Author Topic: HAWKER P.1032 EAGLE FURY  (Read 21310 times)
0 Members and 2 Guests are viewing this topic.
Offline kitbasher
  • What-IF SIG
  • bashes kits
« on: May 30, 2016, 12:25:24 pm »
OK there's several P.1027s (including my own) on this forum, and the P.1030 has been kitted by Unicraft, but there are no known drawings of the P.1032.  This was a RR Eagle-engined Sea Fury, and my take on what it may have look like will start the day after tomorrow.
On the go: Arrow, Beaumaris, Battle, Bronco GA.1, Barracuda II, CASA 2.217, Corsair GR.1, EE P12, Hawker P1067, Hellcat IV, Ice Cream Tank, JP T4, Jumo MiG-15, Macchi MC.205, Phantom FG1, Puffin, Sea Hawk T7, Spitfire XII, Ta154, Val.
Offline Gondor
  • What-IF SIG
Re: HAWKER P.1032 EAGLE FURY
« Reply #1 on: May 30, 2016, 02:04:06 pm »
That's a P.1026 fitted with a Eagle to F.2/43 at least going by the information in BSP Fighters and Bombers 1935-1950
EDIT: Just found out that the P.1026 is the Fury which became the Sea Fury  :banghead:
« Last Edit: May 30, 2016, 02:24:32 pm by Gondor »
Offline Captain Canada
« Reply #2 on: May 31, 2016, 09:03:16 am »
Excellent ! Can't wait to see this one come together.
Offline kitbasher
  • What-IF SIG
  • bashes kits
« Reply #3 on: June 02, 2016, 01:20:12 am »
A bit of rhinoplasty last night, a bit more chopping tonight and then the fun begins.  Pics at the weekend.
Offline kitbasher
  • What-IF SIG
  • bashes kits
« Reply #4 on: June 05, 2016, 09:42:56 am »
Here' the first pics of the 1032, based on a long in the stash Premiere2 Sea Fury plus a Falcon canopy, Aeroclub main undercarriage, and some resin (again from some years ago) mostly via OGL but also one item from The Wooksta:
Since these were taken I've assembled the wings and built up some sidewalls for the cockpit.  I might add a bit more detail to the cockpit, certainly an instrument panel and control column.
Offline The Wooksta!
  • Resident Soup Dragon
  • What-IF SIG
  • Would you risk it for a chocolate biscuit?
« Reply #5 on: June 05, 2016, 10:23:10 am »
Dave, the cockpit as provided is definitely wrong - the rear bulkhead is about 2mm too far back.  It should align with an external panel line about 6mm aft of the windscreen.
"Please dial *617 at this time"
"Now then, Butch Harry. Tell us about Fulham."
"An inaccurate parcel of dog turds!"
www.whatifmodelers.com/index.php/topic,34762.0.ht
Offline kitbasher
  • What-IF SIG
  • bashes kits
« Reply #6 on: June 05, 2016, 12:00:27 pm »
Thanks Lee
  • What-IF SIG
« Reply #7 on: June 05, 2016, 12:32:41 pm »
You'll also need to build up the rear fuselage decking - it looks more like a Tempest.  Aeroclub did a replacement canopy with a white metal insert for that area.  Wheels are best replaced with Tempest ones.  The resin leading edge radiators (I assume they're from me) will need some considerable trimming to fit - I've a yet unfinished Furious with l/e rads and they did need a lot of trimming.
You're too late to sand down the trailing edges as they're really thick.  May have a spare wing somewhere.
Best of luck with this as it's one I'd planned but shelved.  May still have a bash at some point, possibly with a Trumpeter one.
« Last Edit: June 05, 2016, 12:34:26 pm by The Wooksta! »
Offline kitbasher
  • What-IF SIG
  • bashes kits
« Reply #8 on: June 05, 2016, 01:12:59 pm »
Yep, got the decking. And yep fell foul - in my haste - of the trailing edges.
Next Haker Hypertheticals after this will be a P1009, a P1030 and finishing off a P1067.
  • What-IF SIG
« Reply #9 on: June 05, 2016, 01:58:27 pm »
I may have a look at the P.1030 at some point in August.  I have the requisite parts and donor kits.  Just want to clear the decks of Spitfires - at least, the assembly to the priming stage - first.
Offline Gondor
  • What-IF SIG
« Reply #10 on: June 05, 2016, 02:09:46 pm »
I'm still looking for exhausts to enable me to build the P.1030 myself Lee
Offline alfavega
  • Out of the Whiffing Closet
Offline kitnut617
« Reply #12 on: June 05, 2016, 02:21:33 pm »
Yeah!, got that drawing from the Brooklands Museum and built my P-1027 from it, check out Gondor's Grumblings, reply #603.
http://www.whatifmodelers.com/index.php/topic,36955.msg729100.html#msg729100
  • What-IF SIG
« Reply #13 on: June 05, 2016, 02:22:29 pm »
That's the Eagle Tempest - do a search on here as several UK based forum members have done several.
Alistair, I might have a mould for the exhausts somewhere.  I'll have a look.
« Last Edit: June 05, 2016, 02:39:11 pm by The Wooksta! »
Offline Gondor
  • What-IF SIG
« Reply #14 on: June 05, 2016, 03:48:53 pm »
Thanks Lee, much appreciated  :thumbsup: Would you happen to have a couple of the leading edge radiators from the Typhoon II/Tempest I spare as well would you?
« Last Edit: June 05, 2016, 04:25:47 pm by Gondor »
