My stash just grew again 2025
Started by Martin H, December 31, 2024, 08:53:54 PM
Arrived today, the Tarangus 1/72 Saab J32B/E Lansen and the Airwaves PE set for 1/72 Fujimi A-7D/E kits.
George the Cat
Quote from: DogfighterZen on July 23, 2025, 06:40:16 PMArrived today, the Tarangus 1/72 Saab J32B/E Lansen and the Airwaves PE set for 1/72 Fujimi A-7D/E kits.
What is the kit like? How does it compare to the Heller kit I wonder?
Well, you probably know the Heller kit so, i'll just say that IMO, detail is better in all aspects.
Don't know about how accurate the shape and dimensions are and i've never built either kit so i can't comment on that... the Tarangus kit does seem to be a bit more complicated to build but that's expected as it is a more detailed kit. Still, there are some aspects that may deter one from getting it but this review covers everything and is a good help to decide which kit to buy. https://www.modellversium.de/kit/artikel.php?id=11159
I already had the Heller kit but i wanted another one for a different idea so i decided to buy this one to have both options at hand.
It's a lovely looking aeroplane, no matter which kit you have.  ;D
I really must build one of my Heller ones.........................
Quote from: PR19_Kit on July 24, 2025, 02:57:54 PMIt's a lovely looking aeroplane, no matter which kit you have.  ;D
Indeed, it's another beautiful Swedish machine and which kit anyone chooses to build is irrelevant.  :mellow:
The Lindberg 1/48 Draken is back in the shops...
As is:
1/144 Convair XAB-1 Beta 1 bomber
Atlantis 1/72 AH-56 Cheyenne
Revell 1/128 Early Warning Star & 1/56 Starfire
Lindberg 1/48 Pogo
Monogram 1/24 Red Baron Rod
You're welcome
Helping you spend your money faster than before!
Quote from: zenrat on July 20, 2025, 05:59:01 AMSo now that's sorted, what's the Stolly kit like?
Review video on the Stolly. He's going to build it for his channel too:
Just received direct from Blackdog
I only ordered the Buccaneer box with the intent of adding the radar to the P.1121, but looking at it, I may change my mind about that. The box of the detail set for the Tracker was a complete surprise. I have one in the stash, I believe, and it could do with the detail set if I have not got too far with it.
Steel Penguin
from Parabelleum in the Jewelry quater, in Birmingham
Gecko 1:35 PACV  patrol hovercraft,  the box ix bigger than i thought it would be.
Quote from: Steel Penguin on July 25, 2025, 06:12:25 AMfrom Parabelleum in the Jewelry quater, in Birmingham
It's BLOODY HUGE is what it is!  :o  ;D  ;D
Steel Penguin
its smaller than the Tamiya Brachiasur box,  and around the same as the Revell 1:48 Euro fighter or CH 53A box.
a goodly size, but not awe inspiringly massive like a Tamiya 1:350 Nimitz kit   :wacko:
Quote from: Steel Penguin on July 25, 2025, 06:12:25 AMGecko 1:35 PACV  patrol hovercraft,
I do like the look of that, even if the price is massive.  :thumbsup:
I wonder if I could convert one back into an SRN5, or even stretch one into an SRN6? (Getting TWO of them for the latter idea would a need a World Bank loan!)
Steel Penguin
i admit Kit it was the mentions on here that made me think of it, and then decide on that over, other choices.
the under piece is a skirt shaped box, that you attach outer  sections too to give it the air blown inflated look.  quite ingenious i think..    as for getting more than one,  that is a discussion between you, your plastic dealer, and you bank account,  and the discount you may be able to wrangle.
i will add that the box was a bit of a surprise in that the lid is the typical lift off style,  the model is contained within a corrugated card box, simeler to a top flap opening shoe / trainer box, witch is stronger than most and will hold things securely in the mean time
Quote from: Steel Penguin on July 26, 2025, 03:07:18 AM...the box was a bit of a surprise in that the lid is the typical lift off style,  the model is contained within a corrugated card box, simeler to a top flap opening shoe / trainer box, witch is stronger than most and will hold things securely in the mean time
I have Zvezda and ICM kits in similar boxes.  While secure they are awkward to work out of.  The top flap of the inner box gets in the way.
