Blargh
Started by Julhelm, November 19, 2005, 01:20:43 PM
Julhelm
I'm trying to design a stylish-looking VTOL jet for my game, and here's what I have so far. Supposedly it has vents below that open for hover mode, and doesn't tilt the nozzle or anything fancy like that.
On the bench:
Post-apocalyptic Beaufighter
Julhelm
Maybe this revised underslung setup looks better?
On the bench:
SebastianP
The top one looks more workable, IMHO - I figure that the front stage of the fans would have some kind of reduction gear, so that it spins faster when the lift vents are open, and that there's a turbine deflector in the rear. It would be a little hard to do IRL, but for sci-fi physics not impossible.
Nice design, by the way - it looks like a cross between a Hornet and an YF-23...
SP
Julhelm
I think I'll go with the underslung one for the time being; it makes it look fatter and more cartoony, which is sort of the look I'm going for. Interesting you should mention F-18 and F-23, since the design I started from was an F-20.
Here's the beginning of the gear and I added some wingtip rails.
On the bench:
Julhelm
I added a couple of intake thingys to the top and some kind of exhaust to the bottom, but I need some suggestions on poo-poo to add to it (no cockpit tho, that'd break visual consistency with other models) as I'm at 1/3rd of my alotted poly-limit right now. Oh, and the nozzle now swivels 90 degrees down for hovering purposes.
On the bench:
From a practicality standpoint the top one is better. If you decide to take-off or land vertically you don't want an intake on the underside that will suck in all sorts of debris.
Perhaps a nice big bump on the fuselage in back of the canopy, and a larger tail for more ground control ???  I like it !!!!
Ollie
Move the nose wheel way from that intake, or you will ingest lots and lots of debris.
Just realised that there's a problem with my choice of the top one - the engine intakes might be blanked off by those LERX's at high angles of attack.
The world is lucky that I'm not an engineer!  ^_^
According to me, there are not several bad designs in your collection: they are simply wonderful together, as a pleasant collection of dreams.
As far as I am concerned, I will not order the best nor fly the most performing, I just enjoy the designs, the shapes and ideas. :wub:  :wub:  :wub:
Thanks for these posts, like a bunch of flowers. :D
QuoteMove the nose wheel way from that intake, or you will ingest lots and lots of debris.
How about splitting the intakes into a "Y" so that the front gear rides in the middle?  that would still leave them on the bottom, and avoid the ground effect.
Julhelm
I did that, but I think it looks hungrier and more sinister this way. Besides, it has the additional intakes on the top to deal with FOD-ingestion, much like the Mig-29.
On the bench:
good call...the 16 has a huge mouth, and little problems.
    Do you think you might try to styrene this one too ?
Ollie
The F-16's nose wheel is behind the intake too.
QuoteThe F-16's nose wheel is behind the intake too.
Fudge.  What was I thinking...ah well.   How about  moving the nose gear then?
