avatar_chrisonord
Dornier Do. P. 206
Started by chrisonord, July 08, 2025, 09:46:35 AM
This is what I have done so far to What I had posted in the ideas thread. The kit is the hobbyboss Do 335 in 72 and scale, the engines are resin Jumo 's from Lonewulf. The kit is near as damn it a snap together one, but it needs a lot of sanding and putty especially on the joints. I have drilled the wing roots to put 20 mm cannon in, and the nose will house a radar. The rocket motor is a piece of tubing with a rocket nozzle from a Douglas skyrocket. I am going to paint it in nachtjagger colours, but with captured by the ministry of Axis Acquisitions RAF roundels
I hope this is not too much of a problem for you, but the engines appear to be on backwards. Are you sure it's not Italian?
Spino
It does look like they are backwards, but I'm also assuming they are just sitting under the wings and haven't actually been attached yet.
Nice concept, I would say it makes the Do-335 a lot safer for the pilot, but German rocket motors weren't exactly known for being safe  ;D
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
I had put them on the wrong way round. :banghead:  :banghead:  I was using pictures from a book I have as reference, as the supplied instructions are a tad faded and vague. The engines are a pain to get in the right place as they are not identical where they glue on, so several attempts were made to get them to look half right. I am thinking of the rocket motors being solid fueled, with the air scoop either to cool the area exposed to the heat, or it is a ram air scoop for the rocket, to give added boost.
Spino
Could be a pulse-jet instead.  The Germans were known for those, and it would be using the same fuel supply as the turbojets (though that has its downsides as well).  Probably wouldn't provide as much thrust as a rocket motor though.
Regards, Spino
For a rocket engine the tail nozzle is very big, and for a pulse jet you'd need proper intakes, with a very clean air flow.
Quote from: Dizzyfugu on July 09, 2025, 12:18:05 AMFor a rocket engine the tail nozzle is very big, and for a pulse jet you'd need proper intakes, with a very clean air flow.
there are four outlets in the nozzle, and the rocket motor is an experimental add on.
I have found a picture of a mixed propulsion Dornier P. 254 in a night fighter scheme, so I am thinking of doing my interpretation of it on this. Shouldn't be too difficult to do, as I am priming it in black also
Been doing some more work to this, and the tamiya tape has left its glue on the underside of the fuselage  :banghead:  :banghead: I have had to scrape off the glue, and sand it carefully down. Now to mask it again, and hopefully it doesn't do it again.
Quote from: Spino on July 08, 2025, 11:40:48 AMGerman rocket motors weren't exactly known for being safe  ;D
Nothing wrong with German Rocket Motors of that time, just the fuel they used. Solid propellant motors were not a thing during the time either.
Nearly done now. I found out that the tamiya tape was not the problem, it was the black primer I had used, so yet more scraping and sanding had to be done. Just matt clear coat, landing gear and the wing root cannons to fit.
I am calling this done. The aircraft is another captured prototype acquired by the ministry of Axis Acquisitions in Germany, and pilffered from underneath the Americans noses. The aircraft was a complete and running aircraft, and instead of taking it apart and trucking it out, it was flown out under escort of 2 mosquito nightfighter, under the cover of darkness. The radar is the same as what is fitted to the Arado AR 234p, and the pilot was familiar with how it works. The aircraft was tested mostly at night to learn more about the radar and sophisticated aiming and targeting system fitted.
The build was quite an easy one, but the airbrush spat its dummy on several occasions, hence the larger blotches. Be reet.
Looks good Chris  :thumbsup:
Anyone who can make a 335 look even reasonably sleek & slim deserves a gong  ;D
Quote from: NARSES2 on September 06, 2025, 12:31:00 AMLooks good Chris  :thumbsup:
Thankyou Chris, the bad paint job is starting to grow on me at least.
