other than by robbing an Airfix Lightning, which I'll not do).
So props it is, then.  Not sure about contraprops though, but will give the suggestion some thought, Kit.
And I think it will indeed be called the Folland 'Foghorn' - the backstory will explain more.
Folland Tufnel because it goes up to 11.
Spino
Had to re-read through all these messages because for a second I thought you were going to scratch up some Firestreaks to go on this thing.  Sensitive 1950s missile electronics combined with a supersonic prop?  The effectiveness of that is highly suspect  :lol:
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
It most definitely has a Screech flavour..really nice work fettling that together
perttime
Definitely props. Something with wide blades, cut down for ground clearance if necessary.
Quote from: perttime on June 10, 2025, 10:30:27 PMDefinitely props. Something with wide blades, cut down for ground clearance if necessary.
Prop will use cut down 1/48 Airfix Hurricane blades.  Before that, though, today is PSR Wednesday.
Wasn't the Foghorn a Farley FAA proposal?
 :unsure:
Spino
Quote from: zenrat on June 11, 2025, 05:23:40 AMWasn't the Foghorn a Farley FAA proposal?
 :unsure:
Foghorn?  If it's British then that's actually a rather fitting name for a turboprop like this.
Regards, Spino
That's looking good Dave  :thumbsup:  Must admit I had wondered about contra-proos, there's someting essenstially "British" about them to me for some reason  :rolleyes:
As for it's maker ? There's something about it that makes me think Blackburn. I think it's the wings and tail looking like something from a spruced up Buccaneer in my eyes ?
Quote from: jcf on June 10, 2025, 05:53:27 PMFolland Tufnel because it goes up to 11.
Too sleek for Blackburn, eccentric enough for Teddy Petter to have designed it.  And as he was at Folland at the time.....
Anyway, mucho application of wet and dry wet-and-dry paper of different grades this evening.  Pleased with the results, did need a little more filler here and there so that's on ready to be attacked tomorrow.
Still want to paint it an overall blue.  Study of colour pics of the Midge and Gnat prototypes suggest something between RAF Azure Blue and PRU Blue so a trip to the LHS to seek out a suitable acrylic paint is needed tomorrow.
As for contraprops, I know what you're all getting at.  Will compare the 'Foghorn' to my 'Screech plans and work out the feasibility.
No pics today as the build is pretty much the same as last night, only smoother!
Quote from: kitbasher on June 11, 2025, 01:41:53 PMStill want to paint it an overall blue.  Study of colour pics of the Midge and Gnat prototypes suggest something between RAF Azure Blue and PRU Blue so a trip to the LHS to seek out a suitable acrylic paint is needed tomorrow.
That's the frequently quoted 'Petter Blue', the same as I used on the Dalgety prototype for the Bad Ideas build. A lovely colour!  :wub:
'Petter Blue'; not sure I'm up for mixing paint for this GB, but let's see what a delve into the LHS throws up (or can be explained away in the backstory 😉).
perttime
Contraprops was a British thing at the time, and Folland did put one on the Fo.117 proposal with 2.500hp Centaurus. But you'll need handed prop blades if you want contraprops on this one.
