avatar_Gondor
The Macchi C.150 Tempesta
Started by Gondor, May 04, 2025, 08:14:15 AM
Designed by Mario Castoldi as one of several ideas he had for a new fighter in the mid-1930s, the aircraft found little favour due to only average handling and its outdated fixed undercarriage.
Only one aircraft was produced, which ended up being a company hack for a time until war broke out, when it was pressed into service as a factory defence fighter until it was damaged in a hard landing. Unfortunately, in an earlier air raid, most of the records for the aircraft were destroyed, which meant that repairing the aircraft was impossible, so it was scrapped.
The idea for this build came from following a real-world build on Britmodeller. I will take any inspiration from where I find it. I bought the base kit off eBay a couple of weeks ago at a reasonable price, only to find at the Scottish Nationals last weekend, the same kit for less than I paid  :banghead:  Typical  :rolleyes:
Anyway, so far I am really enjoying what I have been doing, which is cutting up plastic  :wacko:
One modified wing
Yes, there is more work to be done, but I believe that I have a good basis to start with. The other wing has also been similarly worked on, but I now have the problem of remembering which is the top and which is the bottom of these replacement wings  :banghead:
While some filler is drying in the gaps from chopping up the donor wings, I think it's time to turn to the fuselage.
There is not much inside this old kit, so plenty of room for some improvements, not much as not much can be seen.
I think this seat needs a bit of a makeover
Maybe a complete rebuild or replacement  :-\
A little more work so far today. I'm trying to do at least one little bit per day. Today, so far, I have glued the upper decking to one fuselage half; the other half is there to help with alignment.
Next, I will be detailing the inside of the cockpit. Not going to put much in there, a bit of structure and an instrument panel should do it. Does anyone know of a good colour to paint the inside of late 1930's Italian aircraft?
Quote from: Gondor on May 07, 2025, 11:25:58 AMA little more work so far today. I'm trying to do at least one little bit per day. Today, so far, I have glued the upper decking to one fuselage half; the other half is there to help with alignment.
Eggplant?
Italian internal colour ? A light bluey/green. I've seen Humbrol 23 mentioned in the past, which is Duck Egg Blue.
Thank you guys! No Humbrol 23 in my stock, but as I have access to the internet, I am sure I can find an equivalent. Saying that, I have just finished placing an order to the BIG yellow H before I logged onto here, so no chance I am going to order anything from them until next month.
So I found out that Hobbycraft stocks the paint, there is a store near my work and it has stock, so the net tells me  :-\  After work tomorrow, I will go in and see if there is any available or not. If the latter, then it will be down to good online shopping to fill my need.
Looking good so far. I'm off to google to see if I can find an idea of what she might end up looking like.
No need for the online shopping, yet. I did go shopping after work, but the company's website lied. There are no tins of Humbrol 23 Enamel unless you have one from years past. They do have some of the Acrylic version, so I bought one. Just a short time ago, I found an old Humbrol paint catalogue which gives the alternatives for the old Authentic range, of which I have several. I found the equivalent! HB4, which I have stock of! No idea how good the paint is, the rim of the tin is a little bit rusty though  :unsure:
Failing miserably at doing something each day on this build in the physical sense. Mentally, I am working on the interior, which will be minimal but more than nothing. I also found out that the windscreen is missing from the kit. Not too big a problem as it will be quite minimal anyway. I am sure I will be able to fudge something up to do. I am not worried about the undercarriage yet, that will be worked on once I finish the wings and work out the wing-to-fuselage joint.
It's surprising what you find when looking for something else. I was looking for an F-16 spine when I found a small packet with the Weroclub logo on it and labelled V053. It contains two bucket seats and control columns for WWII aircraft, I think I have just found a large amount of my interior for this build.
I'm thinking this is going to be quite neat  ;D
