avatar_Thorvic
CVA-01 1/700 scratchbuild #2
Started by Thorvic, June 11, 2025, 02:25:33 PM
I built a 1/700 CVA-01 back in 2009, thats been seen at many a show and is usually in my display cabinet when not at a show. However it was built using the data i had in 2008, mostly 3 views and artist imptressions, in the 16 years since i have been able to see much more detailed drawings from Warship 2014 article, Hobbs British Aircraft Carrier and a couple of years ago i was able to get a private viewing of one of the official models at the FAA Museum stores.
With these i noticed where i had gone wrong with my original build, the CVA-01 hull is a classic boat shape with curves leading to a transom stern, (The design evolving from the 1952 carrier which intern evolved from the Vangaurd hull form as it was a very stable ship), the hull sides flare out much like ark royal and eagle so the sponsons are cuite different from the more familar USN CVN that have straight flat sides.
Therefore i eventually found a hull form i could use as a basis for the lower hull, the Very Fire H39 german battleship, this had to be streteched in the middle, in order to allow the stern to be cut down to create the transome stern, but it did match the plan view of the waterline and hanger deck level. The bows and hanger were then built up as per the drawings, then the flared upper hull sides and then the sponsons. Flight deck was added and the Island created.
5d9d2f6c-4274-42aa-a2b5-f39f44bfe27d by Geoff Baker, on Flickr
18c9cb33-ee2e-4691-a428-9fe61f75324c by Geoff Baker, on Flickr
a313ab4a-bf61-41ff-90ae-c7b8a876b432 by Geoff Baker, on Flickr
862ca841-64b5-48c8-afdc-bb1bcfc4be72 by Geoff Baker, on Flickr
4b12b3dd-7eae-400b-bfde-9b3bf6ee3b96 by Geoff Baker, on Flickr
9fef2b12-2a72-40b9-8ef0-a8a95413cc71 by Geoff Baker, on Flickr
0b465775-ccaa-41b7-96c6-3c0af52fec0c by Geoff Baker, on Flickr
Very nice, I look forward to seeing it at Telford.
There's a guy in the Gloucester Model Boat Club building a 1/96 scale CVA-01 for radio controlled sailing just now. I had hoped to see it at this year's Model Boat Mayhem, but it wasn't there. The pics show it to be HUGE of course.
He's using Tamiya 1/100 scale aircraft kits for the air wing, which means converting their F-4Es into F-4Ks. Good luck with THAT job I'm sure!
Quote from: PR19_Kit on June 12, 2025, 05:11:01 AMThere's a guy in the Gloucester Model Boat Club building a 1/96 scale CVA-01 for radio controlled sailing just now. I had hoped to see it at this year's Model Boat Mayhem, but it wasn't there. The pics show it to be HUGE of course.
At that scale a nose job is about all you need to do other than paint it in FAA marking.
They did do the F-4K in 1/100 but they're as rare as hen's teeth now!
You could try HERE for the aircraft. I believe they are also available in individual aircraft types as well as the linked Ark Royal set.
scautomoton
Looking good Geoff! As mentioned, I look forward to seeing it at Telford.
Does the island actually sit that far inboard?
Quote from: Gondor on June 12, 2025, 01:41:52 PMYou could try HERE for the aircraft. I believe they are also available in individual aircraft types as well as the linked Ark Royal set.
Yeah i had that from Mike when i got their Ark Royal, also had types from Dorset Printman and SNAFU off shapeways before it folded. Currently investigating possibility of some of the projected types too. Aiming to get the carrier painted up first and then determine the airgroup.
Glenn Gilbertson
Quote from: scautomoton on June 12, 2025, 02:18:27 PMDoes the island actually sit that far inboard?
The idea was to enable them to taxi aircraft past the island outboard as well as on the man deck.
Joe CalPo
Ugh, an in-deck elevator.   :banghead:  Limits the ability of what it can carry, unlike the deck edge where tails and noses can extend over the edge.
Great work on the model, and your research.   :thumbsup:  Looking forward to the final result.
Quote from: Joe C-P on June 16, 2025, 03:47:45 AMUgh, an in-deck elevator.   :banghead:  Limits the ability of what it can carry, unlike the deck edge where tails and noses can extend over the edge.
The idea of having aircraft taxi on the outboard side of the island seams to be a waste of space to me. There would be very few times that air operations would be busy enough for you to taxi aircraft from the edge lift to the forward Starboard catapult while keeping the main deck clear for other air operations.
