The Hawker Beechcraft Dragon MRA1, the Nimrod's replacement- Resurrected!
Started by PR19_Kit, June 07, 2025, 05:08:58 AM
While waiting for the Light Aircraft Grey underside paint to go off, I started on the second Harpoon missile, and what a fiddly job that is, the parts are SO small.
I've discovered that the four main wing are all slightly different to each other, and they're only meant to fit their own recesses in the missile body. No wonder I had such a job with the first one, but it would have been good if they'd SAID that in the instructions somewhere!  :banghead:
Sorry, I'm out of this GB.  :banghead:
After making very good progress on the actual build, that went almost perfectly to plan, once again it was the painting that's wrecked it. That pebble-dash primer meant I had to sand it all over, which screwed up most of the detailing, but now I've found that primer won't stay attached to the model! I masked it up before painting on the Hemp upper surfaces, but found that the tape took the entire colour and primer layers clean off when I had to re-position one mask. :(
I'm going to  have to strip the entire model and re-prime and re-paint it, and that'll probably wreck the masks as well, so there's not enough time for all that. I'll surely finish it, I've had the idea in my head for ages, but not for this GB.
Please can you  move this thread else where Chris.
That stinks!
I know it will be worth it when it's done.
Would a wipe down with white spirits or turpentine help as a key to protect the paint finish rather than having to strip the paint and start again?
No, the original and the second coat of primer just aren't adhering to the plastic. Not sure if it's the rubbish primer or some strange Sword styrene, but it means I can't mask up the demarcation lines as the tape just pulls all the paint off when I de-mask it.
It's an 'all or nothing' job I'm afraid. :(
Sometimes it's best to treat a short run kit like its resin and give it a wash and brush up.
I've replied to your message Kit.
Did you wash the parts before you started to assemble them?
Quote from: McColm on June 11, 2025, 05:12:34 AMDid you wash the parts before you started to assemble them?
Sure did, but maybe it needed something stronger than soap and water.
It seems that my original idea of bathing it in brake fluid won't work as it'll dissolve the resin bits, and thanks to Fred Zenrat for that sage advice.  :thumbsup:
So what can I use to strip ALL the paint off it without damaging any bits? I'll have to mask the open windows or the stuff will get inside and wreck my carefully painted cockpits. :(
HarryPhishnuts
Quote from: PR19_Kit on June 07, 2025, 02:01:54 PMBeing a Sword kit though, it isn't that easy a build. Quite fiddly in places, but it's coming along OK.
I"ve got a 1/72 Sword FJ-3 in the stash so I'll be interested in how that builds out.
No Matter Where You Go, There You Are - Buckaroo Banzai
Quote from: HarryPhishnuts on June 11, 2025, 08:30:12 AM
I used the Sword 1/72 EE/BAC Lightning T.55 for my kitbash Thunderbolt and didn't have any problems using acrylic paint with a hairy brush.
Quote from: PR19_Kit on June 11, 2025, 06:35:43 AMSo what can I use to strip ALL the paint off it without damaging any bits? I'll have to mask the open windows or the stuff will get inside and wreck my carefully painted cockpits. :(
Fairy Power Spray has been relaunched, although I'm not certain its the same stuff. I've got some at home, I'll give it a try and let you know.
If it's acrylic paint then Hannants sell an Extracylics-branded spray paint stripper called PURISOL. It doesn't specifically say it's okay with resin:
https://www.hannants.co.uk/product/PURISOL
I've got a little jar of something called "Eazi Strip Gel", a specialist model paint stripper, which I bought ages ago. "Eazi" seems to be the name of the company. Afraid I've lost the leaflet ages ago, so I can't confirn whether it's okay on resin or not, but I've put a bit on some resin scrap from the MUSTARD build so I'l report on the results in 24 hours.
I can't find it on Hannants, nor can I find a website for them, so it may be they're not in business any more. I did find a couple of web forum mentions which implied that it's more from the model railways world, and that would make sense if I bought it from the LHS I think I did.
For what it's worth:
Eazi Scenic Modelling Products
4 Manor Court
Blaby
Leics
LE8 4FW
Tel: 0116 278 5134
Mob (I presume): 07984 678395
