Main Menu
avatar_NARSES2
General Discussion
Started by NARSES2, November 01, 2025, 05:47:06 AM
Thinking a loud what about a hovercraft train? The bridge ahead is damaged so the train floats across the river/lake, then drives along the road until it can find the track again.
Quote from: TomZ on November 02, 2025, 04:46:30 AM
Quote from: McColm on November 02, 2025, 04:28:38 AMOkay,  what about a 'Flying Jeep' ?
Or a powered Hafner Rotabuggy , other 4x4s could be used?
That could go but do keep in mind that it can't add or shed parts when going from one environment to another. So the rotor or wings would have to stay on while driving.
TomZ
The Hafner Rotabuggy didn't have any wings, just a tail section and a autogyro rotor, no moving rudder. It actually worked. My version would use the vehicle's engine to power the rotor or rotors. Which would be folded when in driving mode.
Quote from: McColm on November 02, 2025, 05:04:11 AMThinking a loud what about a hovercraft train? The bridge ahead is damaged so the train floats across the river/lake, then drives along the road until it can find the track
again.
That'd need one HEFTY sized road to take a train of any sort! And quite how you'd guide a hover-train without it looking like the Tracked Hovercraft test vehicle at Peterborough I'm not sure.
But it would fit the requirements of the GB.
Quote from: PR19_Kit on November 02, 2025, 05:28:51 AM
again.
If this idea was based on the Australian O-Bhan Transpress (single decker bus that can run on rails and the road) just needs the inflatable skirt and the other bits that fold flat on the roof when not in use.
Andrew Gorman
Another real world true amphibian, the Arktos Evacuation Craft:
https://www.arktoscraft.com/
Quote from: Andrew Gorman on November 02, 2025, 08:43:26 AMAnother real world true amphibian, the Arktos Evacuation Craft:
Now that would be fun! Cross a DUKW with a snow cat.
Quote from: McColm on November 02, 2025, 06:16:47 AMIf this idea was based on the Australian O-Bhan Transpress (single decker bus that can run on rails and the road) just needs the inflatable skirt and the other bits that fold flat on the roof when not in use.
OK, I read up on that and it's very clever. But in your scenario how would it 'fly' over a bridge? A hover pad underneath it wouldn't lift it high enough, you'd need a semi-Ekranoplan system to do that.
Which may work in this GB, I'll talk to my fellow mod.
Joe CalPo
Have to see what's left in the spares boxes, I have an idea.
 ;D
Joe
Quote from: PR19_Kit on November 02, 2025, 09:10:27 AM
It's not meant to fly, it goes around the obstacle, crossing the river by means of the inflatable skirt and the pop-up directional fans on the roof. Besides if it has wings it's going to be too wide for the roads in the UK and might get stuck in a tunnel!
So are Ekranoplans allowed in this GB?
TomZ
Quote from: McColm on November 02, 2025, 12:39:47 PMSo are Ekranoplans allowed in this GB?
Ah... Finally. We anticipated this one  ;D  ;D
Ekranoplans are a bit of a borderline issue. Strictly speaking they just operate in the air but after a lot of thought and copious quantities of whisky, we decided that the fact that Ekranoplans are normally very close to water but also can achieve respectable heights, will qualify them as eligible in this group build.
TomZ
Quote from: TomZ on November 02, 2025, 12:47:43 PM
TomZ
Thanks, being a Moderator can be very tricky when trying to define the parameters of the GB. I tried to restrict what could qualify but it backfired, however we all learn from making mistakes.
So if I understand the rules ; flying boats with retractable wheels, floatplanes, helicopters, aircraft with skis and heliplanes are all banned. What about vehicles related to TV, films, books and Sci-fi?
Inspiration:
Australian prototype amphibious Land Rover;
Link: http://anzacsteel.hobbyvista.com/othervehicles/landroverph_3.htm
perttime
"The ITEC Maverick is a powered parachute aircraft with a roadable fuselage."
https://en.wikipedia.org/wiki/I-TEC_Maverick
TomZ
Quote from: McColm on November 02, 2025, 10:04:39 PMWhat about vehicles related to TV, films, books and Sci-fi?
The rules don't say anything about movies, films, etc. So as long as the build fits within the rules, that will be fine. Go for it, I would say!
TomZ
