avatar_Deino
Can anyone identify this aircraft / model ???
Started by Deino, May 11, 2005, 12:23:07 PM
Deino
Just found at the ARC-forum ???? :blink:
Any idea ???? Besides, I don't think it's Chinese !  :lol:
Cheers, Deino
My noon, my midnight, my talk, my song;
I thought that love would last forever; I was wrong.
The stars are not wanted now; put out every one:
Pack up the moon and dismantle the sun;
Pour away the ocean and sweep up the woods:
For nothing now can ever come to any good.
W.H.Auden (1945
Scooterman
#1
I first thought it was some member of the BQM-34 Firebee drone family but the tail and wing platform is all wrong........
Jeffry Fontaine
#2
This is a very interesting image that you have posted here.  What was the original image size?  I get the impression that you have cropped it down to just show this particular portion.  If that is the case, can you post the original image?  Sometimes there is more supporting information to be obtained within the original image that would allow for better analysis and perhaps provide an answer as to what that particular aircraft is by determining the country of origin.
Analysis of the image/subject, you must consider the following criteria:
Size of object/subject
Shape of object/subject
Surroundings of the subject/object
Shadow(s) created by the subject/object
Settings/situation of the subject/object
If it looks like a duck.  And it is sitting with a bunch of other ducks.  And these ducks are all floating on a pod.  Then it must be a duck...
The original image would also allow for determination of the size of the object.  From what you have posted I can only determine that it has two drop tank or bomb shapes under the wings and very close to the fuselage.  This alone tells me that it might be devoid of landing gear and could indeed be a target drone or reconnaissance drone of some kind.  So if you can, post the original image or provide a link to it so a better analysis can be made.
Leigh
For some reason I'm seeing something that looks like a Harrier?
Leigh's Models
RotorheadTX
Definitely looks like a drone to me. What I'm guessing are booster rockets paired above/below the wings, and what I'd swear is a 12" Tiny Tim rocket on the ventral centerline. The pods on the wing trailing edges are almost surely tracking flares.
Got no idea what it's called, or where it's from though.......
dragon
QuoteFor some reason I'm seeing something that looks like a Harrier?
Yeah, it looks AV8A-ish (those extensions on the wing tips).  But that nose looks too sharp for the AV8A....Does the Yak FORGER have wheels on the wing tips like the AV8A?  What's with the stuff under and on top of the wings?
viper29_ca
Wings are too small for a Harrier, even an AV8A
Thanks
Scott
Elm City Hobbies
http://www.elmcityhobbies.com
dragon
Perhaps one of the Harrier prototypes (P1127 or Kestrel or preceeding models)?
elmayerle
QuotePerhaps one of the Harrier prototypes (P1127 or Kestrel or preceeding models)?
Nope, the aspect ratio and planform of the wings is all wrong for an P.1127 variation.
--Jane Wagner and Lily Tomlin
WEll I've no idea but the tail and fusalage look a bit Jaguar'ish to me
Deino
QuoteDeino san;
In analyis of the image/subject, you must consider the following criteria:
Thanks,
Jeffry Fontaine
Bremerton, Washington
Sorry; this was the original picture ... I only chnaged the brightnes and contrast a little bit !
Deino  :(
W.H.Auden (1945
Deino
Maybe this could help ... both in comparison !
W.H.Auden (1945
dragon
Its got to be british (or british influenced).  Can't think of anyone else who mounts stores on top of the wings.
Aircav
The missile type things look like they could be boosters and the things on the trailing edges possibly tracking flares
Sir Sydney Camm
Vertical Airscrew SIG Leader
Jeffry Fontaine
#14
The original image does allow for more details of the aircraft to be revealed.  I now see that there is something attached to the rear of this aircraft that appears pod like in shape.  There are other features that were not observed in the darker image that look like jet engine exhausts in shape along the side of the fuselage and the attachment of the pod like objects appears now to be duplicated on both the top and bottom of the wings.  It is still very difficult to determine what country made this thing or its intended purpose.  I would still lean towards this thing being some kind of target drone now since the things on the wings do look like some kind of target flare for tracking purposes for heat seeking missiles or for tracking the object from the ground by observation/evaluation cameras.
