The Convair Shuttle B - 'Aquila' HL -LAUNCHED!
Started by PR19_Kit, August 01, 2025, 06:33:26 AM
I'm a dedicated hairy stick user, so I already use the Hataka Blue Line paints for brushes. IPA acts as a thinner for Hataka Blue Line stuff, and I use it as a 2nd stage brush cleaner, after water for the 1st stage.
Quote from: PR19_Kit on August 12, 2025, 10:08:37 AMI'm a dedicated hairy stick user, so I already use the Hataka Blue Line paints for brushes. IPA acts as a thinner for Hataka Blue Line stuff, and I use it as a 2nd stage brush cleaner, after water for the 1st stage.
So, if you're lucky, it won't effect the rattle-can white & you can clean the Hakata paints off with it.
Steel Penguin
Quote from: PR19_Kit on August 12, 2025, 10:02:24 AMHmm, yes, paint pens might work, and I've even got a black one right here too!
Great idea, thanks so much!  :thumbsup:
[Only a few minutes later] And it WORKS too!  :thumbsup:  :thumbsup:
egads!!!  i can be held up as a good example to my peers for a change...  :lol:
Itt Tell Mrs SP immediately, she will never believe me   :o  ;D
Quote from: PR19_Kit on August 12, 2025, 10:00:26 AM
Quote from: frank2056 on August 12, 2025, 08:47:31 AMYou can try masking, paint white over the tape, paint the lines then pull off the tape when the lines are dry.
That's exactly what I did, but even with the tape sealed with Klear, the paint crept under the edges.
Quote from: Weaver on August 12, 2025, 09:35:42 AMIs there a thickener or medium you can add to the acrylics to make them less prone to running?
If there is I don't know of such stuff. Anyone else know please?
I'd need s sort of negative thinner...................  :-\
Winsdor and Newton make products called things like "acrylic medium", but I have no idea about compatibility or how to use them.
The paint pen sounds like a great solution. I'll have to remember that one.
frank2056
I was going to suggest the AK Interactive pens... but don't want to sound like a shill.
And I use "Brush Magic" as a third stage cleaner for when a brush needs a real good deep clean. You have to be careful though as it will take the paint of the brush handle if left to long  ;D
Quote from: NARSES2 on August 13, 2025, 05:34:40 AMAnd I use "Brush Magic" as a third stage cleaner for when a brush needs a real good deep clean. You have to be careful though as it will take the paint of the brush handle if left to long  ;D
Yes, I tried that stuff once, and it not only took the paint off the brush handle, it took the glue out of the ferrule and the hairy bit fell right off! :(
I've still got the bottle of it at home, but I've not used it since.
Quote from: PR19_Kit on August 13, 2025, 06:02:35 AM
I put just enough in the jar to cover the lower part of the ferrule nowadays and then keep an eye on it. Wouldn't be without it  :thumbsup:
The Aquila's SRBs now have brass tube pegs to plug into the PSB and the First Stage. It was a bit of a fiddle to get them EXACTLY in the right place to match the already drills holes, but they fit nicely now.
I think I'll sand off the clamp ring paint and re-spray the whole thing white before doing the rings of both SRBs with Sharpies. I've also painted up the crew compartment of the 'glider', such as it is, and I may apply a wash of dark blue or similar over the crew members before sticking them in place.
I bit the bullet on sorting out the markings on the SRBs, and sanded ALL the old ring markings off. The I re-primed and re-sprayed both of them from top to bottom and I'll re-do the markings using the ink pen method.
They're probably 1/120 th scale now, with all that extra paint!  :o
I've got the five little crew dudes painted up and installed in the 'glider' now, so that's the top part of the Aquila all sorted.  :thumbsup:
The SRBs are a different story though. I've tried marling the sealing rings with a black Sharpie, but the pen seems to run out of steam after only drawing 1-2 rings and then just stops, despite still being able to write on paper. Very odd.
I'll get some different maker's pens and see how they work.
Funnily enough, another Convair-ish shuttle called Aquila has just crossed my Twitter ("X" :rolleyes: ) feed, this one done by an account called "Truthful". Apparently, it's made using his own modded parts for KSP.
https://x.com/Truthful_ast/status/1957404611515424875
https://x.com/Truthful_ast/status/1957415935238676802
https://x.com/Truthful_ast/status/1957408384686416056
https://x.com/Truthful_ast/status/1957412159614582850
Now that's REALLY weird! And it's almost the same shape as mine, but quite a bit larger.  :unsure:
