avatar_Dizzyfugu
DONE @ p.8 +++ Saab J31B, Flygvapnet F1 Västmanland Flygflottilj, late Fifties
Started by Dizzyfugu, September 06, 2025, 02:56:47 AM
Quote from: Gondor on September 08, 2025, 09:46:02 AMI may have a BAC 1-11 that I could donate to the cause, if you're interested Dizzy.
Thanks a lot for the offer - I wait for the B-47 to arrive, I have high hopes in its wings, but will call if I need assiatance. Problem is that postage has become dizzyingly expensive, so that international parts/material exchange is severely hampered.  :-\
Besides, a few updates, even though not much hardware work has been done. First of all, a look into the WiP cockpit - seats are still on the work bench, and the dahsboard needs some fine tuning, but it looks comfy, esp. in the new greyish green. the white-on-black instruments date back from an older creative phase of mine, but I retained them, because they also match well with the Tornado dashboard style. And later, thorugh the canopy, things will hardly be recognizable, anyway.
1:72 SAAB J31B 'Val'; 'Blue T/Blå Tore (s/n 31014)' of the Swedish Air Force (Flygvapnet) F1 Västmanland Flygflottilj, 2nd Squadron; Hässlö AB, Västerås (Central Sweden), 1956 (What-if/kitbashing) - WiP
by Dizzyfugu, on Flickr
And there's a recent pic of the engine pods, after some serious PSR sessions:
"We get there", but until I have found suitable wings there will hardly be more progress. In the meantime I have been worring on the tandem landing gear, and this looks promising - forgot to take a WiP pic with the intended nose-up stance, but will post it later.
Hello, little news to show. First, the cockpit is about to be populated and closed. The crew consists of a pair of ugly vintage pilot figures that found a new home in the J31; only dry-fitted yet, they will receive a coat of matt varnish, too:
And here's a look at the intended stance on the ground:
Under the tail the cavity for the arrester hook has been PSRed away, gun ports have been drilled open, and I will add a ventral display adapter for eventual flight scenes later, too.
Good news! The vintage Revell B-47 kit arrived, and the gamble on its wings paid out! They are all I need, with the benefit that I will use/recycle their tips as stabilizers.  :lol:
Here's a look at the planned cuts to reduce span (someone pls. re-animate Kit at this point... :rolleyes: ) and sweep angle, and the planned place for the undersulng engines:
After trimming things down we got this, with a 20° sweep back.
With these, the wings' new shoulder position on the F3D fuselage could be defined - there will be cutouts to hold them:
Start of the next PSR mess: blending the nacelles under/into the swepts wings:
However, as can be expected, the detail and esp. the fit of the B-47 wing parts is ...poor. The whole upper surface had to be treated/levelled up with putty, the engraved lines for the flaps etc. is utterly soft and shallow, I think that I will also have to do some re-engraving work, at least for the ailerons, flaps and slats on the outer wing sections.  :unsure:  However, we are moving again, into the right direction.
Good heavens, I must have eaten  something that didn't suit me, I've just come over all faint..................  :-\
That's looking more and more Vautour-like in the wings as you go on Thomas.  :thumbsup:
Agreeing with Kit here. It's more and more looking like a side-by-side Vautour. That is however not necessarily a bad thing.
I've started looking more in depth at the Il-28 wings and engine pods, and how close they actually are to that jet B18 sketch. Basically, a Canberra B(I).8 fuselage, Il-28 wings and something unexpected in the back, and we'll be there. And I just might have all the parts needed.
Another project idea in the already too long queue, then..   :rolleyes:
Yes, it's like a fat Vautour, but only superficially. The initial Yak-25 a/w fighter is another "benchmark" - all from the same era, when engine and aerodynamic technology apparently dictated much of an aircraft's layout in this weight/size class.  ;)
Nothing new to show yet, PSR around the engines is still in progress.
Quote from: Dizzyfugu on September 12, 2025, 11:53:10 PMThe span appears a bit wide (Kit will probably like that?  ;) ), but I will leave it that way.
It's impossible to have the span '....a bit too wide......;!
Unfortunately not much progress here, despite some efforts. Mostly more PSR all over the hull before I might turn to details like land gear covers, the planned outrigger wheels under/in the engine pods, and underwing hardpoints plus drop tanks.
However, my dad is in hospital, serious issue. He had an intestinal operation and now even pneumonia, and this ...distracts.
Quote from: PR19_Kit on September 13, 2025, 12:59:31 PM
I'm tempted to try and build something to prove you wrong... :wacko:
Quote from: zenrat on September 16, 2025, 03:57:52 AM
You may convince the rest of us but you'll never shake Kit's Belief in his Faith!  ;D  ;D
Somewhere I have a 1/32 Revell kit of a Duo Discus sailplane (mainly because I flew one once.....) and that has some SERIOUSLY long wings! Specially if I use them to Whiff something else in 1/72.  :wacko:
Quote from: PR19_Kit on September 16, 2025, 05:09:22 AMSomewhere I have a 1/32 Revell kit of a Duo Discus sailplane (mainly because I flew one once.....) and that has some SERIOUSLY long wings! Specially if I use them to Whiff something else in 1/72.  :wacko:
A Wellesley?  :unsure:  ;)
