Double Pancake
Started by PR19_Kit, March 10, 2020, 08:49:57 AM
Scotaidh
Quote from: PR19_Kit on March 30, 2020, 03:51:47 PM
Joined the top and bottom halves, added the tailplanes and the engine intake cowlings. Both the last two items are going to need some PSR, they don't fit all that well. :(
A bit off-topic here, sorry.  I've never liked this aircraft, but this picture makes me want to build one of these as a twin-jet.  Scratch some two-dimensional exhaust nozzles, figure out what to do with the prop-shaft housings, and have a pretty (far-fetched) little jet fighter.  :)
Sorry for the diversion, but if I don't sort these thoughts out now, I'll lose them forever.
Now I return you back to the story already in progress ...
In this context, I found a sketch of a pure jet version of the F5U in a book - purely fictional, though:
Post-war STOL Skimmer concept drawing
by dizzyfugu, on Flickr
And, BTW, there actually was a rival for the F5U from Boeing, the B.390 project with a single turboprop and more of a central fuselage - and actually not with the F5U's STOL capabilities:
Boeing B.390 project - an F5U alternative
Quote from: Scotaidh on April 01, 2020, 12:51:55 AM
...picture makes me want to build one of these as a twin-jet.  Scratch some two-dimensional exhaust nozzles, figure out what to do with the prop-shaft housings, and have a pretty (far-fetched) little jet fighter.  :)...
Put gatlings in them
Not a bad idea at all!!  Only problem is if the rates of fire are not exactly synchronised, I can visualise the whole affair hurtling round the sky like a badly thrown frisbee.
Quote from: Dizzyfugu on April 01, 2020, 01:15:57 AM
Spread the nozzles out into thin slits at the trailing edge, then have intake slits upstream from them that a) cool the nozzles, b) cool the exhaust stream and c) act like thrust-reversers. Essentially, they'd be like linear A-37 Viggen nozzles.
Quote from: Rheged on March 31, 2020, 07:23:42 AM
Quote from: PR19_Kit on March 31, 2020, 05:22:57 AM
Quote from: Weaver on March 31, 2020, 05:20:20 AM
It has the added advantage that if the pupil really screws up, the instructor can scoot forwards a bit and kick him in the side of the head... :wacko:
Just like a Jaguar, Tucano or any other modern trainer.  ;D
I understand that if the pilot made errors in a Sea Vixen, the navigator in his black hole could bite his ankles!
The back seaters in Javelins discovered a couple of 'interesting' things:
1. By unscrewing a panel in the back cockpit, they could get access to the control linkages from the front cockpit to the flying controls and steer the plane by pulling on them even though they didn't have any official flying controls (telling the pilot was optional... :wacko: )
2. With a bit of practice, the "diddly-dee, diddly-dee" sound of the stall warning horn (a very, VERY important piece of kit in the Javelin) could be simulated using a harmonica... :wacko: :wacko:
Without the props there'd be no big vortices to generate the massive lift at low speeds which was the root of Zimmerman's patent. The single finned pure jet version just wouldn't work the same way, and that goes for the Boeing aircraft too.
Plus the RW F5U had a couple of automatically operated flaps at the trailing edge, between the two fins, that stabilised it during landing. The jet version doesn't have the room for those flaps either.
I think Unicraft do a "kit" of that Boeing project ?
Yes, I remember having seen a model of the B.390.
Quote from: NARSES2 on April 01, 2020, 06:31:07 AM
Please do NOT use the word 'Kit" and "Unicraft" in the same sentence!
Quote from: The Wooksta! on April 01, 2020, 09:22:43 AM
As if..............  ;D ;)
The PSRing of the Pancake was a right pain, the intakes didn't fit at all well, and the tailplanes were pretty awful too. But amazingly it came OK in the end, mainly by the use of Albion Alloys narrow sanding sticks to get round the intake areas.
I've put one coat of primer on and I think the PSR's pretty well done!  :thumbsup: ;D
It looks strangely different without the cowl flaps sticking up half way down the engine fairings.
For markings, how about Canadian Navy as a COD aircraft?  I'll pass on some resin barrels so it could be delivering Maple syrup supplies.
I'll get me coat...
Quote from: The Wooksta! on April 01, 2020, 04:51:00 PM
I'll get me coat...
;D ;D ;D ;D ;D ;D
No, it's slated to be a USN Trainer, in that T-28 scheme I posted elsewhere much earlier.
That's why I put it in parenthesis  :angel:
