avatar_zenrat
Fairey Rotodyne 2.0 - Finished pics page 14
Started by zenrat, February 25, 2019, 11:18:42 PM
Let me be the first to put their metaphorical towel on the sun lounger of the Flying Machines of Unconventional Means (that really needs a snappy acronym - haw about Alt. Flight?) GB.
I shall be building an improved Rotodyne from these parts.
Rotodyne 2.0 Start by Fred Maillardet, on Flickr
Go Fred!  :thumbsup:
But not until March 1st of course...........  ;D
Modelling_Mushi
Quote from: zenrat on February 25, 2019, 11:18:42 PM
Very interested to see how this one goes ... been a wallflower/lurker for nearly 2 years, dreaming of polystyrene glue ...
GB acronym? Already has one ... F*Mum ... although don't tell my mum.
Quote from: PR19_Kit on February 26, 2019, 12:52:02 AM
Go Fred!  :thumbsup:
Not even a small head start so I can begin sanding all those rivets off...
OK, I promise.  ;)
Hmmm, a Rotodyne AND a Harrier in the same build? It only needs a bit of Concorde in there to become more Nineteen-Sixtiesly British than the mind can comfortably conceive...
The other two bags contain parts from an Il-28 and an A-10.  Neither British nor Sixties.
However, you have given me an idea for a paint job OTHER than zenrat industries.
Quote from: zenrat on February 28, 2019, 12:40:50 AM
Ah, I can see them now you've named them, however I was struggling to identify them before.
Quote from: Weaver on February 28, 2019, 01:59:30 AM
But can you identify the kit manufacturers?
The A-10 is easy given there are two colours of plastic in there.
The Harrier could be a bit trickier unless you have built one of this example and have cursed at the ill fitting and poorly thought out intake design.
Well i've started.
I've glued the windows into the 'dyne fuselage, assembled the 'dyne wings, partially assembled the Il-28 nacelles and started assembling the Harrier fuselage while working out how to combine it with the rotor support thingo (pylon?).
Quote from: zenrat on February 28, 2019, 02:37:48 AM
I've got one of those in my stash, I'll try to find it.
Chop, saw, hack, glue, hack, chop, chop, saw, gouge, balance and photograph...
Progress so far.
ROTODYNE 2.0 WIP 05-03-2019 by Fred Maillardet, on Flickr
While it will have a jet nozzle at the rear providing thrust, the main purpose of the Harrier's Pegasus is to provide compressed air to the rotor tips.  it also allows me to raise the rotor higher above the fuselage meaning the vertical tail(s) doesn't need to fold for clearance.
Radical thinking there Fred.  :thumbsup:
Can't wait to see where it goes eventually.
I may add burner cans to the rotor tips...
...and line the fuselage with cotton wool to simulate sound insulation.
Today I also disassembled the nacelles and reassembled them correctly so I didn't have one fat one and one thin one.
Quote from: zenrat on March 05, 2019, 01:34:47 AM
Tophe wold have approved if you'd left them as they were.............  ;D ;)
I've been thinking about the Hughes hot tip solution* which is just exhaust gases being piped from the engines above the fuselage for a Rotodyne project I have in the works ---
* been reading about it on the Secret Projects Forum.
