avatar_nev
Mirage 2000
Started by nev, April 08, 2005, 12:27:14 AM
Patrick H
#30
Never realised that Xtracolors paint needed that much drying time. Would be a reason to change brands for me. I used to have the second coat of Humbrol paint on in a matter of an hour or so. That is sprayed an not brushed, might be a diffrence in drying time there also
You must be a man with lots of patience Nev.
Patrick
My webpage
Patric, I've found that Xtracolor paints can't be brushed on, typical gloss paints!!! The drying time is quite long, I normally leave mine for about a day before I start handling the modl again, but then I o tend to spray on a couple of coats at the same time.
Patrick H
Guess Ill stay with the old trusted Model Masters and Humbrol paints then. Dry in a matter of hours in stead of days.
My webpage
I did/do brush paint with Xtracolour - can be done but need's a lot of coats.
Now switched almost exclusively to Xtracrylic - brilliant !!! :wub:
I'm gonna have to try that new xtracryllic stuff.
I don't think you'll be disapointed Lance
Finished!!  :cheers:
Thats 3 kits completed so far this year  :cheers:
mmm, deltas...  :wub:
Have you seen the size of my SNECMA M-53 P2?
Absolutely stunning, Nev!   :wub:   :wub:  :wub:
What a stand-out this will be in contrast with all the dull greys out there, eh?
Great job.  Keep up the productivity at this rate and you'll need a whole new shelf soon.
retro_seventies
now THAT's what i call a real blue!
real eyecatcher there nev, certainly not something that you see every day!
anthonyp
Nice Mirage!  I'm always looking for a way to get blue into a camoflage scheme, but overall blue looks great.
I exist to pi$$ others off!!!
Thanks guys.
Lee, I wondered if you'd pick up on the serial  :D   The real serial is XV408, which I changed to XV840 just to bump it along a bit.  Was all I could do as it was the only white serial numbers I could find in my stash.
