avatar_seadude
What would you whif a YAMATO class battleship into if you could?
Started by seadude, October 13, 2024, 11:01:28 AM
seadude
As I previous mentioned in Post # 1436 here:
https://www.whatifmodellers.com/index.php?topic=52431.1425
.............I came into possession of a TAMIYA 1/350 scale IJN Yamato battleship kit.
But whether I keep it, re-sell it, or do anything else with it depends on how salvageable the kit is as I need to check for missing or damaged parts, etc.
If I keep the kit, I have no idea what I'd whif it into if I did. I'm clueless.  :unsure:
So my question is: What would you folks do with a Yamato battleship kit? How would you whif it?
Steel Penguin
in no apparent order,
catamaran
wheels  or tracks and a land battle ship,
 low profile wheels and a racer
90s update,  cwis radars ets
now update  vls cells drones etc
zeppelin style lifting array and an areal battleship as in the Micheal Moorcocks " warlord of the air" books
rebuild the uppers and have it as a comms array / science vessel
i dont know what scale figure youd need to use to get a "shipgirl" look  probably too large.
Quote from: Steel Penguin on October 13, 2024, 12:10:13 PMi dont know what scale figure youd need to use to get a "shipgirl" look  probably too large.
There's already a Boat Girl: a hairdresser called Jackie who just happens to own an ELCO 109ft torpedo boat. She was a bit shy and innocent until she met the gang... :wacko:
Quote from: seadude on October 13, 2024, 11:01:28 AMAs I previous mentioned in Post # 1436 here:
Turn it into a giant space battleship, with tail fin and jets, but keep the 18" guns. Totally original idea: I mean, who'd be mad enough to have come up with that one already, right?
Quote from: Weaver on October 13, 2024, 01:13:41 PM
Well, once you get all that steel into space you might as well make good use of it. A couple of times slingshotting around the big planets would get it up to speed. Just don't try to stop it.
1.@1958. It survived the war and after sitting in mothballs for a decade + it was modernized roughly like the Galveston Class Cruisers with main turrets still forward but missiles aft.
2. WWII- Aft deck converted to a flight deck.
3. Post WWII, captured as a war prize, Put into Soviet service.
Steel Penguin
swap the plant for a nice big Fusion engine  and go for railguns and CREWS
rescale it with some foils and have a hydrofoil in 100cale.
Quote from: sandiego89 on October 14, 2024, 09:34:43 AM1.@1958. It survived the war and after sitting in mothballs for a decade + it was modernized roughly like the Galveston Class Cruisers with main turrets still forward but missiles aft.
Re option 1:
The kamikaze operation to Okinawa is never launched due to fuel shortages.
Yamato is scuttled at her moorings to block the port in anticipation of a US invasion.
The A-bombings make an invasion uneccessary.
Since the ship was scuttled by opening her sea cocks rather than using explosives, the easiest way to clear the port is to seal and refloat her.
Yamato is disarmed, unfuelled, and used as an accomodation ship for 10 years.
When the JMSDF is being put together, the use/conversion of the hull comes up for consideration.
Steel Penguin
ive gone sideways again ( i blame John Denver's  Calypso coming onto my player at random)  a super sized research ship for  Jacques Cousteau  plenty of space for the under hull view dome, and submersibles on the back deck.  And its such a statement of swords into ploughshares..
Use the turrets and gun barrels as a crane to lower and recover the minisubs. Or place them as artificial reefs to study the fish
Joe CalPo
Replace the guns with catapults and ballistae as an ancient warship, or post-apocalyptic.
PFJN
Hi,
I guess you could use also maybe the hull to make a ginormous cruise ship/passenger ship.
Pat
perttime
Yep. A luxury cruise ship. Remove the guns and other stuff that is only good for ship battles and bombardment. That should make space for swimming pool, golf driving range, skeet or trap range, and other facilities for healthy and fun activities.
This page about the genesis of the Yamato has some interesting stuff:
Yamato Class Genesis
This is the all main turrets fwd. configuration closest to Yamato, as built.
Quote from: PFJN on December 20, 2024, 06:50:29 PMHi,
Pat
Yamato is dwarfed by cruise ships, and it was smaller than the big ocean liners of the period, but it could be an ostentatious yacht for a mega-rich Bond villain.
:wacko:
