avatar_Gondor
My Toolbox just got Bigger!
Started by Gondor, June 21, 2017, 10:41:58 AM
I received a Vman ultra sonic cutter too. It cuts like a dream but the battery doesn't seem to charge or I'm not doing it right. Works perfectly when it's plugged into the charger. The web is no help as it sends me to charging instructions for an ultrasonic kitchen knife.
frank2056
Quote from: Charlie_c67 on January 14, 2026, 12:40:46 PMI assume this is where I should be putting this.
I've purchased 6 of the AK paint pens, three allies cockpit colours and three insignia colours (which includes white and yellow, but not blue?). So far, they've all worked from the off, the yellow has needed more than one coat, but that's to be expected, and I've not got up the courage to try the white one... yet!
Main takeaway so far, protect those tips!
I've had these pens for a while, and have learned a few things:
1 - they degrade gracefully - the felted point will wear out and you'll ed up with a wider point that is fine for larger areas
2 - they seem to last forever. I haven't run out yet
3 - if the tip dries out slightly, water, or better yet an acrylic thinner (like Vallejo) will revive it.
4 - as the tip wears out, keep an eye out for little bits of felt. they're easy to trim off.
frank2056
Ken, if it comes with its own GAN charger, make sure you're using the cable that came with it.
Charlie_c67 and Frank2056. Many thanks for those opinions on the AK paint pen range  :thumbsup:
Seriously looking at getting the cockpit colours and a few others  :thumbsup:
Nick
Hobbycraft do an X-Acto style craft knife but with a thicker grippier handle. https://www.hobbycraft.co.uk/xcut-no-1-craft-knife/5847431000.html
Ordered some AK Interactive Paint Markers from Jadlam Monday and they arrived today. Mainly interior shades and a couple of basic colours for things like nav lights etc. Hopefully try them out next week.
First time I've bought from Jadlam on-line, I've bought from them at shows, and whilst I wasn't that comfortable with the website *, their service was excellent  :thumbsup:
* I find the Big H easier to use, but that's probably because I'm always on it  ;D Also unlike Jadlam they are purely about modelling and you don't have to navigate your way through railways and slot cars etc. Still they are useful for when the Big H doesn't stock what I want  :thumbsup:
Quote from: NARSES2 on February 06, 2026, 05:27:40 AMOrdered some AK Interactive Paint Markers from Jadlam Monday and they arrived today. Mainly interior shades and a couple of basic colours for things like nav lights etc. Hopefully try them out next week.
Jadlam have a points-based discount system as well, so if you find yourself using them regularly, rememeber to sign up fro it.
Quote from: Weaver on February 09, 2026, 12:51:07 AMJadlam have a points-based discount system as well, so if you find yourself using them regularly, rememeber to sign up fro it.
I did notice that and signed up just in case  :thumbsup:
frank2056
I got some thin (0.2mm) tin-pewter foil, certainly safer than lead foil and a good replacement. It should also work when I need something smoother and with more heft than Tamiya tape. This is what I got: Flexible Tin Foil - Craft Pewter certainly safer than lead foil
After borrowing my railway modelling mate's Optivisor on a long term basis for many years, now I've moved 120 miles away from him I had to get one of my own, and a real zinger it is too.
It comes complete in its own carrying case (!) and has no less than FIVE different levels of magnification, ranging from x1.5 to x3.5, most impressive. It also has a built-in re-chargeable light, and a fold over magnifying glass as well.
What not to like?
It was invaluable in starting to build my RW IBG Spitfire PR1C.
A tool to make grab handles with.
Should be most useful.
Quote from: kitbasher on March 19, 2026, 11:41:57 PMThat's cheating, Kit!
Maybe so, but when the PE camera trigger, which needs to be glued to the styrene joystick, is only 0.5 mm wide and 1.5 mm long I had to do SOMETHING just to see the darn thing!  :o
The amount of teeny, weeny parts in the IBG Spitfire kit is mind boggling!
...and your point is?...  ;)
At our age, we need all the help we can get.  :thumbsup:
Quote from: Rick Lowe on March 21, 2026, 07:30:22 PM
I have been using something similar for years. As kit says, really small parts require something like that, and I occasionally work on 1/600 ship parts, which is a scale of two feet per millimetre!
