avatar_frank2056
Spalah 1/35 Resting Staker
Started by frank2056, July 02, 2025, 08:31:13 PM
frank2056
This is going to be both a build and brief technical study of the "Resting Staker from Universe of "STALKER" games": Spalah Stalker
First off, this is a flawless 3D print. There are no layer lines visible, so they're printing with around 20um (micron) layer height and roughly 20um pixel size. The painting guide is a color sheet with color callouts. There's what appears to be a flat spot at the top of the head, but it's more apparent in the pictures than on the print. So maybe a 99.9% flawless print.
For fellow 3D printers, their supports are interesting. They're using medium or small supports with a small contact area (The contact area is 0.35-0.4mm) and they use quite a few. The result is again, a flawless print with no deformation of the part. Here's zoom from their ATV Quadrobike
The box contains the stalker, a wooden (ammo?) box and an axe. Here's the figure right out of the box:
I removed the supports with care. One trick when removing supports from a thick or large piece is to use a hair dryer on high on the supports for about 10 seconds. This softens the contact points and the supports can be removed with a finger, leaving little or no damage on the part. This only works on thick or large parts that have a higher thermal mass than the supports, so they don't deform. If the part is thin, or is the diameter of the supports or smaller, the hair dryer method will deform the part or break it off. Use caution. For instance, I cut the supports from the fingers and from the axe with cutters, first, but used the hair dryer on the underside of the figure and on the box.
Here is the figure, ready to paint:
Thanks for the tip re the haidryer  :thumbsup:  Just got my first 3D printed parts and can see me getting more.
I want to buy their complete STALKER range!  :wub:
Whether I do or not is another question entirely!  :rolleyes:
So, I'll be watching!  ;)
Apropos of nothing;
I received a Legend Productions "LBT Assault Pack w/Gerber Tomahawk Set" today - this one was traditional cast resin, the previous set I bought was 3D printed.  :unsure:
frank2056
Quote from: NARSES2 on July 03, 2025, 12:45:11 AMThanks for the tip re the haidryer  :thumbsup:  Just got my first 3D printed parts and can see me getting more.
Be very careful, because the heat will soften the resin quite a bit. If the part has thin (1-2mm) walls or thickness, just snip the supports off.
Quote from: frank2056 on July 03, 2025, 08:13:40 AM
Noted  :thumbsup:
frank2056
Mostly finished. I missed a couple of shading spots and maybe a coat of flat (some of the shiny spots are shiny because they're still wet). Great little figure kit. I have several more like it.
Outdoors, with a rusty old satellite dish in the background. I used Tamiya interference  material for the goggles:
The fingernails are a slightly redder color, but they don't show in these pictures:
Indoors, on a rocky alpine mat:
He's looking really good, Frank!  :thumbsup:
But, with all those ammo pouches, I'd be giving him an AK or similar. ;)
What's 'Tamiya Interference Material'? I've never heard of it before.
frank2056
Quote from: PR19_Kit on July 07, 2025, 09:36:46 PMWhat's 'Tamiya Interference Material'? I've never heard of it before.
It's also known as an "anti reflection coating" but optically, they're thin film interference filters.
Anyway, they're made by Hasegawa, not Tamiya...
Trim Film Polarize Finish Brown-Cyan TF903
The sheets are hard to find now.
AFV Club do them, too, but usually cut to suit certain AFV models.
Quote from: Old Wombat on July 07, 2025, 06:30:07 PMBut, with all those ammo pouches, I'd be giving him an AK or similar. ;)
I had similar pouches for my M-16 in Iraq, but the whole plate carrier set up screams "Russian" to me.
Quote from: frank2056 on July 08, 2025, 03:38:52 PMIt's also known as an "anti reflection coating" but optically, they're thin film interference filters.
Oh thanks, not something I've ever come across before.
frank2056
Quote from: scooter on July 09, 2025, 02:10:00 AMI had similar pouches for my M-16 in Iraq, but the whole plate carrier set up screams "Russian" to me.
Definitely Russian, since the STALKER game was set in the area - and going by some of the Russians in Ukraine, the plate was probably bought at Temu...
I've seen pics in the early stages of the war where Ukrainian troops who were wearing that russian crap and carrying M4's ....this was not long after the US and NATO started to supply Ukraine with our gear ,,it wasnt long after those pics  that  they started to wear alot more western plate armour rigs. .
So if you throw an M4 or M16 at that dude Frank you'd be good to go  ;D
