avatar_Dizzyfugu
DONE @ p.8 +++ Saab J31B, Flygvapnet F1 Västmanland Flygflottilj, late Fifties
Started by Dizzyfugu, September 06, 2025, 02:56:47 AM
Look forward to the rest.  <_<
(NOT a hurry-up, just a comment. In your own time.)
If is wasn't for the tyres needing to be slightly flattened/bulged there'd be nothing to indicate that this is actually a model in those B&W shots.  :thumbsup:  :thumbsup:
Finally, and given the circumstances under which this was created/built it looks really good.  <_<
1:72 SAAB J31B 'Val'; 'Blue T/Blå Tore (s/n 31040)' of the Swedish Air Force (Flygvapnet) F1 Västmanland Flygflottilj, 2nd Squadron; Hässlö AB, Västerås (Central Sweden), 1956 (What-if/kitbashing)
by Dizzyfugu, on Flickr
Some background:
The SAAB B31 was a Swedish jet-powered multirole aircraft, originally designed to serve as a tactical bomber, ground attack, reconnaissance and interceptor aircraft. In the aftermath of the Second World War, Sweden set about the rebuilding and modernization of its armed forces. Regarding aviation, jet propulsion had been identified as the powerplant of the future, and experience with the SAAB 21R, which had been converted from a propeller-pusher aircraft into a jet-powered fighter and attack aircraft in 1947, bolstered confidence in the home industry's competence. The Saab 21R was only an interim solution, though. One hundred and twenty-four aircraft were planned but this number was reduced to only 64 and they were mainly used as fighter-bombers. The Flygvapnet's standard post-war bomber, the Saab 18, a twin piston-engine design from 1944, was outdated, too, and its performance was regarded as inadequate for the Fifties. This led to a major development initiative for modern jet aircraft for the Flygvapnet in 1946, which spawned the Saab 29 'Tunnan' fighter and the Saab B31 light bomber. Both aircraft were initially designed around the de Havilland Goblin turbojet of British origin, but when the more powerful de Havilland Ghost became available, this was chosen as the standard powerplant. Both aircraft incorporated such modern features as swept wings or ejection seats.
The Saab B31 was originally developed as a straightforward tactical bomber replacement for the Saab 18, called the Saab B31, which would carry its free-fall ordnance internally in a bomb bay. The Saab B31 had a streamlined, drop-shaped fuselage. A crew of two were envisioned, the pilot and a navigator/bomb aimer. They would sit in separate cabins, a generously glazed nose section with an optical bombsight and a navigational/bomb aiming radar in a shallow blister underneath, and in a fighter-type cockpit on top of the hull, respectively. Swept wings were planned that would offer a good compromise between speed benefits and range/lift. Due to the aircraft's size and weight, two de Havilland Ghost engines were required, but integrating these bulky centrifugal flow engines with a relatively large diameter turned out to be a design challenge.
Several layouts were evaluated, including engines buried in the rear fuselage with side air intakes, or engines mounted in wing root fairings with individual exhausts at the wings' trailing edge. Eventually the Saab B31's powerplants were directly mounted in nacelles under slightly swept (20°) shoulder wings, what made access and maintenance easy and kept the fuselage free for a huge fuel capacity, a generous bomb bay, and a conventional tricycle main landing gear. The latter's tread width was quite narrow, though, which might have caused handling problems, so that during the bomber's design refinements the landing gear arrangement was radically changed into a tandem layout. It eventually comprised of two main struts featuring large low-pressure twin wheels, supported by small outrigger wheels that semi-retracted into fairings under the bulbous engine nacelles. While unusual, this arrangement had the side benefit that the bomb bay could be lengthened and the fuel capacity in the fuselage could be increased without a center of gravity shift, with the rear/main landing gear strut well placed further aft, well behind the aircraft's center of gravity. This, however, prevented normal rotation upon take-off, so that the front strut was lengthened to provide the aircraft with an imminent positive angle of attack while rolling, giving the Saab B31 a distinctive nose-up stance on the ground.
