avatar_Radish
Airfix
Quote from: Weaver on July 25, 2024, 02:38:08 PMOff the top of the my head, I think the Frdnch ones now have a sight called Viviane with IR capability, and export customers might have different ones again.
Does it have four starts in a row on the top front of it?
Quote from: Beermonster58 on July 25, 2024, 02:36:15 AMI had a look at the site and, regretted it instantly! ;)  ;D . They're still quite expensive but, I may have to treat myself regardless! ;D
You and me both  ;D  However I quickly reminded myself that there is no way I'd be able to paint one nowadays and my heart stopped pounding  :angel:
Another one for you Vintage Classics fans.
Out at Hannants now
Belvedere
I want to read the reviews on the Belvedere first, let's hope they've re-done the clear bits, the old ones were DIABOLICAL!
Quote from: PR19_Kit on July 26, 2024, 10:35:03 AMI want to read the reviews on the Belvedere first, let's hope they've re-done the clear bits, the old ones were DIABOLICAL!
For what it's worth, the second reply on their Twitter("X" :rolleyes:) post announcing that it's out is me making exactly that point to them.
I've just asked their spares department for a replacement port side canopy, my original issue one came with two starboard ones. If they supply it, I'll send the spare to them.
If Airfix hasn't issued an improved set of clear parts, very likely, then perhaps some after-market company may do so. Very easy to make an accurate vac-form buck by 3D printing it.
Maintrack/Whirlybird did that with the original kit, but they also included a whole lot of parts to update the model to a proper RAF version, which made the whole lot pretty expensive, specially when it was in Whirlybird's hands!
I think OGL did one using that kit, and Whiffed it very nicely too into an AEW variant.
The Belvedere clear parts are the same old tat.
Screenshot from a rather horrible unboxing video. Shot way too close and the dude seems to think that we need to see his flippin' fingers all the time.
Belvedere
Grooooooooooooooooooan! :(
Couple of other things from that video:
The instructions and decals have a scheme for an aircraft from the Belvedere Trials Unit at Odiham (1960). The instructions tell you to leave off the end-plate fins and cut off the tabs on the original tailplanes. I'm not sure if this is a poor attempt to replicate the production aircraft tail planes, or if the BTU aircraft were to some intermediate standard and it's accurate.
The video maker says a company is already working on a mask set for the cockpit glazings.
It might be worth it for somebody to do a resin correction kit. It'd be fairly complicated though: you'd need hollow cockpit halves with, at least, a separate chin glazing, new intakes (brass mesh?), new tailplanes and a new door.
I think a whole new kit is the real answer as the Airfix one is "not fit for purpose" shall we say?
Quote from: Gondor on July 27, 2024, 03:04:39 AMI think a whole new kit is the real answer as the Airfix one is "not fit for purpose" shall we say?
They can do that after they've done the new Rotodyne Mould I feel they owe me.
Airfix have just announced a 1/48th scale Curtiss  Tomahawk Mk.II:
https://uk.airfix.com/products/curtiss-tomahawk-mkii-a05133a?
£28.99 - seems reasonable to me, but then I don't build 1/48th so I don't really know the market.
Quote from: Weaver on July 28, 2024, 05:41:55 AMAirfix have just announced a 1/48th scale Curtiss  Tomahawk Mk.II:
This is, basically, just a re-pop of their 1/48 Curtiss P-40B Warhawk which sells for about AU$55.00 (₤27.99) here, which is in the upper range for a 1/48 Kittyhawk/P-40 kit (HobbyBoss P-40M Kittyhawk = AU$21.95 (GB₤11.18) & Italeri RAAF P-40E/K Kittyhawk = AU$54.95 (GB₤27.98)) but not unreasonable.
The question is "Do I need a P-40B in the stash?" & the answer is "No", I would much rather a Merlin-powered P-40F/L.
