Culinary Combat Commando
Started by PFJN, May 10, 2025, 07:11:51 PM
Robomog
This is so left field and bonkers  :thumbsup:  :thumbsup:
Looking forward to seeing the finished article
Mog
Sounds a bit like "Under Siege". Will he look like Steven Seagal?
PFJN
Quote from: Gondor on May 17, 2025, 03:52:37 AMSounds a bit like "Under Siege". Will he look like Steven Seagal?
Hi, that thought crossed my mind but I'm probably not a good enough model builder to pull that off  :rolleyes:
For now here is a shot of my current progress.  I have a base coat on the main figure, the "Heavy Ballistic Cloth Battle Apron", and head, and also am working to finish up the "Tactial Toque du Chef" (hat) and "Compact Cast Iron Combat Skillet".  Unfortunately, currently the hat is badly oversized and will likely need a lot of trimming  :-\  I will also then work on finishing up the paint jobs of all the pieces.
Initially I had tried to do a camouflage scheme for the main figure's uniform, but it didn't turn out too well, so I removed most the paint, and now am thinking of just going with a solid color (hopefully ith a bit of shading).
Regards  &lt;_&lt;
Steel Penguin
its looking good so far, and the concept is a major prop for it  :thumbsup:
Still a great concept and off beat. Great work
You can get camo decal sheets for BDUs, mostly in US or Ukraininan schemes.  ;)
Build is still lookin' good!  :thumbsup:
He is coming along very  nicely bud 👍 👌
It's amazing the results you can get with a teeny brush (tm) and a 'If you don't know what you can't do, then anything's possible' attitude.
