avatar_Spino
Cold War Ragtag Armor Platoon
Started by Spino, December 18, 2025, 04:12:05 PM
Spino
I don't play World of Tanks either (anymore), I just posted those photos to show more or less the kind of look I'm going for with these vehicles.
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
Spino
Anyway, enough about silly video games that no one plays.  I have now printed one of two MQM-57 drones for this set, as well as hulls for the T110E6 and T57, and the turrets for the T57 and M103A2.
Unfortunately on closer inspection the gun tubes on the T110E6, T57, and M103 are all different diameters, with the M103's gun tube being the largest.  Since all three of said vehicles are supposed to have nearly the exact same gun, this is an issue!  Still trying to decide if it's worth it to print two more M103 gun barrels and graft them on to the existing turrets, or just explain this discrepancy away with some good old-fashioned whiffery.  I do have an idea about the T110E6, the US did do some work on 90mm smoothbore guns in the 1950s, so maybe I'll just use that as the reason for the smaller barrel on the T110.
I did assemble the first MQM-57, the second one will probably be broken down into its fuselage and wing sections.  It's so big that I'm considering just having a trailer with the drone, launcher, and antenna on it!
Regards, Spino
Steel Penguin
go with the same gun tube but different thicknesses on the thermal jacket   :thumbsup:
alternatively go for a heavy camo netting on them and wrap the barrels in gauze for that effect
or a heavy natural cammo, with cut turf on flat surfaces, branches and brush in grab rails and behind things, and a load of bark on the barrel so it looks like a fallen tree when its hull down
Spino
Quote from: Steel Penguin on December 22, 2025, 02:04:02 PMgo with the same gun tube but different thicknesses on the thermal jacket   :thumbsup:
Those are all quite good ideas, thanks!
Regards, Spino
If i remember rightly you've got like 105mm ..120mm and 155mm guns on those three tanks Spino mate ..back in the day before guns like the British L7 came onto the scene.
Penguin has ya covered very nicely with that problem  :thumbsup:
Spino
Quote from: Wardukw on December 22, 2025, 09:45:34 PMIf i remember rightly you've got like 105mm ..120mm and 155mm guns on those three tanks Spino mate ..back in the day before guns like the British L7 came onto the scene.
Technically they are all supposed to be variants of the same 120mm M58 gun found on the M103.  There was an oscillating turret tank proposal based on the M103 hull that would have mounted a modified 155mm T7 gun, but that was the T58 Heavy Tank, not the T57.  The T58 is actually one of the vehicles I'm planning to make with this set, so perhaps I'll just scrap the T57 turret and replace it with a T58 turret since the rest of the tank is externally the same.  The T57 was essentially just an M103 with a slightly modified 120mm gun paired with a revolver-style autoloader in an oscillating turret.  And the T110 was supposed to have a 120mm gun as well, I believe the same M58 as fitted to the M103.  One of the whiffery elements of these heavy tanks is that I'm using M103A2 hulls, so these tanks would either be upgraded versions of the original proposals or just took so much time to develop that it made sense to just have the better engine of the M103A2/M60 by the time they were ready.
On a side note, I have had to log in on a separate browser profile for the second time in order to view anything on the Whatifmodellers site.  I keep getting an error that says I am a guest and have been permanently banned for "iffy links in first post".  When I try to login, I get the same message.  First I switched to a different browser yesterday and that solved the problem (or so I thought), but this morning I had to change internet browsers again to get on here because I was getting the same error.  Not sure what is going on with that.
Regards, Spino
Supertom
Quote from: Spino on December 23, 2025, 07:47:57 AM
If you get that again, would you send us a screenshot? Thanks.
Spino
Quote from: Supertom on December 23, 2025, 09:36:57 AMIf you get that again, would you send us a screenshot? Thanks.
Sure, here it is:
And here's what happened when I clicked the login button:
Regards, Spino
Quote from: Spino on December 23, 2025, 10:32:16 AM
Sure, here it is:
Thats exactly what i'm seeing too when i open with Chrome Tom ..again just like everyone else right now ,,just came out of the blue .
Spino mate you could just use a cheat code since this is Wiffy World after all and just stick with those same 3 guns and still keep em all at 120mm and the reason for the differences in thickness ??
Simplies ..the bores are still 120mm but the outer barrel is thicker dew to one reason for another ,,barrel tech moving with leaps and bounds as it does ,,couple of em a test beds for thinner experimental gun tubes to test overall barrel life ,,this is know to be true as it's been done many times in the RW so thats and excuse you could use and it'll be a true one  ;D
Spino
Quote from: Wardukw on December 23, 2025, 10:46:27 AMThats exactly what i'm seeing too when i open with Chrome Tom ..again just like everyone else right now ,,just came out of the blue .
Funny you should say that, the first time I encountered it I was using Firefox.  I switched to Chrome, it worked for a day, and then gave me the same issue this morning.  So I have now switched to a different Chrome profile for today, hopefully it doesn't kick this one out tomorrow because I'm running out of options.
Quote from: Wardukw on December 23, 2025, 10:46:27 AMSpino mate you could just use a cheat code since this is Wiffy World after all and just stick with those same 3 guns and still keep em all at 120mm and the reason for the differences in thickness ??
You make a good point, I didn't think of that.  I might just do that, we shall see.
Regards, Spino
Yeah this internet banning bollocks is bloody annoying and i do wonder what it could be as i bet you do ,, my google did update yesterday and then everything went into the poop bowl after that so that leads me to believe that the update boned us ,,but then firefox goes all silly buggers as well ,,this still works fine with my phone so thats good an firefox is working fine to.
The strange thing to me about this is that all my other saved pages have zero problems ,,it's like our site is being targeted with all the crap we've been getting as of late ...if it is some dude dicking with us oh how i'd love to find em and do things i can't talk about here cause that will upset Chris and we don't want that now do we ?  ;D  ;D
Spino
Quote from: Wardukw on December 23, 2025, 05:44:25 PMYeah this internet banning bollocks is bloody annoying and i do wonder what it could be as i bet you do ,, my google did update yesterday and then everything went into the poop bowl after that so that leads me to believe that the update boned us ,,but then firefox goes all silly buggers as well ,,this still works fine with my phone so thats good an firefox is working fine to.
Can't say that I blame you.
Regards, Spino
Same thing happened to me (as I said in the other thread). All I did was shut down my computer & re-start it. No issues since.
Spino
Quote from: Old Wombat on December 23, 2025, 11:53:03 PMSame thing happened to me (as I said in the other thread). All I did was shut down my computer & re-start it. No issues since.
Wish that was all there was to it on my end, but that doesn't seem to be the case.  Restarting my computer didn't help anything unfortunately.
Regards, Spino
The tanks are looking great ! Love the big guns