The enlarged bomb bay could hold up to four free-fall 340 kg bombs, the B31's primary weapon. Additional ordinance, typically two further single bombs of up to 500 kg caliber, pods with unguided missiles, or drop tanks to extend range, could be carried on a pair of hard points outside of the engine nacelles. The maximum total payload was 2.400 kg. No offensive or defensive guns were carried, the B31 was supposed to rely only on speed and agility. Large air brakes on the aircraft's flanks were introduced to prevent the exceeding of the B31's design speed limit of Mach 0.9 in a dive, and they also helped to slow down the aircraft upon landing. To reduce the landing run length further a brake parachute was housed in an extended teardrop fairing on the fin that also held the swept horizontal stabilizers.
Overall, the Saab B31 reminded vaguely of the Soviet Yak-120/25 (NATO code Flashlight A) and of the French Sud-Ouest SO.4050 Vautour, which were both under development at the same time. Beyond the original tactical bomber role that was supposed to supersede the Swedish B 18, the Saab B31 was also intended to fulfill night/all-weather reconnaissance missions, outfitted with a camera and sensor pallet in the bomb bay and flash bombs on the wing hardpoints. Furthermore, the aircraft was proposed to become, in a second step, the basis for a jet-powered long-range all-weather fighter, a type of aircraft that was direly needed by Flygvapnet during the late Forties. The situation was so severe and urgent that the Swedish Air Force did not want to wait for a J31 development and had to procure sixty radar-equipped de Havilland Mosquito NF.30 night fighters from Great Britain as a hasty stopgap solution – a totally outdated model in the late Forties, but it was the best and only readily available off-the-rack solution.
In parallel, both engine and aircraft technology underwent dramatic developments and literally made leaps: In December 1948, an initial contract for the design and mockup of Saab's newly proposed P.1150 design was issued, a modern swept-wing design that already represented the next, transonic fighter aircraft generation. The resulting aircraft would become the Saab 32 'Lansen' and it literally overtook the B31's intended role as the Saab 18 bomber and attack aircraft replacement. However, a modern all-weather fighter with long range and a powerful radar was still not on the horizon, and, consequently, the Saab B31's original bomber/reconnaissance version was dropped completely in favor of an optimized interceptor derivative with a powerful on-board radar: the J31. This was, however, also just a stopgap solution until an all-weather fighter version of the favored Saab 32 would be ready for service, so that a single aircraft type would take over multiple military roles and therewith simplify production, maintenance and logistics.
From that point on the Saab B31 was re-designed and optimized for a principal fighter role, with an attack capability as a secondary capability. However, due to its bomber origins and its intended mission profile the J31 was not intended to be a typical sleek and nimble dogfighter (that was the contemporary Saab 29's role as a day fighter, even though a radar-equipped version of the Tunnan was on Saab's drawing boards, too, yet not realized because compact systems were not available), but rather as a standoff night fighter which would loiter on station and patrol the air space, search for targets and then identify and engage them.
The bomber's large air brakes were a welcome feature to position the approaching fighter behind a potential slower target, which were primarily relatively cumbersome bombers that would come in at medium to high altitude and at subsonic speed. This mission profile heavily influenced the J31 design and also set boundaries that were later hard to overcome and develop the aircraft's potential further. While the light bomber basis would meet the required demands concerning range, speed and limited agility, the obligatory radar and its periphery to fulfill the N/AW fighter mission led to a major re-design of the forward fuselage. A large radar dish under a solid nose radome now occupied the formerly glazed nose section, and the radar operator was placed together with the pilot in a new pressurized side-by-side cockpit under a common canopy. A large and relatively flat forward windshield was used; while not conducive to high-speed flight, it provided distortion-free external visibility, something that was particularly valued for a night fighter at that time. Both pilot and navigator/radar operator had full steering equipment, what also made a dedicated trainer version unnecessary. Both sticks were extendable so that more force could be exerted upon it by the pilot as a fallback measure in the event of a hydraulic failure. Bleed air from the engines was used to de-ice the wings' and tail surfaces' leading edges and the engines' air intakes, so that the aircraft could operate even in harsh climatic conditions.
