avatar_Weaver
Laci Models
Started by Weaver, November 23, 2025, 07:24:48 AM
Laci Models in a British company that started in 2020, producing mainly resin flap and engine sets for airliner and transport kits (and a few combat types), but also a small range of resin kits including Flying Fleas and several gliders in a variety of scales. Some interesting stuff here:
Website: https://laci-ltd.uk/en/
Some random examples (lots more on the website):
Now if they did those RR Dart engines in 48th and not 144 i'd be very interested  :wacko:
And the propellers to go with em ,,even better  :thumbsup:
Charlie_c67
That Flea looks like either the ultimate in testing your patience or the quickest way to the looney bin!  :party:
Quote from: Wardukw on November 23, 2025, 11:50:38 AMNow if they did those RR Dart engines in 48th and not 144 i'd be very interested  :wacko:
They do them in 1/72nd: https://laci-ltd.uk/en/search?controller=search&s=dart
Quote from: Weaver on November 23, 2025, 02:03:26 PM
Ahhh ,, they didn't say that on the box ,,that LAC144015 number is what i looked at and with alot of manufactures out there you can get the scale by the first couple of numbers in the part number ...these guys clearly dont that is would seem  :lol:
Or they do but also in 72nd ,,but either way ,,to small ,,or maybe in 72nd they could work on a small 48th COIN type aircraft 🤔
Quote from: Wardukw on November 23, 2025, 02:12:47 PM
They do exactly that with the part numbers, it's just that there's a LOT more stuff on the website than the random selection I could put up.
They don't do any resin sets in 1/48th. These are the kits they do: https://laci-ltd.uk/en/65-kits-48
If they're 3D printed they may be able to do them in 1/48 if you request them.
One thing is for damn certain they do look very very nice in the pics ,,it does make me wonder just how big these are 72nd but i cant seem to find any measurements .
Quote from: Mossie on November 23, 2025, 03:25:17 PMIf they're 3D printed they may be able to do them in 1/48 if you request them.
Yeah that's an idea ,,, not sure at all how they would scale em up but it might be worth an ask  ;D
Well an RR Dart RDa.7 (Mk.520) is 2480mm long in real life, so in 1/72nd scale it'd be about 34.5mm.
Quote from: Weaver on November 23, 2025, 07:24:48 AMLaci Models in a British company that started in 2020, producing mainly resin flap and engine sets for airliner and transport kits (and a few combat types), but also a small range of resin kits including Flying Fleas and several gliders in a variety of scales. Some interesting stuff here:
I saw one of these at Telford and I'm still having sleepless nights thinking about its construction  :o  ;D
Quote from: NARSES2 on November 24, 2025, 01:56:47 AMI saw one of these at Telford and I'm still having sleepless nights thinking about its construction  :o  ;D
There's surprisingly few parts to them. This is the "scary" skeletal one:
It strikes me that the biggest challenge is cutting all the 3D printing supports off without breaking it:
Those struts will be problematic. Hot scalpel should do the trick, or replace them with fine brass rod or stretched sprue.
I must admit I'm tempted, I've always been intrigued by the Flying Flea. Might be less masochistic than Brengun's 1/144 kit.
Quote from: Mossie on November 24, 2025, 04:35:33 AMThose struts will be problematic. Hot scalpel should do the trick, or replace them with fine brass rod or stretched sprue.
Yes I was thinking that brass rod might be easier too. Then there's the rigging, which has always terrified me... :o
There's a 1/48th version of the Flying Flea that's only a couple of quid dearer and probably less eye-breaking:
https://laci-ltd.uk/en/kits-48/228-mignet-flying-flea-g-aeeh-48.html
(Includes pics of a built-up example)
I've not dare attempt rigging yet. Should bite the bullet.  :-\
Randomly, I worked out human hair is the correct scale thickness for rigging at 1/72 and curling cream should help tighten it up. Not weird or anything...  :angel:
Quote from: Weaver on November 24, 2025, 02:18:54 AMThere's surprisingly few parts to them. This is the "scary" skeletal one:
That's remarkably like the late lamented Renwall Aeroskin kits, recently mentioned on here too IIRC.
