My stash just grew again 2025
Started by Martin H, December 31, 2024, 08:53:54 PM
Quote from: zenrat on July 09, 2025, 04:07:29 AM
Quote from: Wardukw on July 09, 2025, 03:11:59 AM
Quote from: Weaver on July 09, 2025, 02:52:38 AM
Quote from: Wardukw on July 08, 2025, 07:59:53 PM
Quote from: NARSES2 on July 08, 2025, 05:10:39 AMFrom the Big H
Special Hobby 1/72 Fw 187A-0.
This is the "Vintage Treasure Edition". The moulds have been cleaned up, Quite a few 3D parts have been added and the instructions have been re-done. Looks good.
Thinking in terms of possibly making an anti-tank version of it armed with a 50mm at gun ? Maybe a single seater ?
50mm ?? ..not sure that would even get off the ground Chris..the HS-129 had much more powerful engines and even that wasn't happy .
The 50mm weighted over half a ton with a 2700mm barrel length 😳.
Now a 37mm would work with tungsten steel cored rounds ..the gun weights less than 300kgs complete .
I do like the single seat idea too..like a German Hornet  ;D
Not really:
Fw 187 A-0:
Engines: 2 × Junkers Jumo 210Ga V-12 producing 671hp each
Airframe weights:  Empty: 7,937lb, gross: 11,023lb
Hs 129 B-2:
Engines: 2 × Gnome-Rhône 14M-4/-5 radials producing 691hp each
Airframe weights:  Empty: 8,863lb, gross: 11,574lb
So the Hs 129 only had 40hp more than the Fw-187, for over 900lb more empty weight. The Hs 129 was always considered underpowered. In an ideal world it would have had 1500hp BMW 801s (there were plans), but the war situation meant they had to use the captured French engines as an expedient.
Yep that's true of course but when you take in the size of the 50mm gun ..it's really bad aerodynamics and you've got problems..the 1500hp Bemmer engines tho would have made it an entirely different ball game for the 187 for sure .
Now you can see what we just did Harold mate ?  ..we're gonna make Chris think about changing the 187's engines  :wacko:  ;D
The first prototypes were single seaters.
Tho I haven't looked I'll bet there'll be none of those in 48th scale cause I want one and id be very tempted to stuff Me-109E engines on it 🙃
Not really:
Fw 187 A-0:
Hs 129 B-2:
He'll be needing a Bf 110 to chop up for it's Db 601s.... :wacko:  :angel:
Delivered today... :mellow:
Quote from: DogfighterZen on June 30, 2025, 09:00:16 AMFrom the Polish Super Hobby store:
Hobby Boss 1/72 SU-47 Berkut
    "        "        "  Eurocopter Tiger HAP
    "        "        "  Westland Lynx Mk. 90
Academy 1/72 F-15C ANG
Dream Model 1/72 AH-1Z Viper
Brengun 1/72 AN/ALE-39/47 US flares
Firma49 1/72 APH-6D flight helmet 3D printed set
Eduard 1/48 Mask set for the Hobby Boss A-7 kits
Kelik 1/48 3D cockpit decals for Hobby Boss A-7A kit
Quote from: Weaver on July 09, 2025, 01:24:21 PM
Not really:
Fw 187 A-0:
Hs 129 B-2:
Hahahaha ,,yep ,,evil thoughts do have a way of making our hobby more expensive/annoying   ;D  ;D
Especially from blokes like us  :wacko:
Received today;
From BNA Models:
3 x ITA* 1/35 British WW2 Number 11 Radios (ITA335018)
3 x ITA* 1/35 British WW2 Number 19 Radios (ITA335017)
3 x ITA* 1/35 British Cold War Clansman Radios (ITA335025)
From Hannants:
1 x Airfix 1/35 Ferret Scout Car Mk.1 (A1386)
1 x Airfix 1/35 Ferret Scout Car Mk.2 (A1379)
2 x CMK 1/35 Ferret Scout Car Mk.2 Wheels (3153)
[*: ITA = Inside The Armour]
From scautomoton, 1/700 P139B and Naval AFVG for my CVA-01 build. These are lovely aircraft and look the part on CVA-01, but could equally be used on Ark Royal, Eagle, Hermes in the mid 70s, they could also be used on the French carriers to replace the Crusaders. They might als be used on the US angled deck essex, as two were offered to the RN to replace Ark & Eagle when CVA-01 was cancelled, the type was also the prefeered option for the Melbourne replacement in the RAN in the 65 period, rather than the refit for Skyhawk & Tracker.
Also in in 1/700 from China through eBay i have picked up a 3d printed HMS Peacock, Hong Kong guardships some of which ended up with the Irish Navy.
Quote from: Thorvic on July 10, 2025, 02:40:24 AMAlso in in 1/700 from China through eBay i have picked up a 3d printed HMS Peacock, Hong Kong guardships some of which ended up with the Irish Navy.
And some with the Phillipines Navy IIRC.
Quote from: Weaver on July 10, 2025, 05:56:05 AM
Swift and Swallow went to the Irish Navy  (withdrawn 07/2022) , and Peacock , Plover and Starling to the Philippine Navy  ( upgraded, still in service)
George the Cat
From Tornado Hobbies and Books in Birmingham city centre today....
1/72 Special Hobby AJ37 Viggen.
From Ebay:
Italeri 1/72nd UH-1N Twin Huey  - same plastic as their AB-212/412 kits, including both 2-bladed and 4-bladed rotors.
Also includes a "British Royal Army" colour scheme... ;D  ;D  ;D  :rolleyes:
Quote from: Weaver on July 11, 2025, 03:16:01 AMAlso includes a "British Royal Army" colour scheme... ;D  ;D  ;D  :rolleyes:
Always amuses that  ;D  The one part of our Forces that requires a vote. :angel:
Delivered yesterday from Japan, the Fujimi 1/72 A-7A "Blue Blazer" box. It will become a real world PoAF bird. I already had the Hobbyboss A-7P but, although the kit may impress with the rivets and fine surface detail at first look, on a closer inspection the Fujimi kit also has good surface detail, the only difference is the most criticized area of the HobbyBoss kits, which is the air intake. Fujimi's intake is accurate and HB's is squashed, with a flat bottom that is very noticeable for those who know the A-7 well.
The next big difference is the lack of rivets on the Fujimi kit, which are present on the Hobbyboss kits. There are other flaws with the HB kit that make me believe the Fujimi kit will be a better build so, this one is going straight to the "Next on the bench" pile that sits beside my chair and the HB kit is going back into the stash. :mellow:
Charlie_c67
So a few arrivals from the bay of e today all 1/72.
Fujimi A-7D
Hobbyboss A-7K
Hasegawa MS 406
Special Hobby Beaufort Mk.1
Whilst I realise the Airfix Beaufort is probably easier to build, the SH one was going for a song!
I also managed to pick up the Arco-Aircam book on the Lancaster from a charity shop for a princely £1. Interest grew further when I realised that the dedication in the front was from one Major Hubert "Nick" Knilans, erstwhile of 619 and 617 squadrons, who took part in Operation Taxable the raids on the Tirpitz in 1944. Admittedly I had to look him up, but good to have a such a tangible link to the past.
Quote from: George the Cat on July 10, 2025, 09:51:07 AMFrom Tornado Hobbies and Books in Birmingham city centre today....
A very nice Viggen kit indeed!  :wub:
George the Cat
Quote from: Pellson on July 14, 2025, 02:16:51 AM
Indeed. I have a couple of the SF37 on the stash too. One might be Norwegian and another Finnish.
