avatar_zenrat
Hobart's Hedge Trimmer - A Failed Funny. Finished Pics Pg. 11
Started by zenrat, March 09, 2025, 03:52:46 AM
Quote from: PR19_Kit on May 11, 2025, 06:00:36 AMI'm sure the recoil of that cannon set would act as a REALLY fast reverse gear!
Quote from: zenrat on May 11, 2025, 06:05:39 AMI suspect it would buckle the support frame - something else to include in the backstory.
I made it hefty but there is no cross bracing.
And probably flip it when firing broadside.
I have the odd pic of a Flakvierling mounted on a 2.5ton Opel truck ..that is definitely not a good idea 😕
A 5 ton..yep.. a 2.5 ton ..noooo
Quote from: Wardukw on May 12, 2025, 01:23:46 AMI have the odd pic of a Flakvierling mounted on a 2.5ton Opel truck ..that is definitely not a good idea 😕
How about a Flak 30 on the back of a Kettenkrad?
Quote from: zenrat on May 12, 2025, 04:11:46 AM
It's possible-ish  ;D
The max load of the Kettengrad is like 340 kgs and the Flak 30 weights 450kgs..but if ya went for a Flak 38 which is a lighter version of the same gun that kinda doable..that's weights in at 405kgs .
It would overstress that little machine for sure but you'd need to build a very light mount of the gun just to make it less stressed 😉
And this would need to be built as it would be FAF for certain  :thumbsup:  :wacko:
Quote from: Wardukw on May 12, 2025, 11:54:09 AM
Stick a fat tire on the front.
Quote from: jcf on May 12, 2025, 01:59:47 PM
Hahahaha 😆 😂
I like it !!! 👌
Transfers are in place.  Some silvering to deal with.   :banghead:
Quote from: zenrat on May 20, 2025, 05:14:56 AMTransfers are in place.  Some silvering to deal with.   :banghead:
Man they sound old  :o
I've got some decals ..Tamiya..Revell and so on which are so old they won't even separate from the backing paper anymore  ;D
The annoying thing is I can't throw wm out until after I try to use em because they still look perfect  :banghead:
I always scan all my decal sheets, new or old, so there's some chance of making copies if the originals all go TU.
These transfers were brand new.  Matt finish though, and there is a possibility the applier is at fault although I did  put down a couple of coats of Future before I put them on.
They'll be right.  Weathering can hide stuff.
Nearly there.  Disasters notwithstanding I might actually finish one without needing an extension for once...
Trimmer WIP 22-05-25 by Fred Maillardet, on Flickr
Joe CalPo
