avatar_NARSES2
My brain works in an odd mix of metric & Imperial, as I was near the end of primary school when Australia changed over to metric & I've found bits of both easier to use for different things.
For example, I use:
feet & inches for heights & short distances (much easier);
metres & kilometres for distances over a few feet (see what I did there? ;) );
acres & parts thereof are easier to visualise for smaller properties up to about 10 or 12;
above that hectares are much better (the numbers are smaller to start with); &
square feet up to about 12, then it's square metres.
Money is always decimal because we changed to decimal currency when I was 4 & had bugger all understanding of money.
Quote from: NARSES2 on April 28, 2023, 05:37:26 AMMany years ago me and the then Mrs Edwards used to walk our dog through Mitcham Road cemetery in Thornton Heath then across the common to one of the Mitcham pubs for a Sunday pint. Our dog was quite a rumbustious thing, but whilst in the cemetery she was always remarkably well behaved.
Wonder what/who she was seeing...  :o  ;)
Quote from: Old Wombat on April 30, 2023, 07:36:50 AMMy brain works in an odd mix of metric & Imperial, as I was near the end of primary school when Australia changed over to metric & I've found bits of both easier to use for different things.
For example, I use:
I use a weird mixture of both.
I have never been able to visualise areas though.  Or longer distances.  Put me on top of a hill and ask me how big a paddock is or how far away, and while I would have a go it would be wildy inaccurate.
#3828
Having worked and generally been interacting with Britons since my early twenties, I'm a bit mixed too. At home, I usually work metric, but as soon as someone imperial is around, I tend to switch.
This goes for distances, weight and speed, as well as some volumes (mainly pints, if you need to know😉) while areas are confusing as soon as you leave square metres or square feet.
Also, I find the imperial system quite entertaining just because it's so totally random.
Quote from: Rick Lowe on April 30, 2023, 10:26:16 PM
I've often wondered that.
Quote from: Pellson on May 01, 2023, 04:58:37 AMAlso, in find the imperial system quite entertaining just because it's so totally random.
I was assured by an old history master that it wasn't, but I've never seen much proof to back that up  ;D
I was 19 when we decimalised, but we've never really embraced metrification. I think governments are just waiting for it to die out, if it ever does. :angel:
HOORAY, HOORAY, FIRST OF MAY and the rest is long consigned to history  :angel:
Quote from: NARSES2 on May 01, 2023, 05:33:42 AMI was 19 when we decimalised, but we've never really embraced metrification. I think governments are just waiting for it to die out, if it ever does. :angel:
LUDDITE!
Quote from: kitbasher on May 01, 2023, 05:42:06 AM
LUDDITE!
 ;D  ;D
At school, I was taught Imperial units  and trained, as a teacher, to teach both Imperial and Metric.  I can work in either or  a hybrid mixture of both.  The aspect of metrication that really exercised me was the change from  £ s d to £ p.  Cashing up the college bar at the end of every evening was a laugh a minute.  The convention was that one paid for drinks in either units, but change was always given in £ p.     Apart from a few argumentative  twerps  and the "tired and emotional"**  types found in every bar  the system worked well and we ended up more or less in balance
**  BBC  euphemism for sozzled politicians
History teacher mode engaged
Imperial units have their own idiosyncratic logic. An inch is a finger joint, a foot is exactly that and a yard (a clothyard) is nose to fingertip. A furlong...furrow long... is as far as your ox team can plough without a rest , a rod, pole or perch is the length of rod or pole  used as an ox goad  and a mile is mille passuum------one thousand double paces by a Roman legionary.  A pint is about as much as you can drink in one draught.  A stone is as much as you can carry any distance and a hundredweight as much as you can lift.
History teacher mode disengaged
Quote from: Rheged on May 01, 2023, 05:47:34 AMAt school, I was taught Imperial units  and trained, as a teacher, to teach both Imperial and Metric.  I can work in either or  a hybrid mixture of both.  The aspect of metrication that really exercised me was the change from  £ s d to £ p.  Cashing up the college bar at the end of every evening was a laugh a minute.  The convention was that one paid for drinks in either units, but change was always given in £ p.     Apart from a few argumentative  twerps  and the "tired and emotional"**  types found in every bar  the system worked well and we ended up more or less in balance
..but making that exact will force you to standardise your human in detail. As well as your ox, I think.  ;)
The most common number I use on a calculator is 25.4..............  ;D
(Ah, maybe after 7.85, which is the scaling factor I use to make my decal drawings correct size when printed.)
I heard that the cubit is makeing a comeback..... opps that should be a Q Bit or Quantum Bit  :rolleyes:
I was at Secondary school when the UK changed to Decimal currancy. Lots of fun at break time trying to catch each other out with conversion in either direction.
And a chain is as long as your wicket.
 :mellow:
