avatar_buzzbomb
Steam Landship
Started by buzzbomb, February 02, 2026, 09:03:12 PM
Or clockwork even? With a BIG key to wind it up?  ;D
Quote from: steelpillow on February 07, 2026, 02:14:08 AM
Quote from: Weaver on February 07, 2026, 12:18:42 AMThe enemy would be sitting in their trenches, getting more and more nervous, unable to see anything, just hearing the low thumping of steam engines, the clank of tracks and the occasional whistle...
Love it!!!
Meanwhile a couple of scouts are sent out to set up decoy whistles, which sound off regularly for up to two hours, depending on the filling of the firebox.
Heh - the steam equivalent of ECM/ECCM, but measured in decibels and psi instead of watts... :wacko:
perttime
Where do they keep the fuel?
Glorious! Carry On, Good Sir!  :thumbsup:
Quote from: perttime on February 07, 2026, 11:38:08 AMWhere do they keep the fuel?
Where's it carried on most steampunk contraptions?  :unsure:
My answer: In Mary Poppins' handbag!  ;)
Quote from: Old Wombat on February 08, 2026, 12:41:56 AM
Or, in an armoured, tracked tender?
steelpillow
Quote from: zenrat on February 08, 2026, 02:26:35 AMOr, in an armoured, tracked tender?
This IS the tender. You should see the tank!
Cheers.
PFJN
Hi.
Maybe you can add a plow on front and it could chew up and burn any trees, shrubs and/or peaty Bog that it digs up  :unsure:
The High Concentration Compressed Carboniferous Media, will be under the hatch named bunker
For major engineering.. this is just about it.
Front and rear 'Undulating Terrain Re-adjustment Stabilizers"
Machine Guns also finished. Maybe, they may get a forward strap around them
Frontal aspect, the front stabilizer wheels do have return springs, plus the not so fat controller who is under contruction.
The main event really, most of the build effort was around here after the initial construction. With all the cables and bits in place. Engineering committee met and Coolie hat stack protectors - Approved  ;)
Still work in progress though
Rear Stabilizers, had to clear the door. Need to fix the wonky one.
Now some dabbling with some Steampunky filigree ironwork, just using what I have without sourcing elsewhere at this stage. Just white glued on while I am at sit and contemplate mode
This might be it for a month, as I am off on holiday at the end of the week.  I do want to see it in primer though, lets see how it goes.
A) Enjoy your holiday  :thumbsup:
B) Whats the guy with the chef's hats job ? On board cook ?  :angel:
steelpillow
Quote from: NARSES2 on February 10, 2026, 05:08:21 AMWhats the guy with the chef's hats job ? On board cook ?
Oh no, not steamed pudding again! :D
Cheers.
"What's the matter with The Fat Cont-, with The Fat Cont-, with The Fat Controller?" asked Harry, who had an unfortunate stammer...  ;D  :angel:
Quote from: NARSES2 on February 10, 2026, 05:08:21 AMA) Enjoy your holiday  :thumbsup:
Chris take a closer look bud..its a top hat ..classic head gear in the steampunk world  ;D
Not sure about the filigree work, but the rest of it is coming along great guns!  :thumbsup:  :thumbsup:
Loving how this is coming together!
