Author Topic: Double Pancake  (Read 3739 times)
Offline ChernayaAkula
  • Deutscher Meister 2011 & 2012 - BVB 09!
Re: Double Pancake
« Reply #15 on: March 14, 2020, 02:51:17 pm »
Hmm. Attach some legs and you'd have a wonderful mecha frog/toad.  :wacko: :rolleyes:  ;D
Offline Librarian
  • NOT a Monkey!
Re: Double Pancake
« Reply #16 on: March 14, 2020, 04:24:03 pm »
Quite the beast. Got the Kittyhawk kit somewhere but never quite got around to fitting Pegasus-type engines inside with nozzles :wacko:
I read somewhere that when sailing into wind (X-knots??), the plane would just lift straight up. Boone Guyton said something about his belief that the vibration issues would have shaken the plane apart with a very short airframe life.
Offline The Wooksta!
  • Resident Soup Dragon
  • What-IF SIG
  • Would you risk it for a chocolate biscuit?
Re: Double Pancake
« Reply #17 on: March 14, 2020, 04:38:22 pm »
I did the Hasegawa kit in 1996 as a FAA bird wearing Gannet markings - it was definitely at Telford that year on the SIG stand and I had several people convinced we'd operated it.
"Please dial *617 at this time"
"We're the Sweeney, son, and we haven't had any dinner."
"An inaccurate parcel of dog turds!"
www.whatifmodelers.com/index.php/topic,34762.0.ht
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
Re: Double Pancake
« Reply #18 on: March 14, 2020, 08:44:21 pm »
The testbed for the Pancake, the lower powered V-173, did almost take-off vertically.
Its take-off run was something less than a couple of fuselage lengths IIRC. I can't remember where I read it, maybe an Aeroplane Magazine article some years ago.
I was thinking about replacing the P&Ws with turboprops, it's already got a perfect intake configuration, I'd just have to sort out an exhaust setup somehow.
I recall your FAA Pancake Lee, that looked the business for sure.  :thumbsup:
Offline kitnut617
Re: Double Pancake
« Reply #19 on: March 15, 2020, 06:22:28 am »
I've got the Hasegawa kit now, and it's a ZINGER compared too the Pegasus version.
The Hasegawa Pancake was originally produce by Hobby Spot U as a resin kit. This Japanese company only produced three kits and only lasted four years (1989-93). Hasegawa re-issued two of them, the Bell X-1 and the Pancake.
  • What-IF SIG
Re: Double Pancake
« Reply #20 on: March 15, 2020, 05:02:40 pm »
I think the Japanese version of the Komet that Hasegawa released was also by Hobby Spot U - IIRC there was a marking on the box.  It definitely wasn't a Hasegawa tooling.
Offline kitnut617
Re: Double Pancake
« Reply #21 on: March 15, 2020, 05:19:29 pm »
The only other kit Hobby Spot U made was a Nakajima Kikka, according to the big book.
Offline PR19_Kit
  • What-IF SIG
Re: Double Pancake
« Reply #22 on: March 21, 2020, 02:15:59 pm »
While searching the sprues for some of the tiny parts I found that it actually has 'Hobby Spot U' moulded on the runners, in quite large lettering too!  :banghead:
The only places that mention Hasegawa are the instructions and the box.
I'm scratching up the tandem cockpit at the mo, which isn't as straightforward as I thought it would be, but if it was easy everyone would be doing it, right?
Offline kitnut617
Re: Double Pancake
« Reply #23 on: March 21, 2020, 02:51:58 pm »
I was looking at the instruction sheet for the Italeri/Testors BAe T.45 Goshawk which has similar markings as the T-28 you were asking what the 'red' was. I have the Testors boxing of the T-45 and it says the red is Testors 2719 Italian Red, FS31302 or Humbrol 60.
Offline joncarrfarrelly
  • Bertie Bassett
  • What-IF SIG
  • Turn that Gila-copter down!
Re: Double Pancake
« Reply #24 on: March 22, 2020, 05:45:47 pm »
Were are you adding the second seat? Immediately behind the aft cockpit bulkhead are the
oil tanks and the cross-shafting connecting the engines.
“Conspiracy theory’s got to be simple.
Sense doesn’t come into it. People are
more scared of how complicated crap
actually is than they ever are about
whatever’s supposed to be behind the
conspiracy.”
-The Peripheral, William Gibson 2014
Offline PR19_Kit
  • What-IF SIG
Re: Double Pancake
« Reply #25 on: March 22, 2020, 06:14:40 pm »
The cross shaft is going behind the front seat and in front of the rear instrument panel.
And as the production F5Us had turbine engines they didn't need such large oil tanks……………  ;D
Offline DogfighterZen
  • Bmx, music and whif junkie
Re: Double Pancake
« Reply #26 on: March 22, 2020, 06:52:45 pm »
I like where this is going!  :thumbsup:
Offline zenrat
  • Moderator
Re: Double Pancake
« Reply #27 on: March 23, 2020, 12:26:47 am »
So, given the props are connected I presume your production version will be able to shut down one engine and loiter?
My name is Commander William Riker.  Take me to your women.
Offline PR19_Kit
  • What-IF SIG
Re: Double Pancake
« Reply #28 on: March 23, 2020, 01:31:45 am »
Actually no, or maybe yes.  ;D
For the aerodynamics of the Zimmerman wing to work both props have to be going the whole time, so at least one engine needs to be running.
But as the engines are the dreaded T40s (hardly any aeroplane that used them was trouble free....) one half of each engine could be shut down in the cruise, a bit like a Gannet.
Offline zenrat
  • Moderator
Re: Double Pancake
« Reply #29 on: March 23, 2020, 02:18:58 am »
But Kit, the diagram Jon posted clearly shows the props are linked by gears and shafts so it would be possible, possibly with the addition of a clutch (?), to run both props on one engine.
