A 'virtual' Short Super Sealand amphibian - SORTED!
Started by PR19_Kit, June 23, 2025, 12:32:45 PM
They're £16 at Hobbycraft in the UK, about 60% of the price of some on ebay!
Sadly, postage will be the killer for that deal... thanks anyway.  :thumbsup:
My Enabler sells out of his garage, so no overheads - he's usually about 60% or so of retail prices over here, and these days that's a Good Deal. :thumbsup:
I've been looking at the position of the PT6s, bearing in mind the CG position, but it turns out the PT6 weighs only 100 lbs less than the original Gypsy Queen, less than a hefty passenger sitting in the wrong seat, so I think I'll leave them where they fit best, right up against the Gypsy Queen's bulkhead.
If I'd mounted them further forward, which is possible by using some of the Twotter's wing cowling, the props would be exactly alongside the flight crew, maybe not such a good idea. :(
loupgarou
Quote from: PR19_Kit on July 07, 2025, 10:44:27 PMI've been looking at the position of the PT6s, bearing in mind the CG position, but it turns out the PT6 weighs only 100 lbs less than the original Gypsy Queen, less than a hefty passenger sitting in the wrong seat, so I think I'll leave them where they fit best, right up against the Gypsy Queen's bulkhead.
Yeah, it's much better to have the props alongside some passenger, in case a blade flies away to slice someone.... ;D
Quote from: loupgarou on July 08, 2025, 12:37:53 AMYeah, it's much better to have the props alongside some passenger, in case a blade flies away to slice someone.... ;D
Hehehehe, of course!  ;D
In actuality the Sealand model has a socking great fuel tank in the centre of the cabin, and the only seats are right aft, so any broken prop blade would only slice a hole in the tank...............................,er, right. :(
Quote from: PR19_Kit on July 08, 2025, 01:23:17 AM
Better AVTUR than AVGAS in that situation, hey, Kit? :thumbsup:
Quote from: rickshaw on July 08, 2025, 02:37:39 AMBetter AVTUR than AVGAS in that situation, hey, Kit? :thumbsup:
Hell yes, another advantage of having PT6s, never mind the extra 450 bhp.  ;)
The 3-bladed Hartzell props used
on the Twotter weigh between 120 and 130 lbs each, depending on exact model.
Engine weight can be misleading when doing swaps as published weights often don't include the propeller and other engine systems weights.
But the Gypsy Queens props won't have been weightless will they?
I've got the first PT6 installed on the Sealand's wing and I think it looks pretty good. It's only had one session of PSR and it's not been primed yet, but the shape sits nicely on there and it's just the sort of thing Shorts would have done had the Sealand carried on in production. After all, they fitted similar sized turboprops to the Skyvan, albeit Garretts,  only 13 yrs later.
Thats going to look so much better with those engines ...a great choice mate  :thumbsup:  ;D
I do wish the manufacturers would find a better method of making props rotate!  :banghead:
They all have those tiny circular washers that you're meant to glue over the prop shafts once they're threaded through the cowling, and the prop almost ALWAYS ends up being glued solid!
That's just what's happened with both props on the Super Sealand. The blades are then very liable to get snapped off, so I'll have to cut the props off and devise a Dizzy type solution, adding an extra prop shaft so they spin properly.
I changed the name, and the thread title to match its new engines.  ;D
Making slow but steady progress on the Super Sealand. Both wings now have their PT6 engines installed, the fin/rudder and both tailplanes are glued in place and partially PSR'sd, and the instrument panel-windscreen joint has been PSR'd for the umpteenth time!  :banghead:
It's a very poor joint and it has a blow hole right in the centre, so I've PSR'd it numerous times, but every time I sand it the blowhole re-opens, so this time I layered it with gel superglue and let that go off before trying the PSR again.
If it was easy everyone would be building one I guess.  :(
The Carpet Monster's on vacation. Unfortunately it decided on the same venue as me!  :banghead:
After the disaster with the 'welded up' props on the Super Sealand I carefully sawed the spinners/props away from the front cowling of the PT6 engines, which went pretty well as both halves of each assembly only needed a little filing down before I was drilled them out to use Dizzy's 'rod in tube' method of making rotating props.
At which point the ruddy CM arose from its slumber and noshed one of the props, totally. It's  just vanished off the planet as far as I can see, as we've subjected the entire chalet to intensive searches and it's just not here.  :banghead:  :banghead:  :banghead:
Lots more PSR has been taking place on the engines and the fuselage, maybe 3-4 sessions each so far, and it's getting there eventually, not finished yet though.
Further on the rotating props, I had no styrene tube or rod with me, so found a decent  model shop on the Net and drove there, around 10-12  miles so not too bad, and they had the largest collection of Evergreen stuff I've ever seen! Heaven!  :thumbsup:
I got the correct size tubing but they didn't have the matching rod that would fit it, so I bought the next size up, and when I got back to the chalet I did what any self-respecting modeller would do in those circumstances, filed down the rod rod it DID fit inside the tube .  ;)  ;D
It took a bit of doing, but I only needed about 1.5" of the smaller diameter so it didn't take too long .
All I need now is  ANOTHER Twotter kit for the missing  prop!  :(