Radar and fire control system for the J31 were created and produced by Ericsson and called "Gryning" (= Dawn). The system was quite advanced for the time even though complex: a combination of three different radars, each performing separate functions. The system comprised a search radar, a tracking radar, both located in the nose under a huge mutual radome, and a tail warning radar with a separate, smaller antenna. The search radar covered the front hemisphere and could detect aircraft at distances up to 35 kilometres (about 20 miles) away while the tracking radar could achieve a weapons lock up to 4 km (2.5 miles) away. Additionally, the Gryning system had a limited look-down capability, being able to detect aircraft that flew underneath the J31 at an altitude of down to 800 m (2.600 ft). The tail-mounted surveillance radar was effective up to 15 km (almost 10 miles) away. The complexity of this vacuum tube-based radar system, produced before the advent of semiconductor electronics, required a lot of internal space and intensive maintenance to keep it operating properly – and it would have been much too big or heavy to fit into the more modern but also more slender Saab 32 airframe.
The armament was changed, too. While the B31 bomber was intended to carry no guns at all the fighter derivative was now armed with four 20 mm cannon in the lower nose, plus two retractable unguided air-to-air missile racks in the former bomb bay in tandem, carrying a total of 96 projectiles, which were supposed to be fired singly, short bursts or in one or more massive salvoes against bomber formations, covering a huge field of fire and ensuring a takedown even with a single hit. This core armament was complemented by a pair of underwing hardpoints outside of the engine nacelles which could carry pods with further 18 unguided missiles each, iron bombs of up to 500 kg calibre for a secondary attack capability, or 570 l drop tanks to extend the J31's range and loiter time.
An initial order for three prototypes was placed by the Swedish government, and on 16 October 1950, the first J31, even though still lacking the radar, conducted its maiden flight. The flight test program proceeded relatively smoothly, but the performance was rather poor for a fighter. More powerful engines were required, but choices for Saab were very limited. The use of the Saab 29's indigenous afterburner variant of the Ghost (which was by then license-produced in Sweden as the Svenska Flygmotor RM2) was deemed inefficient for the large aircraft, so that attempts were made to improve the Ghost's dry thrust for the J31 without an increased fuel consumption through reheat. This new indigenous engine variant became the RM2F ("förstärkt" = "powered-up"), which provided 5,400 lbf (24.02 kN) of thrust with water-alcohol injection instead of the RM2's original dry 5,000 lbf (22 kN) maximum thrust. The tank for the required water-alcohol mixture was carried in the rear half of the former bomb bay and replaced one of the unguided missile racks. These were hardly ever used operationally, though, and soon completely removed, replaced by a second water-alcohol tank, which gave the aircraft enough endurance of 30 minutes at the increased thrust output level.
A follow-on order for six pre-production aircraft was soon received, which were still equipped with the weaker original RM2 and designated J31A. These machines were delivered to F 1 Västmanland Flygflottilj at Hässlö air base in Central Sweden, which just had been converted from a bomber to a night fighter unit, having been equipped with the J 30 Mosquitos. There the J31 was evaluated against the J30 until early 1951 and deemed superior in almost every aspect. With these satisfactory results, a full production order for 54 more aircraft was placed in mid-1951. These machines were now outfitted with more powerful RM2F engines and other refinements and designated J31B. This became the type's operational main variant. All were delivered to F 1 where they were exclusively operated and gradually replaced the J 30s. In service the J31 received the unofficial nickname "Val" (= Whale), due to its bulky yet streamlined shape, but it was officially never adopted.
During regular maintenance in the following two years, the six early J31As received the stronger RM2F, together with the second water-alcohol tank as well as some avionics updates and were accordingly re-designated J31Bs. Further updates included wipers for the windscreen (a serious issue esp. at slow speed and while taxiing) and two smaller brake parachutes instead of the single large original one.
All J31s were delivered in a natural metal finish and retained it throughout their career; only two machines ever received camouflage during trials, but this measure was deemed unnecessary for the aircraft due to their role. Some aircraft of F 1's 3rd squadron and operated by the unit's staff flight had the aircrafts' fins painted in dark green, though, to improve the contrast to the tactical code letters' colour, yellow or white, respectively. The J31s' radomes were made from fiberglass and originally tinted in opaque black. During maintenance and after damage, however, some machines received newly produced replacement fairings which were untinted/semi-transparent.
The only major update the J31B received was rolled out starting in 1958, when the IR-guided Rb24 (AIM-9B Sidewinder AAM) was introduced in the Swedish Air Force. Together with the J29 Tunnan fighters the J31s were outfitted to carry launch rails on the wing hardpoints – even though only a single pair could be carried in total. This, however, markedly improved the type's combat efficiency, and it would take until the Saab 35F in 1965 with its Rb27/28 Falcon missiles to introduce more capable guided anti-aircraft missiles. Since the Rb24s extended the J31's weapon range considerably, a potential gun upgrade with 30 mm cannons was not executed and Saab's resources rather allocated into the Saab 32's development.
