Martin Baker MB5 Super Monsoon F1
Started by PR19_Kit, April 12, 2026, 03:47:07 AM
I think you're dead right Lee, maybe another increase in fin height too?
The wing will be RADICALLY different as well, and that may make some changes to the tailplane a necessity as well.  ;)
Got the main fuselage assembled OK, sort of. One side is taller than the other, so there'll be a fair amount of filing and PSR to do, but that's not unusual here.
However that was just a temporary situation as I soon got the razor saw out and hacked the ends off it.  ;D  And then added some bits back on again....
That's the Eagle engine grafted onto the front end, with a fair amount of filing and PSR needed to fair it all in, but it's not too bad. The tail has been extended by 10 mm (a couple of feet in 1:1 scale...) to compensate for that monster nose. I may add some area to the fin as well, or borrow Lee's idea idea add a dorsal fin instead, there's no room for a ventral fin as it's still a tailwheel aeroplane.
Lots more styrene engineering to do yet, and PSR of course.
Flip, that's my future MB5 project (so far, anyway)  :banghead:  :banghead:
It's not quite as easy as I thought it would be Dave. :(
And the really radical bit isn't on there yet....................  ;)  ;D
I've got to go back to my old house this weekend for the stuff I'll need for that, so there may be a bit of a pause in the build.
What, you mean fitting the Matchbox Mystere wings (😉)?
Quote from: kitbasher on April 14, 2026, 06:27:00 AMWhat, you mean fitting the Matchbox Mystere wings (😉)?
Not exactly, no........................ ;)
Airfix Super Mystere wings then! 😂
Not quite...................  ;)
perttime
Big dorsal fins tend to look awkward to me. Tall fins/rudders on the other hand ...
Quote from: Gondor on April 14, 2026, 01:35:35 PMHFB 320 Hansa Jet wings?
I like idea of the forward sweep, but no.  ;)
But I have heightened a fin a bit, as much as is practical anyway.
I've got the first coat of primer on the Super Monsoon, after numerous PSR sessions of course. Still needs a bit of PSR, but that's what the initial primer coat is for of course. It's looking pretty much as I intended, and the tail extension looks a lot better than Kurt Tank's job on the Ta-152! Mind you, the MB5 is pretty rectangular anyway.
It must get an 8 blade Wyvern prop.  Anything else is just so passe...
