Westland Waterspout (Sea Whirlwind) MKIII
Started by Doug K, November 21, 2018, 12:00:14 PM
Quote from: NARSES2 on November 22, 2018, 07:13:18 AM
On mine I found the Italeri Spitfire Mk V engines (which come separately in their kit) didn't take much fettling at all. Even less if I could cut straight lines  :banghead:
http://www.whatifmodellers.com/index.php/topic,45532.0.html
I was going to suggest using a Spitfire nose
Doug K
Quote from: kitnut617 on November 22, 2018, 09:34:28 AM
The Spit might have worked, the Defiants definitely didn't!
Not quite what you're doing but close - my Boulton-Paul/Westland Defender Mk.IV.
http://www.whatifmodellers.com/index.php/topic,33424.0.html
My Westland Wirly-Wirly TF.III  used Bristol Hercules Engines.  It was decidedly easier than you'd think.  All that was needed was a little widening of the engine pods and a slight lengthening of the undercarriage legs to make it all fit.
Doug K
Doug K
OK, it's done. BPF markings, flying from HMS Indefatigable in 1946
This was one of this project one wishes one had never started! The resin nacelles are beautifully moulded but are definitely not for a Whirlwind!
If I did it again the Kestrels would be working perfectly (it's a whiff after all) and the 4-blade spit props would have their own spinners!
I assumed that the Mark III would have moved to sting-hook, which strikes me as more practical on the fuselage.
Or not.....
IMG_1467 (2) by doug_alba, on Flickr
IMG_1468 (2) by doug_alba, on Flickr
IMG_1469 (2) by doug_alba, on Flickr
IMG_1470 (2) by doug_alba, on Flickr
dwomby
I do like that, especially in those markings  :bow:
Doug K
Thanks guys, as I said it was a bit of a bugger.
Came out ok in the pix tho
Neat.
Best use for the Pavla two stage Merlins, because as moulded they're too short for a Mosquito.
"Visit Scarfolk today!"
"She's died?!?  Then how's she meant to get the shopping home?"
