My stash just grew again 2025
Started by Martin H, December 31, 2024, 08:53:54 PM
Two Revell 1/72 kits, found for a very reasonable price at a tiny museum at Gwilli steam railway while holidaying in Wales. They'll probably be parts donors, although the E.555 is a fairly simple but striking kit for its size so I'm tempted to build it almost oob.
Arado E.555
Mistel 5, He.162 and Arado E.367a (ex Dragon)
George the Cat
#1006
Quote from: Mossie on July 30, 2025, 06:23:30 AMTwo Revell 1/72 kits, found for a very reasonable price at a tiny museum at Gwilli steam railway while holidaying in Wales. They'll probably be parts donors, although the E.555 is a fairly simple but striking kit for its size so I'm tempted to build it almost oob.
Arado E.555
Ah the old Dragon kit. The 'warhead' section is worth considering if a manned version would work.
The E555 is a very impressive kit. I did one in USAAF markings years ago but it did not survive.
frank2056
The Ar E.555 is worth building just for the enjoyment of a fine fitting kit. Great whiff fodder as well. The Dragon kit is very old and IIRC, the fit of the He 162 wasn't great and my kit had a strange smoke colored clear canopy. The E.377 does have potential!
Nice find Mossie - I didn't even know that Mistel kit existed. :thumbsup:
I've got two of the Ar 555, the intention being to finish one of them with the decals from one of my two Motorhead He 111s.
Quote from: George the Cat on July 30, 2025, 07:23:03 AMAh the old Dragon kit. The 'warhead' section is worth considering if a manned version would work.
Quote from: frank2056 on July 30, 2025, 08:41:57 AMThe Ar E.555 is worth building just for the enjoyment of a fine fitting kit. Great whiff fodder as well. The Dragon kit is very old and IIRC, the fit of the He 162 wasn't great and my kit had a strange smoke colored clear canopy. The E.377 does have potential!
Quote from: Weaver on July 30, 2025, 09:25:06 AMNice find Mossie - I didn't even know that Mistel kit existed. :thumbsup:
The mistel warhead is definitely convertible, its roughly 14cm/10m in 1/72 so a similar length to a Me-262. The He-162 looks good in the box, there's some nice engine detail. Fingers crossed on that one.
I'm wondering about the E.555, looks lovely. I could bash it into something rocket shippy, or I often think of putting Luft '46 in captured markings. Maybe fair over the turret and create a recce version. Motorhead decals will look good. :thumbsup:  :thumbsup:
OK looking at the Arado E.555 gave me an idea right from the get go which hasn't happened in a while...and of course now I can't find one here and which is more annoying is they ain't that much money either 😒
Thinking a single seater in 48th which twin jet engines and the kits big enough for it .🤔
If I can bloody find one  :banghead:
frank2056
Phill - Renax Sharkit changed it to a twin engine design and he may have rescaled it to 1/48: https://renax-sharkit.blogspot.com/2009/12/virulan-long-range-heavy-fighter.html
killnoizer
This kit from East Germany is 50 years old.
And in scale 1:100 it is also 50 cm long ( 20" )
Wing span is a bit more.
And a sweet Me 262 with the same age...
                     ~ π ~
VDPM Hannover / Germany
Charlie_c67
Is that a Playfix Bear? I've got their Trident which is going to have a bit of a scal-o-rama going on when I get my brain in gear.
Quote from: Charlie_c67 on July 30, 2025, 03:21:57 PMIs that a Playfix Bear? I've got their Trident which is going to have a bit of a scal-o-rama going on when I get my brain in gear.
Sort of.
It was originally by VEB from East Germany, as was your Trident, but the moulds got shared around a lot and the kits appeared under many names.
Quote from: frank2056 on July 30, 2025, 02:45:42 PMPhill - Renax Sharkit changed it to a twin engine design and he may have rescaled it to 1/48: https://renax-sharkit.blogspot.com/2009/12/virulan-long-range-heavy-fighter.html
Frank mate thats very cool,,,its looks like he just took the original cockpit and modded that ,,,what i have in mind is a total replacement  of the cockpit  with a single seat ,,ME-262 type of deal but i do like his idea for the engines tho ,,,that does look pretty sweet and far more modern than what i had in mind  ;D
Quote from: Weaver on July 29, 2025, 11:59:26 PM
Quote from: Rick Lowe on July 29, 2025, 10:12:24 PM
Quote from: Weaver on July 28, 2025, 03:10:23 AM
Quote from: Rick Lowe on July 27, 2025, 10:45:43 PM"Let the Wookie win!"
Or he'll feed you through the lift fan, grenades and all...
Or kick you into the Spaceships' engine intake...  ;)
"Captain Hairy Pants" rather than "Captain Tight Pants"? The crossover we didn't know we needed.
***Write it... :wacko:  :wacko:  :wacko:
That's the reference!  :thumbsup:
*** Sadly not in my skill set, but there's bound to be one out there already - either on ArchiveOfOurOwn or Fanfiction.net...
Or maybe it should just be 'The Crossover We Didn't Need...'  ;D
Quote from: Wardukw on July 30, 2025, 01:29:19 PMOK looking at the Arado E.555 gave me an idea right from the get go which hasn't happened in a while...and of course now I can't find one here and which is more annoying is they ain't that much money either 😒
This idea has been floating around in my head for nigh-on a decade (about as long as I've had my Ar (E) 555 in my stash).
Generally I've been looking at my Tamiya F4D-1 Skyray as a fuselage donor, & have thought of buying another to give me two engines but they're showing as "Discontinued" on several sites - so that's unlikely.
So, lately, I've been upgrading to a 2-seater with either a Tornado or, more likely, F-111 fuselage.
This is nice thinking! Giving the Arado 555 an entirely new nose and some more modern engines will produce a rather different aircraft. Hmmmmm......
#1019
Quote from: Old Wombat on July 31, 2025, 12:43:34 AM
Those are sweet ideas mate ...the two seater is a different one of sure and definitely make for a very different look to that plane  :thumbsup:  ;D
Quote from: Pellson on July 31, 2025, 05:34:35 AMThis is nice thinking! Giving the Arado 555 an entirely new nose and some more modern engines will produce a rather different aircraft. Hmmmmm......
Yeah you can see what I mean ...it's already got the wings ..which look cool unto themselves but fit it with intakes ..in my brain a single seat cockpit..a couple of after burners poking out the back ...if ya got the canopy right man that thing would looked wicked bud  ;D
