avatar_kitbasher
Not the Downfall GB #2 - Bubbletop Hellcat
Started by kitbasher, April 01, 2026, 04:01:00 AM
Another that was originally started two years ago and enjoying rapid progress and then it went into the part-build box.  Mostly a pre-loved Matchbox Hellcat plus what look like FROG Hellcat bits.
Canopy will either be from a scrapped 1970s Airfix P-51D or a scrapped Matchbox P-51D.
So a second officially revived build, again working to the Downfall GB deadline.
You're on a roll here Dave, good thinking.  :thumbsup:
Good stuff! I've been thinking of the same for a while but never got the urge to build it. Looking forward to see the outcome. :thumbsup:
That's an excellent idea!
I wonder why it took the Navy so long to adopt the bubble top canopy. It took until the Bearcats and Skyraider to show up in production IIRC.
Wings and tailplanes fitted, joints require a bit of PSR.
Have decided to go with the canopy off the long-scrapped 1970s Airfix P-51D.  Fit is better, saves faffing with the fuselage.  Needs scratch marks polishing out of it.
Pics at the next update.
Bubbletop Hellcats are cool. I did one long ago with a P-51 canopy, but also changed the engine into an R-3350 from a Skyraider, as a post-WWII variant.
That's a Bearcat.  What?  No.  Hang on...
Quote from: Dizzyfugu on April 28, 2026, 04:26:45 AMBubbletop Hellcats are cool. I did one long ago with a P-51 canopy, but also changed the engine into an R-3350 from a Skyraider, as a post-WWII variant.
EDIT (not using clunky iPad now): is that on the forum, Dizzy?
Quote from: kitbasher on April 28, 2026, 11:09:33 PM
kitbasher is lost for words!
(Again, if I remember correctly.)
Quote from: Old Wombat on April 29, 2026, 12:33:24 AM
Jeez it's the clunky iPad, must remember not to use it for the forum 🤬
See that post's edit.
Yes, must be, somewhere. Was called F6F-7 - if you cannot find it, the description is in the link to my FlickR albums below.
1:72 Grumman F6F-7N "Hellcat", aircraft '29/WF' of United States Marines Corps (USMC) VMF(N)-513, based at Kunsan AB, Korea, 1953 (Whif/kit conversion)
by Dizzyfugu, on Flickr
Here it is: https://www.whatifmodellers.com/index.php?topic=38957.msg641492#msg641492  :lol:
Cheerrs Dizzy,
Top build  :thumbsup:
I see I commented on it at the time (mind you it was a 2014 build and scope for 'senior moments' have been on the rise since!).  Mine won't look as Bearcat as your's did.
Jennings Heilig's F6F-7 from yonks back. I saved all of the profiles that Madoc Pope
used to host. They're all good old days dial-up low res.
Quote from: jcf on April 29, 2026, 05:00:45 PMdial-up low res.
A bit like my builds!
Anyway, that profile is how I imagine my bubbletop Hellcat will look, some minor differences in the windscreen because of what I'm using for that.
