avatar_Dizzyfugu
DONE @ p.6 +++ 1:72 N. A. EA-5D „(Electric) Vigilante”
Started by Dizzyfugu, February 17, 2026, 11:35:28 PM
This what-if project had been lingering for a long time in the back of my mind, and I shoved it a side for years because of the model's sheer size that eats up a lot of display space – even though I had the hardware already stashed away, collecting dust. While the build was rather inspired by its livery (see below) I wondered why the Vigilante, an elegant and impressive aircraft, had not been adapted to the ECM role? The concept of a supersonic penetrator/protector aircraft was realized by the USAF with the EF-111A Raven, but in the Vigilante's time frame, the Vietnam War, esp. its end phase, an escort for fast USN attack aircraft might have made sense, so that I tried to mate the RA-5C with contemporary ECM technology and typical details – and the result became the fictional EA-5D.
1:72 North American EA-5D ,,(Electric) Vigilante"; U.S. Navy VAQ-135 "Black Ravens"; NAS Whidbey Island  (Oak Harbor, Washington), 1985 (Whif/modified Trumpeter kit) - WiP
by Dizzyfugu, on Flickr
With this idea the model became only a conversion of a basic airframe, not a spectacular kitbashing. Since I knew the Hasegawa RA-5C and its underwhelming quality/detail, I settled for the Trumpeter kit – a MUCH better but also a bit über-complicated offering. It is, however, better in any respect, even though you can ask why the cockpit has to consist of no less than thirty (!) parts (including seats and dashboard films), and the pylons as well as even the thin stabilizers and the fin have to consist of halves? One can also wonder why the kit comes with four(!) free-fall nukes but none of the RA-5C's typical 400 gallon drop tanks? The kit features the type's underwing flare dispensers, though. If there is something to criticize it's the lack of air intake ducts – behind the wedge-shaped intakes and their ramps there is nothing inside the fuselage. Since I did not want to put too much effort into that flaw I simple blocked sight into the model's body with a bulkhead made from black foamed styrene.
Everything goes together quite well, except for the fuselage halves which appear somewhat warped, and the rather massive plastic makes work easy. Despite this splendor of material, the sandwich leading and trailing edges are surprisingly thin and look pretty good.
Quote from: kitbasher on February 18, 2026, 01:54:27 AMAn alternative to the EA-6A, then?
Yes, somewhat - at least with the same technology on board. Heavy metal. :mellow:
HarryPhishnuts
Quote from: Dizzyfugu on February 18, 2026, 07:06:51 AMEsp. the first pic creates a sudden urge to add delta wings and twin fins, for a kind of "Baby XB-70"?
Or leave the single vertical stabilizer and you start looking like a F-108 if you squint hard enough  :o
No Matter Where You Go, There You Are - Buckaroo Banzai
Quote from: HarryPhishnuts on February 18, 2026, 08:47:11 AM
Agree!  ;D
At the moment nothing new to show, deep into PSRing the hull. Fit of the body halves is rather mediocre, and I try out parts and positions for some sensor bulges and a different ventral canoe fairing.
I try my best to make it look plausible.  <_<  But it's so HUGE...!
Again, not much more to show, but progress is steady. Landing gear has been completed and is about to turn white, the new tail cone requires some more attention, and I am in the process of adding antennae/fairings to the hull. Dry-fitting of the clear parts and the stabilizers is also underway. However, major painting phase visible on the horizon.  :angel:
Quote from: Dizzyfugu on February 21, 2026, 11:55:34 PMAgain, not much more to show, but progress is steady. Landing gear has been completed and is about to turn white, the new tail cone requires some more attention, and I am in the process of adding antennae/fairings to the hull. Dry-fitting of the clear parts and the stabilizers is also underway. However, major painting phase visible on the horizon.  :angel:
looking good :thumbsup:
I've always thought the Vigi a VERY attractive aeroplane, very well proportioned and it looks like it's doing Mach 2 just SITTING there!  ;D
Yes, it's an elegant machine - esp. the sleeker A-5A and in the air with everything tucked up! But it's HUGE!  ;D
Detail work makes further progress, and I worked on the ordnance, too.
