Westland Waterspout (Sea Whirlwind) MKIII
Started by Doug K, November 21, 2018, 12:00:14 PM
Doug K
Hmm, well this seemed like a good idea at the time, Airfix Whirlwind plus conversion kit for the Tamiya Mossie. Simple cut'n'shut, no? NO!
The resin engines mare missing the top of the cowling so PSR2 is being employed. The spinner diameter is way more than I bargained for, so the 4-blade Spit props I had in mind are useless and the only others that come close are from a Lanc!
If I leave the prop blades full length then the cannon will need interrupter gear!
FFS, now I see why they didn't re-engine the Whirlwind with Merlins.....
I fear the the Kestrels with the Spit props would have been more believable!
IMG_1447 by doug_alba, on Flickr
The tops of the cowling are "missing" because you use the kit part that the conversion is made for Doug.
Can you lengthen the inner wing portions? But then you will probably have to lengthen the landing gear. That might be more than you are willing to invest in this. On the other hand cut down props with squared off tips might look cool. Just my $0.02 worth.
Doug K
Quote from: kitnut617 on November 21, 2018, 12:49:36 PM
Yeah, I assumed that. I tried my various spare cowlings (from all my Defiants) but the curves were wrong.
I'll get there, eventually!
kerick's suggestion of cut-down 4-blade (maybe even 5-blade?) props sounds the go-to to me. :thumbsup:
Martin H
When I did all my Whirlwinds I left the cowlings alone. I just bolted on aeroclub mk9 spitfire props. That and a change in markings were convincing enougth (for me) that you were looking at a Mk II whirlwind or higher....................
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Air21
Or just use the nacelles from a Swearingen Merlin   :mellow: you'll only be 1,500lbs lighter for the same hp  :wacko:
Scotaidh
Can you just use the Mossie wings inboard of the engines?  IIRC, they also used wing root radiators -
which would give you the standoff from the fuselage so the prop arcs don't impinge on the firing cones.
Air21, who makes a 1/72 kit of the Swearingen Merlin?
The trick of this stunt is to stick to the considerably smaller Whirlwind propellers - the Mossie props are much too big and long, even though you have to adapt the spinners. The good thing is that the Whirlwind uses the same radiator arrangement as the Mosquito, but you cannot (at least not easily) transplant the Mosquito wing to the Whirlwind, it is much too deep and thick. Using the Whirlwind wings is a better strategy.
On mine I found the Italeri Spitfire Mk V engines (which come separately in their kit) didn't take much fettling at all. Even less if I could cut straight lines  :banghead:
http://www.whatifmodellers.com/index.php/topic,45532.0.html
Quote from: NARSES2 on November 22, 2018, 07:13:18 AMOn mine I found the Italeri Spitfire Mk V engines (which come separately in their kit) didn't take much fettling at all. Even less if I could cut straight lines  :banghead:
Cutting straight lines is easy and simple. At least, from what I see others do. I still haven't managed it.  :banghead: <--- Joining you in frustration.
Doug K
Quote from: The Rat on November 22, 2018, 07:28:08 AM
Not a skill I've mastered either!
Doug K
Quote from: Dizzyfugu on November 22, 2018, 06:19:17 AM
Yeah, that is my thinking too, right now I can't see any thing for filler dust!
Still, the arrester hook looks ok....  :o
In my extensive experience of doing such things I've found that the best way to cut a straight line is to TRY and cut a curved one.
The result will be as straight as a die, just when you DON'T want it to be!  :banghead: :banghead:
