avatar_Spino
F-8S "Super Crusader" - Ultimate USN Dogfighter - Done P. 6
Started by Spino, April 06, 2025, 03:02:49 PM
HarryPhishnuts
Ok I've used my 3D printer to print out some parts here and there but this is awesome.  :thumbsup:  :bow:
No Matter Where You Go, There You Are - Buckaroo Banzai
Spino
Yeah my M.O. is becoming something like "if I can't buy it, I'll print it!".   ;D
Speaking of printing, I've got some decal paper and clear-coat, so this build may get custom decals.  I'm also probably going to have to re-print the nose section - it's a bit too wide for the F-8 canopy.  I suspect the cross-section of the XF8U-3 is tapered a bit more near the top rear of the cockpit, but I should be able to sort that out.
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
Spino
Well the wings finally finished.  Nose still needs to be either re-printed or modified so that the canopy will fit.  But this is the basic look (and no, the wings are not going to stay black).
Regards, Spino
Very sharp looking, figuratively and literally too!  :thumbsup:
That's looking so sleak it could slice butter and not leave a mark  ;D
Spino
#37
I was honestly worried that it would look a little fat compared to the regular F-8, but that doesn't seem to be the case.  Makes sense it would be pretty sleek, being a Mach 2.35 airplane.  Once I get that nose fixed it'll be time to fill in the gaps and start painting.  The gun fairing position I currently have makes absolutely no sense, it's way too close to the starboard upper AIM-7 trough.  Didn't really want the gun on the left side, but it looks like that's what I'm stuck with from an internal arrangement perspective.  Ah well, that's where it is on the Tomcat.  I'm also going to have to figure out how to print the Y-pylons.  Those have very specific geometry and may be hard to get right.  The good news is that thanks to computers and geometry, all I have to do is get one side right and then I can mirror it to get the other one.
It turns out the Crusader III is not actually all that much bigger than the F-8E, just three feet longer.  The internal volume of the fuselage is presumably greater to keep that big hungry J-75 engine fed, and house the electronics for the AIM-7s, but presumably Vought was going for the same "smallest and lightest airplane around the biggest engine we can get" approach that they took with the original Crusader.
Regards, Spino
IIRC, one of the original F8U designs had a 20 mm gun in the lower intake lip, and one on each flank of the duct. Not certain if that's an option with the different sugar scoop arrangement, though.
perttime
Earlier on, you mentioned putting a Vulcan gun on it. I guess that would take some space.
Spino
Quote from: perttime on April 16, 2025, 01:32:38 AMEarlier on, you mentioned putting a Vulcan gun on it. I guess that would take some space.
Yeah the A-7s eventually went to Vulcans, I figure this probably would too.  I'm presuming that this is the third letter designation for the Crusader III, so starting at F-8F, then F-8M, then F-8S or something like that, so I figure by that point they probably would have been considering a Vulcan instead of the Mk-12s given all the issues those seem to have had.
Regards, Spino
Spino
I see now that I've gone from "Kitbasher" to "Makes own decals".  That's definitely about to be the case lol  ;D
This plane is gonna need some!
Regards, Spino
But you're also losing 4x Mk12 revolver cannons and their ammo handling.
Quote from: scooter on April 21, 2025, 07:27:24 AM
And their mass (OK, so the Vulcan will make that up plus a little but the better fire power is worth it!)
Spino
After some more consideration and review of the design, I think I'll put the Vulcan low on the starboard side, directly in front of the nose gear bay.  The ammunition feed should be able to go up around the side of the intake duct to a drum behind the cockpit that way.
Regards, Spino
