avatar_NARSES2
SMW (Telford) 2025
Started by NARSES2, September 11, 2025, 01:00:11 AM
Quote from: Weaver on November 11, 2025, 11:25:57 AM...The one that hurt: AZ Gotha P.60 C-6 (the sensible one with both engine pods on top instead of one above, one below, the latter's FOD scoop being right behind the nosewheel). I saw it on the Sunday, when I'd said I was ONLY buying decals, bits and supplies. I didn't need it but I liked it. I put it down carefully and told myself that if it was still there when I passed the stand again I'd take that as a sign and buy it. It wasn't there...
Looking at the destructions here I think every boxing contains the same sprue meaning you can build any version from any boxing - only the box art and transfers differ.
<Edit.  Found a sprueshot.>
Quote from: Weaver on November 14, 2025, 01:05:32 AMThe Hunter nose is going on an airframe that's a whiff in other respects (F.4, basically) , so it doesn't matter if it's wrong or not. IIRC it's missing some windows, or something like that? If you can find the Airkit one I'll certainly buy it off you though, since I can't find a Quickboost one anyway.
IIRC I may have made a mould of it, which is probably easier to find than the Quickboost bit (although I think I've seen it recently...). I'll run one or two off when I get some more resin, probably in January.
Quote from: zenrat on November 14, 2025, 02:16:19 AMLooking at the destructions here I think every boxing contains the same sprue meaning you can build any version from any boxing - only the box art and transfers differ.
Would be standard AZ/KP practice
Cheers - that's interesting. :thumbsup:
Quote from: The Wooksta! on November 14, 2025, 04:26:46 AM
Okay well if you do, I'll definitely have one from you (swaps or cash, whatever you want). There's no rush either: it's a side project to a main timeline, so it's not holding anything up.
frank2056
The changes between the 2013-2015 AZ P.60s and the 2025 looks to be mostly part re-arrangement on the trees, some minor changes to the parts (closed main landing gear doors) and from the looks of the sprues shown, maybe an improvement in the molding. Compare the old instructions with the new ones.
Quote from: frank2056 on November 14, 2025, 07:14:29 PMThe changes between the 2013-2015 AZ P.60s and the 2025 looks to be mostly part re-arrangement on the trees, some minor changes to the parts (closed main landing gear doors) and from the looks of the sprues shown, maybe an improvement in the molding. Compare the old instructions with the new ones.
I built one of the origional mouldings, still have another in the stash, and the sprues/mouldings certainly look cleaner and sharper.
Nick
I'm looking ahead to next year and it seems likely that I won't be staying in the centre like I have the last 5 years.
Travelodge and Premier Inn are quoting me £500+ for 3 nights in a budget hotel.
My trip to Lisbon is only £440 with flights, parking, insurance and hotel with breakfast included.
I am looking around at other hotels which are offering much better rates even if it means paying a small fee for show parking.
Quote from: Nick on November 17, 2025, 06:41:52 AMI'm looking ahead to next year and it seems likely that I won't be staying in the centre like I have the last 5 years.
Don't park at the show, park in the shopping centre opposite.  It's pretty much the same price and I've found it's never totally full.   Other option is to find accommodation in , say, Shrewsbury and get the train in
Quote from: zenrat on November 14, 2025, 02:16:19 AM<Edit.  Found a sprueshot.>
A modern stealth aircraft should be easy to achieve from that model.
George the Cat
Quote from: Mossie on November 17, 2025, 07:25:53 AM
Early version of the A12?
Quote from: George the Cat on November 17, 2025, 07:45:22 AMEarly version of the A12?
I was thinking something more Northrop-Grumman, RQ-180, B-21 etc.
Quote from: Nick on November 17, 2025, 06:41:52 AMTravelodge and Premier Inn are quoting me £500+ for 3 nights in a budget hotel.
They're taking advantage. Pure, unadulterated greed. Yes, I know that's what 'capitalism' is meant to be about, but it's just going too far these days.  :banghead:
steelpillow
Quote from: Mossie on November 17, 2025, 07:25:53 AMA modern stealth aircraft should be easy to achieve from that model.
Main problem would be burying the engines: pods and stealth go together well do not.
It's a nice kit, if a touch basic. If you want to be faithful to the actual design then the upper/lower central pods and the blunt nose are the authentic options. In my stash for this very reason. The alternative options did appear, but on variants that also differed in more fundamental ways. Things like wheel options are fictitious, as the u/c was never designed in any detail. No harm in something for the spares box, though.
Cheers.
