My stash just grew again 2025
Started by Martin H, December 31, 2024, 08:53:54 PM
Quote from: Old Wombat on July 20, 2025, 08:19:00 AM
Quote from: zenrat on July 20, 2025, 05:59:01 AMSo now that's sorted, what's the Stolly kit like?
Just for you, Fred, I've removed one of the kits from its protective plastic bags.
1st up: The clear parts look fantastic! The clearest, smoothest plastic parts I can recall ever seeing. The wipers are moulded into the front windscreens, so a bit of care will be needed there. Weirdly the mesh over the exhausts is moulded as three clear parts - I can see where they were coming from but I'll probably use some PE mesh instead, but I won't make a definitive call on that until I begin the build sometime in the nebulous future.
2nd up: The plastic seems quite soft, but I haven't tried cutting it, yet, so don't quote me on it! It's also a bit greasy & I noticed some mould-release spots still liquid on the parts, so a thorough wash will be in order. Three parts had come off the sprues but they were all easily identifiable even before looking through the instructions to find the part numbers (C58, C59 & E12 = both water jets & a radio). Some detail looks a little soft, but nothing that will really scream out at you. There is (as there should be) zero flash but mould lines are present on most parts, however they're very minimal & should only take a quick swipe with a scraper/blade to remove.
3rd up: Without have tried to use them to put anything together, the instructions appear to be quite clear & easy to follow in the current Airfix style, with options call-outs for the three supplied-markings variants. The drive train looks to be the most complicated part of the build but, given the subject, I'm not surprised. Glazing is one of the last steps, as most of these parts are fitted externally.
Over all: Looks good in the box. Hopefully it goes together well, too.
 :thumbsup:  :thumbsup:
Thanks mate.
Quote from: Weaver on July 22, 2025, 01:47:13 AMI'm just here practicing the not-at-all-smug sympathetic noises when it turns out to be nightmare to build... :angel:  :angel:  :angel:
Hehehehe, quite so, there's a lot of flash on the sprues so I'm expecting some fit issues. But then we're Whiffers, and that's meat and veg for us of course.  ;D
Quote from: PR19_Kit on July 21, 2025, 12:54:00 PMGot back to my 'country home' today to see a BIG parcel from the Big H containing this..........
The rear end of the shuttle part of that contraption has an almost Thomas the Tank Engine look about it  :unsure:
Quote from: NARSES2 on July 22, 2025, 05:20:18 AMThe rear end of the shuttle part of that contraption has an almost Thomas the Tank Engine look about it  :unsure:
Should I paint it like that?  ;D
Quote from: PR19_Kit on July 22, 2025, 05:29:26 AM
Why not  ;)
Quote from: NARSES2 on July 22, 2025, 05:31:38 AM
Why not  ;)
In which case the blue plastic will help.   ;D
George the Cat
Why not? Red, green or blue?
Quote from: George the Cat on July 22, 2025, 06:30:53 AMWhy not? Red, green or blue?
If it's painted at Thomas it HAS to blue, but his face is white, with added eyes and grin.....................
George the Cat
Quote from: PR19_Kit on July 22, 2025, 06:32:11 AM
James and Henry are worth a look in. Hence my reference to colours.
According to Fantastic Plastic's build, it's supposed to be a sort of French blue:
More pics: https://fantastic-plastic.com/convair-space-shuttle-by-revell.html
I decided i needed to cheer myself up and see if i can find some deals on trademe .
Since im in here now its pretty easy to guess that deals were found  ;D
So now i have two more goodies to add to the stash ...i scored these two ..
Kitty Hawk | No. KH80135  XF5U-1 "Flying Flapjack" | 1:48
And this monster ..
Trumpeter | No. 00378 German Geschutzwagen Tiger fur 17cm Kanone 72 (Sf)  | 1:35
Its been a good day gents  :thumbsup:
Now i've got to hunt down 2 sets of Tamiya king Tiger track sets as the tracks that thing comes one are rubber band type and total crap .
Didn't think I'd see a Flapjack in 1/48... there again, it's added to the long list of such things that are now available...
Phill, haven't you just converted one of those? There again, a 'big-donkey' German chassis is always of use...  ;D  :thumbsup:
Quote from: Rick Lowe on July 22, 2025, 10:20:02 PMDidn't think I'd see a Flapjack in 1/48... there again, it's added to the long list of such things that are now available...
When i saw the flapjack in 48th and its the one i like too it was only a matter of time before i would convince myself i wanted that ...as you might have guessed ,,that didnt take to long at all ,,,and yep ,,i'm going to modify it too  ;)
As for the monster ,,,not this one matey ,,i took a standard King Tiger and played with that ...this thing has a few more road wheels pur side and much longer tracks ,,it was a stupid idea all in all ,,take a 170mm gun ,,take it to its firing position,,drop it off ,,and drive away so it can do that bang bang thing and then pick it up ,,,not a single thought about counter battery fire or  Allied air power crossed their minds i think  :banghead:  :wacko:
Quote from: Weaver on July 22, 2025, 05:39:30 PMAccording to Fantastic Plastic's build, it's supposed to be a sort of French blue:
That looks a lot better blue than the one it's moulded in for sure!
It's quite a clever kit, and it all comes apart into various sections, all of which are 'stand alones' in their own right.  :thumbsup:
Received from the BIG yellow H
1 x 1/72 Airfix A06024 Boeing Chinook HC.1(LATE)
1 x 1/?? CMK/Czech Master Kits CMK010 Clear Navigation Lights
1 x 1/?? CMK/Czech Master Kits CMK011 Red Navigation Lights
1 x 1/72 Transport Wings TWC72060 AN/ASQ-236 Dragon's Eye Radar Pod. Two in the packet.
1 x 1/72 & 1/144 Mark1 Decals DMS01 RAF/FAA Stencils Pt.1
1 x 1/72 Mark1 Decals DMK7213 Indian AF insignia dia. 18", 24", 36" & 54" 2 Sets. Ashoka Chakra, post-1947 and post-1950s roundel.