Even though the J31B was a capable night and all-weather fighter for its time, it was limited due to its outdated weaponry and quickly superseded by advancing radar, engine and aerodynamic technologies. It did its job but lacked development and performance potential – and it was a large and complicated aircraft that required lots of maintenance. However, the J31 turned out to be a very stable and robust weapon platform, and it was quite popular among the crews because of the spacious cockpit, even though the field of view on the ground was very limited, due to the tall landing gear front leg, and several J31s were involved in taxiing accidents. Due to its twin engines and radar intercept operator, pilots gained more confidence on long missions in the remote northern areas of. Sweden, esp. on mission over open water.
When the Saab 32's fighter version, the J 32B, eventually became operational in 1958, it was clear that the heavy and highly limited twin-engine J31B would not remain in service for much longer. By 1963 all machines had been retired from frontline service, initially stored in reserve but scrapped by 1970. Two machines remained operational, though: as flying test beds for the Swedish Air Force's Försökscentralen (FC) at Malmen AB, where they served until 1981 – primarily to test radar and missile guidance systems, and as radar targets for war games and anti-aircraft unit trainings
General characteristics:
    Crew: 2
    Length: 15,76 m (51 ft 7 1/2 in)
    Wingspan: 16.96 m (55 ft 2/3 in)
    Height: 4,21 m (13 ft 9 1/2 in)
    Wing area: 45 m2 (480 sq ft)
    Empty weight: 9,000 kg (19,823 lb)
    Gross weight: 17,500 kg (38,546 lb)
    Max takeoff weight: 19,000 kg (41,850 lb)
    Fuel capacity: 5,100 L (1,350 US gal / 1,120 imp gal) maximum internal fuel
                          plus 2x 570 L (150 US gal, 120 imp gal) optional drop-tanks
Powerplant:
    2× Svenska Flygmotor RM2F centrifugal-flow turbojet engine (Rolls Royce Ghost), each with
          4,750 lbf (21.1 kN) dry thrust at 10,250 rpm and
          5,400 lbf (24.02 kN) with temporary water-alcohol injection
Performance:
    Maximum speed: 1,090 km/h (677 mph, 588 kn; Mach 0.9) at 10,000 ft (3,000 m)
    Cruise speed: 732 km/h (455 mph, 395 kn)
    Stall speed: 150 km/h (92.8 mph, 80.6 kn) with approach power
    Combat range: 1.850 km (1,145 mi, 995 nmi) on internals
    Ferry range: 2.200 km (1,375 mi, 1,195 nmi) with 2× 570 l drop-tanks
    Service ceiling: 16,200 m (53,062 ft)
    Rate of climb: 40 m/s (7.681 ft/min)
    Wing loading: 87.1 lb/sq ft (388 kg/m²)
    Thrust/weight: 0.32
Armament:
    4× 20 mm (0.79 in) akan m/47C (license produced Hispano Mark V) autocannon with 220 RPG
    48× 75 mm (3.0 in) srak m/55 (Bofors 75 mm (3.0 in) rocket "Frida") unguided air-to-air missiles
          with contact fuze high-capacity warhead on retractable rack in ventral bay
          (not used operationally, later completely deleted in favor of a second water-alcohol tank)
    2× wet underwing hardpoints outside of the engine nacelles for 600 kg (1.321 lb) each;
        alternatively a pair of Rb24 (AIM9-B Sidewinder) IR-guided air-to-air missiles
It might not look spectacular or exciting, but I am quite proud of this "second" J31, because it not only was a major kitbashing project, it also conveys the Fifties "look and feel" I wanted to catch, like its contemporaries S.O. 4050 Vautour, Yak-25, or even the stillborn Baade Ba-152 airliner. From that point it turned out very well, and going for a simple NMF livery was IMHO also a good move – the J31 has a certain "space age" look? At least, this is what you can get when you combine major parts from F3D, B-47. B1, Il-28, Su-25, Tu-95 and a Gloster Meteor... 😉
