Author Topic: RAM's M4A2 Sherman - COMPLETED - Pic's pg.2  (Read 1588 times)
Offline Old Wombat
« on: November 07, 2019, 04:53:38 pm »
So, moving on from the F9F-8 Cougar into my preferred field of Armour, I'm going to build something I've never actually built before - a Sherman tank.
Seriously, in all of the years I've been modelling, I've never built an M4 Sherman of any variant. Closest I came was an M3 Grant, back when I was about 11 or 12.
Being me I've already made my first mistake; I trimmed off the casting numbers on the front left hull top next to the driver's hatch. :banghead:
Anyway, enough waffle, this is more a place-holder for when I get past the tedious bit of building the running gear & get into the build proper.
Catch you soon! :thumbsup:
« Last Edit: June 07, 2020, 08:07:13 pm by Old Wombat »
Offline Old Wombat
Re: RAM's M4A2 Sherman
« Reply #1 on: November 07, 2019, 09:03:34 pm »
Oh, by the way, I'm using the Dragon 1/35 USMC M4A2 Late PTO (DR6462) variant as the base for this build which will be mostly OoB.
Below is a photo of the casting numbers I removed last night. :rolleyes:
Offline NARSES2
  • Global Moderator
« Reply #2 on: November 07, 2019, 11:50:49 pm »
Sherman designations have always confused me (easily done), looking forward to watching this come together  :thumbsup:
That casting number throws me a little though. The hull seems to be a series of welded plates ? Was that plate cast, rather than rolled, because of the hatch apertures ?
Please note mate that if I don't respond to any reply it's because I'm away at Telford, not being rude and I don't tend to travel with the internet if it's only a few days.
Decals my @r$e!
Offline Old Wombat
« Reply #3 on: November 08, 2019, 01:00:38 am »
I'm no expert, either, but the M4A2 is the twin-diesel powered version.
The Chieftain (a.k.a. Nicholas Moran) gives a bit of an explanation in the earlier part of this video, if you want a more professional opinion: https://www.youtube.com/watch?v=z9Iirk8Q4Xw
PS: Shermans went through a number of construction types of varying levels of cast-&-plate which were, generally, welded together - the original M4s were almost all cast while the last versions were almost all plate.
Edit: Changed out the link for a better one. ;)
« Last Edit: November 08, 2019, 07:19:40 am by Old Wombat »
Offline zenrat
« Reply #4 on: November 08, 2019, 01:35:44 am »
Looking at the box art this one appears to be made of wood...
 ;D
My name is Commander William Riker.  Take me to your women.
Offline nighthunter
  • "Maybe I like that I'm Not Alright."
« Reply #5 on: November 08, 2019, 09:18:50 am »
 ;D
Zen,
The wooden added armor was to prevent Japanese magnetic mines. One of the things I'll be looking for at the local model railroad swap meet this weekend is HO (1/87) wooden siding and planks to put on my build, as well as some brass or plastic tube to make the gun barrel better. The latter is a maybe.
Offline Scotaidh
« Reply #6 on: November 08, 2019, 01:11:39 pm »
 ;D
Zen,
Why not just use stir sticks?  When I wanted a wooden bed-plate for my hover-truck that's what I did - stir sticks soaked in coffee for 48 hours or so ...
I try to learn from the mistakes of others who take my advice.
Offline nighthunter
« Reply #7 on: November 08, 2019, 01:18:32 pm »
 ;D
Zen,
Scott, are you talking about the coffee stir sticks?
Offline Scotaidh
« Reply #8 on: November 10, 2019, 08:15:49 am »
 ;D
Zen,
Yes.
Offline nighthunter
« Reply #9 on: November 10, 2019, 08:46:57 am »
Don't forget the bolts for the planks.
And green stuff for the concrete
Offline Old Wombat
« Reply #10 on: November 13, 2019, 07:11:44 pm »
Photo's have been rare for this build, I'm afraid, but only because I've been flat-out working on it.
Currently in the paint shop getting the base OD done.
Once I've done that I'll be putting more of the sub-assemblies together &, hopefully, fitting them for semi-final paint.
Then I'll be working on the clear bits (a lot of little ones for the periscopes, etc.).
Followed by final construction & paint.
Typical of a Dragon kit, this thing has far too many small, fiddly parts & didn't come with a .50 cal (the mount but no gun), so I've used an AFV Club item from a set of .50 cals (which also had too many small, fiddly parts but looks very good).
Thanks for watching! :bow:
Offline zenrat
« Reply #11 on: November 14, 2019, 01:36:48 am »
Balsa has a nice fine grain and is very easy to work being soft (ironic being it's a hardwood).  I've had good results staining it with soy sauce.
Offline Old Wombat
« Reply #12 on: November 14, 2019, 06:38:54 am »
To stop people fussing about wood planks; My build isn't using them. :rolleyes:
Offline nighthunter
« Reply #13 on: November 14, 2019, 01:12:54 pm »
Sorry, that's my fault
Offline Old Wombat
« Reply #14 on: November 14, 2019, 06:51:06 pm »
Not really, I should have said so at the start. :thumbsup:
Base OD has come out a bit lighter than desired, so I'll have to darken it a bit but I'll do that later, after she's all together & the camo is on (which I'll do a bit light to allow for overall darkening).
I'll try to get some photo's up but probably not before Monday. Got 3 more arvo shifts to get through first. :-\
« Last Edit: November 14, 2019, 06:56:04 pm by Old Wombat »
