Steel Penguins braying
Started by Steel Penguin, June 22, 2013, 01:55:36 PM
Steel Penguin
all cut up and it works  :thumbsup:   so thats that project done for now ( its a wargames army, it never finished, you can always add a new unit or 2, or upgrade the base to the better  looking ones your doing now... )
so ive started a new build
Aoshima  1:24 cyber formula racer sugo super asurada  AKF - 11
https://www.google.com/search?q=aoshima+akf-11&sca_esv=c2df872898b90107&hl=en&source=hp&biw=1920&bih=937&ei=nTOFaMTDK4-AhbIPkJDliQ4&iflsig=AOw8s4IAAAAAaIVBrRmEK-FuOEjmqnffPlwyRJlIIlJk&oq=aoshima+akf+%60%60&gs_lp=EgNpbWciDmFvc2hpbWEgYWtmIGBgKgIIADIEEAAYHkjFlgFQAFiuiAFwAXgAkAEAmAFBoAH-BqoBAjE1uAEByAEA-AEBigILZ3dzLXdpei1pbWeYAhCgAu0HwgILEAAYgAQYsQMYgwHCAggQABiABBixA8ICDhAAGIAEGLEDGIMBGIoFwgIFEAAYgATCAg0QABiABBixAxiKBRgKwgIHEAAYgAQYCsICChAAGIAEGLEDGArCAgYQABgIGB6YAwCSBwIxNqAHvDWyBwIxNbgH4wfCBwcxLjcuMi42yAdg&sclient=img&udm=2
 admittedly i got mine cheap second hand and without the canopy, so im going to build it and then see if i can use an old kit canopy or possibly a piece of clear packaging, or possibly just go for the small canopy's that modern F1 cars have as opposed to the kits full length fighter style one.
it will be fun to build without worry and i can paint as i wish, and add any decals from the stash as well.
Something like a large-scale F-16 or -18 two-seat canopy looks close.
You'll enjoy that mate.  Any figures with it?  They often come with a driver or a standing figure.
Steel Penguin
Quote from: zenrat on July 27, 2025, 05:38:23 AMYou'll enjoy that mate.  Any figures with it?  They often come with a driver or a standing figure.
Fred, alas nope, there isnt any mention of one on the sprue map either, possibly its one without  :unsure:   not a problem, i have a plesier ( sp?) 1:24 eve set ( somewhere) if i do want to do a figure with it,  or possibly re scale and go for a 1:35 scale, as ive a few of those i can re purpose as well.  :thumbsup:
They are anime figures so are out of proportion.  Maybe 1/24 legs with a 1/35 torso and a 1/24 head.
This is one of the kit figures - 1/24 vinyl (so paint & glue adhesion can be an issue).
Stormzender WIP 19-9-17 by Fred Maillardet, on Flickr
Steel Penguin
hhhmmm.  most certainly going to have to think then, my mad l33t 5k1ll5!!   ( spelt thus for maximum irony) arnt up tp that kind of mix and match i fear.  i can have a go after building the car though.  :thumbsup:
Steel Penguin
slowly progressing, and had to deploy something normally outside my comfort zone today,   :unsure:
the body has the cockpit section added from the underside, but i have painted the base of that Tamiya NATO black  including the sides, so to avoid a unsightly section of that amid the Ford ice diamond white of the rest of the body i decided to line in the floor in the black,  either its tape and hope, or the other option.
Time to break out my bow pen...
its been a long time since i needed to use one, and the one i have i inherited from my late father in law, but a couple of minutes to check its good and to remember how to use it, a quick pass on each side, and jobs a good un  :thumbsup:    then carefully crean up the pen, slacken off the jaws so it wont strain and carefully put back in the storage box..  and the side do look rather good if i say so myself.  ;D
Quote from: Steel Penguin on August 01, 2025, 12:05:08 PMTime to break out my bow pen...
I remember having a set of various types for GMD (geometrical & mechanical drawing) at school. Doubt if I ever used them and no idea where they are now.
Me and GMD never actually hit it off  :rolleyes:
Steel Penguin
Quote from: NARSES2 on August 02, 2025, 06:13:06 AM
i was told i didnt have the aptitude for technical drawing ...   considering we had done nothing of a similar nature before this utterance, i will go no further,  but i have learnt to use technical drawing pans ( care and cleaning of) since and still have my 30 ish year old Rotering in a usable condition, and its a useful tool to aid the painting and detailing process.   It is a case of adapt and utilise any suitable tool, and when i do get the best i can afford, and look after it properly after...  <_<
Quote from: Steel Penguin on August 02, 2025, 08:08:40 AMand look after it properly after...  <_<
And therein lies the Learning Curve... most of which of mine tend to be Parabolic m- or Ballistic, one or the other; but usually resulting in something that shows neglect and lack of care...  :banghead:
Quote from: Steel Penguin on August 02, 2025, 08:08:40 AMi was told i didnt have the aptitude for technical drawing ...
I recently found an old school report my mum had kept from the 2nd year of senior school, so I was 12/13. My GMD master had written in bold green ink - " Christopher has no aptitude, nor liking for GMD and tends to spend the entire lesson attempting to keep the rest of the class amused. Which he is very good at"
I'm quite proud of that  ;D [/quote]
Steel Penguin
Quote from: Rick Lowe on August 02, 2025, 08:11:28 PM
i admit its one reason i use the old hairy stick for paint,  i got a cheap revel airbush to try, and realised even that took multiple times the length of spraying a single model  / coat to clean and a more expensive one would-ant take less time, but certain as certain would be a power more expensive to repair...  :banghead:     the only problem  / colour would be something like airliner / anti flash white.... i get round that by using a spray can to undercoat / main coat....
Quote from: Steel Penguin on August 03, 2025, 03:48:24 AMi admit its one reason i use the old hairy stick for paint,  i got a cheap revel airbush to try, and realised even that took multiple times the length of spraying a single model  / coat to clean and a more expensive one would-ant take less time, but certain as certain would be a power more expensive to repair...  :banghead:     the only problem  / colour would be something like airliner / anti flash white.... i get round that by using a spray can to undercoat / main coat....
My reasoning EXACTLY!   :thumbsup:
Seriously?  :o
On average it takes me about 5 minutes to clean my airbrush after each use.
I only pull it apart & thoroughly clean it about once, occasionally twice, a year.
But, then, I generally only use Tamiya acrylics & SMS (& Testors, while they existed) lacquers through it, both of which clean up extremely easily.
I've only ever had to break that system when I've used enamels (Humbrol) or more water-based acrylics (Life Color, AK, Vallejo) through it - they have all lead to completely gummed up workings & the need to pull it apart & sanitise it of their sticky residues.
